León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor jony83 el 12 Jun 2016, 17:01
genialsoft escribió:
jony83 escribió:Camara instalada y funcionando , pero con algun fallito!!!!!
Os cuento. alimentacion cogida a la marcha atras.
he subido la intesidad de la marcha atras hasta 127 , desconozco si se puede subir mas.
he codificado el stg 10 park assist - coding 07 - en el bit 3, bit 4-5 : 20 camera type , environment camera installed.
he codificado en 5F MMI3g- coding 07 - bit 19 , el 4.
si codificaba el bit 18 , el 4 me saltaba el error de park pilot no disponible despues de meter la marcha atras.
se ve perfecto.
ahora viene el problemilla. dependo de como metas la marcha atras, funciona la camara o no. Si la engranas despacio , no funciona la camara trasera, si la engranas rapido funciona perfectmente las veces que lo hagas.
alguna idea????
Prueba a subir la intensidad a 200 por ejemplo. No creo que tenga que ver con la velocidad con que engranas la marcha.
Enviado desde mi S6-Edge
imposible subir de 127 el valor. :enfurecido:
jony83
Agradecido: 20 veces
Notapor Davido2790 el 13 Jun 2016, 00:04
se ve perfecto.
alguna idea????
En park assist selecciona la cámara japonesa o algo así, si mal no recuerdo es la última, así es como lo tengo yo, sin problemas y a la primera todo, y el byte 18 el 4 no lo activo, creo que tú lo tienes igual por lo que he visto en tu explicación
Davido2790
Agradecido: 81 veces
Notapor jony83 el 13 Jun 2016, 08:24
se ve perfecto.
alguna idea????
Cámara japonésa?? Esa opción no la vi..
jony83
Notapor jony83 el 19 Jun 2016, 21:03
Bueno , ya he descubierto otra cosa del mal funcionamiento de la camara.
funciona el 50% de las veces. una vez si, a la siguiente no, y asi sucesivamente, independientemente del tiempo, forma de engranar la marcha atras...etc.
alguna solucion ? intento codificarla con odbeleven ? porque con el vagcom no funciona bien :pelea:
jony83
Notapor freedom2co el 20 Jun 2016, 00:32
chicos si alguien quiere una la vendo me llego y no la montare..
viewtopic.php?f=4&t=117920&p=1895510#p1895510
saludos.
freedom2co
Notapor MORKAS el 20 Jun 2016, 05:29
jony83 escribió:Bueno , ya he descubierto otra cosa del mal funcionamiento de la camara.
Has hecho la instalación con el montaje de condensador?..a mi no me falla nunca..de momento
MORKAS
Agradecido: 369 veces
Notapor jony83 el 20 Jun 2016, 09:16
no, ni condensador ni rele...
subi la intensidad de la luz trasera.
jony83
Notapor Davido2790 el 20 Jun 2016, 12:42
De donde eres? Haber si te puedo echar un cable
Enviado desde mi ONE E1003 mediante Tapatalk
Davido2790
Notapor jony83 el 20 Jun 2016, 16:04
Enviado desde mi ONE E1003 mediante Tapatalk[/quitar]
De Zaragoza! Pero creo q el problema está en la codificación.
Hoy con el odbeleven he puesto los sensores traseros para q se vean en pantalla, y ahora funciona bien, pero después de quitar la imagen de marcha atrás , me sale el park pilot y se queda unos 8-10 seg
jony83
Notapor Caanpulo el 20 Jun 2016, 22:17
Yo creo que la solucion seria conectarlo directo al fusible de mechero, ami tambien me pasaba eso y una vez conectado directamente me funciona 100%
Caanpulo
Agradecido: 42 veces
Notapor jony83 el 21 Jun 2016, 08:05
En cuanto tenga un rato lo pruebo.gracias!
jony83
Notapor P.carrizo.leonstfr el 21 Jun 2016, 12:22
Hola buenas, me pasa igual se puso la alimentación en la marcha atrás i salta el Park pilot.. Si l alimentas por al fusible del mechero funciona correctamente?? mi león es un st my16 sin sensores ni Park pilot ni nada lleva la radio media system plus 6,5 con full link. Saludos!
P.carrizo.leonstfr
Notapor Caanpulo el 21 Jun 2016, 15:04
El mio tambien lleva pantalla de 6,5 con full link y lo tenia conectada a la luz de marcha atras y solo funcionaba la primera vez que metia la marcha atras desde que arrancaba el coche despue sya me salia lo de park pilot no disponible, lo puse directo al fusible y va perfectamente
Caanpulo
Notapor P.carrizo.leonstfr el 21 Jun 2016, 15:10
Al fusible de la toma de 12v del mechero no??
P.carrizo.leonstfr
Notapor Caanpulo el 21 Jun 2016, 21:28
Correcto
Caanpulo
Usuarios navegando por este Foro: Anthropic, Facebook/Meta/ExternalAgent y 3 invitados
