León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor jony83 el 31 May 2016, 22:06
cvillajos escribió:
jony83 escribió:una pregunta, los que teneis un st. como habeis pasado el cable desde la luz de matricula hasta el maletero ??
Con una guía, primero abajo a la derecha te encuentras una trampilla a desmontar, segundo arriba recto te encuentras el agujero con los cables que dan al maletero.
Gracias! mañana intento ponerme manos a la obra con la camara! que la echo en falta del otro coche. :comediante:
jony83
Agradecido: 20 veces
Notapor jony83 el 04 Jun 2016, 12:05
Camara colocada en el parachoques. me falta coger los 12v de la marcha atras y pasar el cable de la camara hasta la guantera.
ahora necesito ayuda, llevo leyendo el post mas de una hora y mas o menos lo tengo claro.Tengo sensores traseros , no aparecen en la pantalla de 6,5 . ahora que tengo que codificar ???
- necesito subir la intensidad de la marcha atras hasta el 127.
- configurar la camara con el vag com, pero tengo la version 15.7.0 y segun he leido, da problemas no ???
:cry: :cry: :cry: :cry:
jony83
Notapor Caanpulo el 04 Jun 2016, 14:20
Yo te recomiendo que cojas 12v del fusible del mechero y asi te ahorras empalmar cables, y el pasacables que va desde el techo hasta el porton se rompe las pestañas al sacarlo, y si vas a coger corriente de la luz de marcha atras es necesario sacarlo.
Y con respecto a lo del vag com muchos compañeros han tenido problemas, yo no me complique, busque un chaval que tenia vagcom original y me lo codifico gratis
Se me pasaba una cosa, si coges corriente de marcha atras te saldra el famoso aviso de park pilot no disponible ya que al desengranar la marcha atras corta la corriente y la camara se queda sin alimentar, y despues de quitar la marcha en la pantalla se queda 8 seg la imagen y al no llegarle señal salta el aviso. Esto en el caso de las pantallas 6,5
Caanpulo
Agradecido: 42 veces
Notapor jony83 el 04 Jun 2016, 14:47
Pero así se queda alimentada siempre la cámara y no me hace mucha gracia la verdad.
Si pasa eso por alimentarla con la marcha atrás, la original de dnd la coge????
jony83
Notapor MORKAS el 04 Jun 2016, 15:00
Sigue los pasos del mod..coje de la luz de marcha atras..
MORKAS
Agradecido: 369 veces
Notapor MORKAS el 04 Jun 2016, 15:01
Y para codificar OBD Eleven..pues en tu psntalla con vagcom (de momento)..te corrompe el 5F
MORKAS
Notapor Caanpulo el 04 Jun 2016, 17:50
Tiene corriente solo con el contacto dado, yo cogi la corriente de marcha atras y alfinal acabe poniendolo directo del fusible porq me daba el error de park pilot no disponible, tambiem se puede poner un rele temporizador para q durante esos 8seg tenga corriente y luego se corte
Caanpulo
Notapor MORKAS el 04 Jun 2016, 20:45
Yo lo tengo cojido de la marcha atras y jamas me ha dado ningun error..y llevo con ella desde que compre el coche...la puse al poco...
MORKAS
Notapor Caanpulo el 04 Jun 2016, 20:51
MORKAS escribió:Yo lo tengo cojido de la marcha atras y jamas me ha dado ningun error..y llevo con ella desde que compre el coche...la puse al poco...
Pero la pantanlla de 6,5"??, nose, yo cuento mi experiencia, me arrepiento de no ponerlo directo al fusible desde un principio, ya que tuve que pelar los cables de marcha atras para luego que no me funcionara
Caanpulo
Notapor MORKAS el 04 Jun 2016, 21:25
Yo use robacorrientes y aun siguen ahi..y no me fallo nada
MORKAS
Notapor cvillajos el 05 Jun 2016, 11:26
@Caanpulo yo también tengo cogidos los 12v del fusible del mechero y sin problemas.
Sobre lo de codificar la de 6,5" con el 15.7.0 te diría que al 95% no vas a tener problemas porque lo que tienes que hacer es de "LongCoding" (no de canales de adaptación *gen2*, que son los problemáticos al escribir con ese cable). Así que con un 5% de riesgo tu decides si modificas los dos bits que necesitas...
cvillajos
Agradecido: 3612 veces
Notapor jony83 el 05 Jun 2016, 12:28
cvillajos escribió:@Caanpulo yo también tengo cogidos los 12v del fusible del mechero y sin problemas.
He comprado tb el odbeleven para no tener ningún problema. Ya me pasó que desapareció la función de BT y me cagué!
Cual es la codificación para los q llevamos sensores de parking traseros y no nos sale en la pantalla?
Mi idea,si se puede, es q no salga en la pantalla los sensores, sólo la imagen de la cámara.
Un saludo y gracias!
jony83
Notapor cvillajos el 05 Jun 2016, 12:34
En el primer post los tienes. Creo que son los bits 4 del 18 y del 19 (no recuerdo cada uno para qué), pero no actives el de los sensores y listo.
cvillajos
Notapor jony83 el 12 Jun 2016, 12:06
Camara instalada y funcionando , pero con algun fallito!!!!!
Os cuento. alimentacion cogida a la marcha atras.
he subido la intesidad de la marcha atras hasta 127 , desconozco si se puede subir mas.
he codificado el stg 10 park assist - coding 07 - en el bit 3, bit 4-5 : 20 camera type , environment camera installed.
he codificado en 5F MMI3g- coding 07 - bit 19 , el 4.
si codificaba el bit 18 , el 4 me saltaba el error de park pilot no disponible despues de meter la marcha atras.
se ve perfecto.
ahora viene el problemilla. dependo de como metas la marcha atras, funciona la camara o no. Si la engranas despacio , no funciona la camara trasera, si la engranas rapido funciona perfectmente las veces que lo hagas.
alguna idea????
jony83
Notapor genialsoft el 12 Jun 2016, 15:02
jony83 escribió:Camara instalada y funcionando , pero con algun fallito!!!!!
se ve perfecto.
alguna idea????
Prueba a subir la intensidad a 200 por ejemplo. No creo que tenga que ver con la velocidad con que engranas la marcha.
Enviado desde mi S6-Edge
genialsoft
Agradecido: 346 veces
Usuarios navegando por este Foro: Anthropic, Majestic-12 [Bot], Semrush y 5 invitados
