León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor P.carrizo.leonstfr el 21 Jun 2016, 22:52
Al final se a cojido la alimentación a la luz del maletero i con condensador porque son en fallaba igual
P.carrizo.leonstfr
Notapor Davido2790 el 22 Jun 2016, 12:17
Caanpulo escribió:
P.carrizo.leonstfr escribió:
Caanpulo escribió:
jony83 escribió:
Davido2790 escribió:
jony83 escribió:
MORKAS escribió:
jony83 escribió:Bueno , ya he descubierto otra cosa del mal funcionamiento de la camara.
funciona el 50% de las veces. una vez si, a la siguiente no, y asi sucesivamente, independientemente del tiempo, forma de engranar la marcha atras...etc.
alguna solucion ? intento codificarla con odbeleven ? porque con el vagcom no funciona bien :pelea:
Has hecho la instalación con el montaje de condensador?..a mi no me falla nunca..de momento
no, ni condensador ni rele...
subi la intensidad de la luz trasera.
De donde eres? Haber si te puedo echar un cable
Enviado desde mi ONE E1003 mediante Tapatalk[/quitar]
De Zaragoza! Pero creo q el problema está en la codificación.
Hoy con el odbeleven he puesto los sensores traseros para q se vean en pantalla, y ahora funciona bien, pero después de quitar la imagen de marcha atrás , me sale el park pilot y se queda unos 8-10 seg
Yo creo que la solucion seria conectarlo directo al fusible de mechero, ami tambien me pasaba eso y una vez conectado directamente me funciona 100%
Hola buenas, me pasa igual se puso la alimentación en la marcha atrás i salta el Park pilot.. Si l alimentas por al fusible del mechero funciona correctamente?? mi león es un st my16 sin sensores ni Park pilot ni nada lleva la radio media system plus 6,5 con full link. Saludos!
El mio tambien lleva pantalla de 6,5 con full link y lo tenia conectada a la luz de marcha atras y solo funcionaba la primera vez que metia la marcha atras desde que arrancaba el coche despue sya me salia lo de park pilot no disponible, lo puse directo al fusible y va perfectamente
Que activaste por el Vagcom? Yo tengo igual que tu y lo tengo con la luz de marcha atrás sin problemas
Davido2790
Agradecido: 81 veces
Notapor Antonio_12812 el 22 Jun 2016, 12:51
Muy buen brico gracias compañero
Antonio_12812
Notapor jony83 el 25 Jun 2016, 12:11
a mi , la unica manera que funcione bien es activando en pantalla los OPS traseros, pero me sale con la vision de la marcha atras y luego cuando la quito vuelve a salir los OPS , duran 8 seg y se vuelven a ir.
podeis pasar la codificacion que llevais a los que os funciona bien ??
jony83
Agradecido: 20 veces
Notapor Tarzan el 25 Jun 2016, 17:37
Muy buenas tardes.
Por fin me llego todo el material para instalarla, ahora solo me hace falta tiempo .
Enviado desde mi SM-G920F mediante Tapatalk
Tarzan
Notapor Tarzan el 28 Jun 2016, 17:51
Tengo una pequeña duda, de donde cojo corriente a la camara, del mechero o de la macha atras.
El mio es un leon 2.0tdi 150cv DSG.
Haber si @rojas que es experto me lo sabe decir.
Tarzan
Notapor rojas el 28 Jun 2016, 18:09
Cógelo del mechero y te ahorras rele y condensador
Enviado desde mi SM-G925F mediante Tapatalk
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1888 veces
Notapor genialsoft el 28 Jun 2016, 18:31
Yo por llevarle la contra a @rojas de la marcha atrás y le subes la intensidad y ya está. Ni rele necesitas. Porque el rele lo necesitas igual desde el mechero.
Enviado desde mi S6-Edge
genialsoft
Agradecido: 346 veces
Notapor tokedj1989 el 28 Jun 2016, 19:17
una pregunta para la de 6.5 se codifica tambien con vagcom como las de 5.8?
Enviado desde mi GT-I9505 mediante Tapatalk
tokedj1989
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 25 veces
Notapor Davido2790 el 28 Jun 2016, 20:50
tokedj1989 escribió:una pregunta para la de 6.5 se codifica tambien con vagcom como las de 5.8?
Si
Davido2790
Notapor tokedj1989 el 29 Jun 2016, 03:59
Si
pero con el 12.12 vale o tiene que ser el vcp o el vagcom original?gracias
tokedj1989
Notapor Isidrito el 29 Jun 2016, 13:27
Tarzan escribió:Muy buenas tardes.
Donde has comprado esa cámara? Que tal funciona esa por la resolución y demás?
Isidrito
Agradecido: 10 veces
Notapor Tarzan el 29 Jun 2016, 14:35
Todabia no la he montado, cuanto este pondre fotos.
Tarzan
Notapor dookky el 01 Jul 2016, 13:16
Hola soy dookky del club octava os ando siguiendo por aquí con el tema de la cámara k me hace interferencias he leído k se puede subir intensidad podríais poner la codificación para hacerlo ?[THUMBS UP SIGN]
dookky
Notapor zacarias el 04 Jul 2016, 18:42
@rojas , te he dejado un mensaje privado con respecto a este tema. te agradecería muchísimo que lo pudieras leer.
un saludo :reverencia:
zacarias
Agradecido: 201 veces
Usuarios navegando por este Foro: Anthropic, SentiBot y 4 invitados
