León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor aprietatuercas1974 el 12 Sep 2017, 20:07
el problema es la version de software que han realizado modificaciones y se debe de investigar cuales producen ahora los cambios
aprietatuercas1974
Agradecido: 358 veces
Notapor buffer el 13 Sep 2017, 01:10
miceor escribió:Bueno, pues os pongo algunas actualizaciones QUE HE ENCONTRADO DE CASUALIDAD para Mib1 y Mib2.
Mib1 - Pantalla de 5.8"
Versión de la actualización : 0480 (Ultima versión compatible con el dispositivo)
Equipos compatibles con esta actualización : MIB 1GEN 5,8" con HW:041 FW:0425
Descargar el archivo desde:
Desde copia de seguridad de centralitas --- https://drive.google.com/drive/folders/0B-nF6uppzDHYZVBOWGtkS1J0bjQ
Drive--- https://drive.google.com/open?id=0BxJGznK3NRXVRGRFWlJwaDhjNlU
Descomprimir el archivo. La estructura final debe quedar de la siguiente forma:
Carpeta: SEAT_NAV_SSB
Carpeta: SEAT_PLUS_SSB
Archivo: metainfo2.txt
Copiar las dos carpetas y el archivo en una tarjeta SD Class 10 de 8 GB (Si usais una tarjeta lenta, la actualización se puede eternizar, con la Class 10 tarda unos 40 minutos)
Mib2 - Pantalla de 6.5"
Versión de la actualización : 0330 (Beta) Instalar esta y luego la 0346. La 0330 es una Beta y tiene fallos conocidos (No asustaros si veis cosas raras) se solucionan actualizando a la 0346.
Equipos compatibles con estas actualizaciones : MIB 2GEN 6,5" HW:024 FW:0245
Drive--- https://drive.google.com/open?id=0BxJGz ... mw0UHNfejg
Carpeta: powerc
Carpeta: mainplus
Carpeta: main
Carpeta: DUW014
Carpeta: DUW013
Carpeta: DUE410
Carpeta: DUE409
Carpeta: DUE406
Carpeta: DUE405
Carpeta: cpuplus
Carpeta: cpu
Carpeta: bluetooth
Copiar las carpetas y el archivo en una tarjeta SD Class 10 de 8 GB (Si usais una tarjeta lenta, la actualización se puede eternizar, con la Class 10 tarda unos 40 minutos)
Versión de la actualización : 0346 (Ultima versión compatible con el dispositivo)(Instalar previamente la 0330)
Equipos compatibles con estas actualizaciones : MIB 2GEN 6,5" HW:024 FW:0245 y logicamente HW:024 FW:0330 (Si existiese alguno)
Drive--- https://drive.google.com/open?id=0BxJGznK3NRXVTU1nbXN5UjlCbDA
Carpeta: powerc
Carpeta: mainplus
Carpeta: main
Carpeta: DUW070
Carpeta: DUW069
Carpeta: DUW013
Carpeta: DUW014
Carpeta: DUE410
Carpeta: DUE409
Carpeta: DUE406
Carpeta: DUE405
Carpeta: cpuplus
Carpeta: cpu
Carpeta: bluetooth
Método de actualización MIB1 5.8"
COMPROBADO Y CON SOLUCIÓN A LOS ERRORES PRESENTADOS
1) Utilizar una SD de 8GB como mínimo y a poder ser Class 10 (Es mucho más rápida)
2) Formatear la tarjeta SD en FAT32
3) Copiar los datos en la tarjeta SD (Todas las carpetas y el archivo TXT deben quedar en el raiz de la tarjeta)
4) Introducir la tarjeta SD en el Alojamiento SD1 del reproductor de la guantera.
5) Poner el contacto del coche (No arrancar el motor bajo ningún concepto ni apagar el Infotainment)
6) Presionar el botón Menú del Infotainment y mantener pulsado hasta que salga el menú de servicio.
7) Seleccionar Actualización SW y pulsar en Actualizar.
8) Esperar a que el sistema nos dé un mensaje de Actualización Realizada y confirmamos.
9) Conectamos el dispositivo de diagnosis (Vagcom, OBDeleven, etc) y hacemos un Scan.
10) Borramos todos los fallos.
Método de actualización MIB2 6.5"
Como ya se ha explicado, para actualizar la MIB2 desde la 0245 hasta la 0346 hay que actualizar previamente a la 0330.
Por tanto, realizar primero la 0330 siguiendo todos los pasos descritos aquí abajo y luego la 0346 y otra vez los mismos pasos y evitaremos sorpresas desagradables.
ERRORES QUE NO SE BORRAN AL BORRAR FALLOS
1) Normalmente después de las actualizaciones hay que validar el SVM (Software Version Manager)
El sistema arrojará un error : 1555 - Check Software Version Management que es permanente y no se borra.
Para solucionarlo seguir estos pasos del video de @Morkas :
[ Video ]
Entramos en la 5F
Adaptaciones
Confirmación de la modificación de montaje (Confirmation of installation change)
Copiamos el valor que nos muestra (XXXX)
Usamos una calculadora que disponga de XOR (Bitwise calculator por ejemplo)
En hexadecimal ponemos el valor que tenemos .
Le damos a XOR.
Ponemos estos valores C9D2 y le damos al símbolo = para que lo calcule.
El valor que nos ponga, lo ponemos en Confirmación de la modificación de montaje y Aceptamos.
Después de aceptar veremos que el valor no ha cambiado con respecto a lo que teníamos al principio. ES NORMAL.
Si lo haces con VagCom dejad un espacio en medio. (XX XX) al meterlo de nuevo .
Una vez realizado, volver a hacer el Scan y borrar el fallo definitivamente.
2) Error Reproductor de media en posición 1 no hay comunicación. Se puede quitar el error siguiendo estos pasos descritos por el Compañero @Destino :
con obdeleven ->interfaz diagnóstico de datos 19->adaptación->lista de montaje montaje teórico y ahí desactivas el reproductor media 1.
Luego borrar el fallo indefinidamente.
3) En las Mib2 (Pantalla de 6,5") en algunos casos desaparece de la pantalla la opción de conexión por Mirrorlink.
Para solucionarlo:
Con OBDeleven :
Modulo 5F
- Vehicle configuration -- Opciones
----- Mirror_link -- (Function off_HMI off)
Cambiarlo a Function On_HMI On
Si no os deja cambiarlo, entramos a Cambiar sesión dentro de la 5F y cambiamos a Modo desarrollador.
Cuando aparezca de nuevo en pantalla, reiniciar el Infotainment para que lea los parámetros nuevos.
Con VAgCom
Modulo 5F
Adaptations menu
Vehicle Configuration
Buscar Mirrorlink y cambiar el valor de 0 a 1
4) En las Mib2 (Pantalla de 6,5") en algunos casos desaparece de la pantalla la opción de conexión por Carplay.
Para solucionarlo:
Con OBDeleven :
Modulo 5F
----- Apple DIO -- On
Con VAgCom
Modulo 5F
Adaptations menu
Buscar Apple y cambiar el valor de 0 a 1
5) En las Mib2 (Pantalla de 6,5") No conocemos ningún caso , pero si os desapareciese el Android Auto de la pantalla.
Para solucionarlo:
Con OBDeleven :
Modulo 5F
----- Google GAL -- On
Con VAgCom
Modulo 5F
Adaptations menu
Buscar Google y cambiar el valor de 0 a 1
OTROS FALLOS Y ERRORES
Si ves que la figura de tu coche en la sección CAR no se ajusta a lo que deberia de salir (Otro formato de coche) y además en la sección SETUP del climatizador no te aparece el gráfico o en el OPS.
Lo puedes solucionar de la siguiente manera:
En el módulo 08:
Codificación Modo Texto
Derivado del vehiculo --- (Cambiar a OFFROAD)
Techo ---- (Cambiar a Panorámico)
Luego en el módulo 5f
Car_derivate --- (Cambiar a 2)
Resetear ajustes de System y Car y reiniciar el Infotainment.
Esto es para un modelo ST, para otros probar otras combinaciones.
A TENER EN CUENTA
En esta versión el comportamiento de las fuentes conectadas es diferente a como lo conocemos.
Ahora simplemente, al conectar el dispositivo te ofrecerá las opciones disponibles con respecto a tu telefono.
Por defecto aparece Android Auto y las opciones del Mirrorlink están desactivadas hasta que conectes un movil compatible con Mirrorlink.
¿Que versiones se pueden actualizar?
1) Coches con pantalla de 5,8" con HARDWARE : H041 y SOFTWARE : 0425 (Actualizar a la 0480)
2) Coches con pantalla de 6.5" con HARDWARE : H024 y SOFTWARE : 0245 (Primero actualizar a 0330 y luego a la 0346)
IMPORTANTE
1) Las actualizaciones vienen tardando en torno a los 30 minutos cada una si la tarjeta SD es Class 10, en tarjetas mas antiguas tardará bastante más.
2) Puedes intentar actualizar desde un USB pero no siempre funciona, los USB son un poco conflictivos en muchos casos, por marca, chip, etc. No pasa nada si no actualiza, simplemente te dirá que no puede leer los datos.
3) Si al intentar actualizar con una SD, te da error de datos, algo has hecho mal. Formatea de nuevo la tarjeta o cambia de tarjeta.
Durante la actualización:
1) No quitar el contacto del coche, ni apagar el Infotainment.
2) No arrancar el motor durante la Actualización.(Puedes tenerlo arrancado antes de empezar, pero no lo arranques si ya empezó a actualizar)
3) Bajo ningún concepto debes utilizar consumidores del coche (Calefacción, aire acondicionado,OBDII, Conexiones Bluetooth,etc, etc). EVITA RIESGOS INNECESARIOS. Las actualizaciones son una cosa seria, no andes trasteando en el coche, si hace frio, te abrigas o busca otro momento.
Si no eres capaz de seguir estas pautas, es mejor que no hagas la actualización.
4) Si consideras que no quieres arriesgarte a quedarte bajo de batería, conecta un cargador de batería antes de iniciar el proceso y mantener encendido hasta que finalice.
Ojo a como conectais el cargador: Positivo del cargador al borne positivo de la bateria y pinza negativa del cargador a la pletina que hay encima de la bateria atornillada al chasis (NO CONECTAR AL BORNE NEGATIVO O TE CARGAS EL CONTROLADOR DE CARGA DE LA BATERIA)
No me hago responsable del mal uso de estos archivos, cada cual que considere si quiere, si debe realizar las actualizaciones bajo su responsabilidad.
Todo está explicado:
Miras tu versión en tu infotainment y miras en este post si es compatible con las actualizaciones.
Aquí podeis ver el proceso de actualización desde la 330 a la 346 :
[ Video ]
Las descargas van a estar disponibles durante un tiempo prudencial, el suficiente para que se puedan descargar con tranquilidad y no tenga sentido comerciar con ellas.
Aquellos que hagais las actualizaciones podeis reportar los cambios apreciables, rapidez, comportamiento, solución de errores anteriores, etc, etc para que sirvan de guia a los que vengan empujando.
Este post se irá actualizando con los resultados que vayamos obteniendo y las soluciones que se encuentren en cada caso.
Hola a todos, un curioso, pero el valor a poner en el segundo campo de la calculadora xor es C9D2 o C92D ?
Porque en el video se encuentra uno en el descifrado es otro
Gracias de antemano
buffer
buffer
Notapor nitromania el 13 Sep 2017, 16:18
gracias aprietatuercas haber si lo averiguo, ya saber el por que quiero averiguar y poner el infotainment con su configuracion
nitromania
Notapor buffer el 13 Sep 2017, 17:34
Carpeta: powerc
Carpeta: mainplus
Carpeta: main
Carpeta: DUW014
Carpeta: DUW013
Carpeta: DUE410
Carpeta: DUE409
Carpeta: DUE406
Carpeta: DUE405
Carpeta: cpuplus
Carpeta: cpu
Carpeta: bluetooth
Carpeta: powerc
Carpeta: mainplus
Carpeta: main
Carpeta: DUW070
Carpeta: DUW069
Carpeta: DUW013
Carpeta: DUW014
Carpeta: DUE410
Carpeta: DUE409
Carpeta: DUE406
Carpeta: DUE405
Carpeta: cpuplus
Carpeta: cpu
Carpeta: bluetooth
[ Video ]
Entramos en la 5F
Adaptaciones
Le damos a XOR.
Para solucionarlo:
Con OBDeleven :
Modulo 5F
Con VAgCom
Modulo 5F
Adaptations menu
Para solucionarlo:
Con OBDeleven :
Modulo 5F
Con VAgCom
Modulo 5F
Adaptations menu
Para solucionarlo:
Con OBDeleven :
Modulo 5F
Con VAgCom
Modulo 5F
Adaptations menu
En el módulo 08:
A TENER EN CUENTA
IMPORTANTE
[ Video ]
Hola amigos,tengo mib2 y me equivoco 1555, para resolverlo es el mismo procedimiento que mib1?
Para mí, odbeleven dice clave 3315
buffer
buffer
Notapor Pedrost el 18 Sep 2017, 13:21
No hace falta que copies todo el hilo para hacer una pregunta, sino esto se hace eterno. Tú mísmo te has contestado esta todo ahí
[ Video ]
Entramos en la 5F
Adaptaciones
Le damos a XOR.
Aunque ahora con culo(st) desde 2003 enamorado de la fiera de seat :enamorado:
Se agradece dándole al :ok:
Pedrost
Agradecido: 281 veces
Notapor Fustodio el 21 Sep 2017, 07:34
jony83 escribió:
tevaadarelsol escribió:
aprietatuercas1974 escribió:
stewei escribió:
aprietatuercas1974 escribió:siento deciros que no espereis la actualizacion para esas versiones y os explico el motivo
la version de hardware que teneis es la 24 y la version de firmware mas moderna que soporta ese hw es la 0346,y esa precisamente es una version beta no publica para los coches de calle.
Por lo tanto esa actualizacion no os la pondran nunca en concesionario.
a partir de hw 30 ,si os fijais ya son los que salen con la nueva interfaz de mosaico
@aprietatuercas1974 Pues siento discrepar.... pero yo tengo Hw 42 y no me sale la interfaz de mosaico...
P.D.: y Sw 319.
Un saludo :ok:
Me extraña bastante,porque incluso con coches nuevos fabricados este mes el hw mas alto en las std es el 30 y el firmware el 0355 o 0358 creo.
Creo que ese debe de ser una high con full link o mirrorlink,y en esas unidades la primera version que tenia el menu de mosaicos es la 0674 o puede que en la 0355,esa no estoy seguro al 100%
Yo tengo la high con hw 50 y sw 355 y sin mosaico
en unidades std sin disco duro son hw 30 para poder actualizar las unidades para la apariencia de ateca
std:
hw 24 solo actualizable hasta la version 0346 apariencia de ateca pero no es un firmware publico y tiene algun bug pequeño
hw 30 viene desde la version 0351,0355 y 0358 creo recordar son firmwares publicos y que to sepa salvo algun problema puntual no tienen bugs conocidos
las high no se exactamente el hw que tienen pero por lo que comentais estan con hw 50,y firmware 355 esas son con full link,hay gente que tiene hw menor y firmware 0123 con mirrorlink solo,y han podido actualizar a la version 0674,ese es el primero que llevan con version de mosaico y menu de ateca.
Todas la high se pueden actualizar directamente al firmware que queramos,ahora incluso ha salido uno que no esta aun en ningun vehiculo que es el 0818 y 0897
si quereis saber algo mas os informare encantado
@aprietatuercas1974, a mí me interesaría saber qué bugs tiene la 0346...
Sent from my Nexus 5 using Tapatalk
+1
Me lo apunto :mrgreen:
:rey: :rey: :rey: :rey: :rey: :rey: :rey: :rey: :rey: :rey: :rey: :rey: :rey: :rey: :rey: :rey: :rey: :rey:
Fustodio
Notapor Fustodio el 21 Sep 2017, 14:34
Tanto ruido para poder seleccionar el tipo de menú principal? o esas actualizaciones llevan algo más? :cafe:
Fustodio
Notapor Valerofr150 el 21 Sep 2017, 18:46
Fustodio escribió:Tanto ruido para poder seleccionar el tipo de menú principal? o esas actualizaciones llevan algo más? :cafe:
Lee bien el hilo, esta todo explicado, mejoras de rendimiento en cuanto a rapidez, seleccion de menu estilo como el Ateca y si dispones de Seat Drive Profile tambien cambia ese submenu. Saludos !
Enviado desde mi GT-I9505 mediante Tapatalk
Valerofr150
Notapor jasoriab el 21 Sep 2017, 19:15
He detectado un bug en mi Infotainment de 8" (HW 41/SW 0462)
Consiste en que si arranco el coche con la vista Sport, con los tres relojes (suelo llevar presión de turbo, temperatura de aceite y temperatura de agua) a veces las 'agujas' de los relojes no se mueven, al subir las temperaturas o actuar el turbo.
Los valores numéricos que aparecen en el centro de los relojes sí se actualizan correctamente, pero las agujas están clavadas en la posición de las 6.
Al cambiar la vista a otra cualquiera (cronómetro u otra de las que aparecen en el menú) y vuelvo a la de los relojes las agujas ya empiezan a marcar correctamente los valores.
¿A alguno más os pasa? ¿Habrá firmware nuevo para mi unidad que resuelva dicho bug?
jasoriab
Agradecido: 2053 veces
Notapor dmesanun el 21 Sep 2017, 19:27
jasoriab escribió:He detectado un bug en mi Infotainment de 8" (HW 41/SW 0462)
Hola
Yo también encontré otro que falsea los datos de consumo medio
viewtopic.php?f=40&t=122880
dmesanun
Agradecido: 197 veces
Notapor Fustodio el 21 Sep 2017, 19:33
Valerofr150 escribió:Lee bien el hilo, esta todo explicado, mejoras de rendimiento en cuanto a rapidez, seleccion de menu estilo como el Ateca y si dispones de Seat Drive Profile tambien cambia ese submenu. Saludos !
Me he leido medio hilo... :pelea: y la conclusion para mi es que si tienes un h24... te la vas ha jugar poniendo frimware beta? Solo por el menu... porque nadie ha comentado que se alegra por mejorar la fluidez del infotimet y con mas de un año de hilo.... digo yo que alguien lo abria comentado ya... en definitiva leetelo tu todo el hilo si quieres que yo ya tengo claro que para esto... no me compro una sd y un vagcom :jodete:
Desde el respeto a los que quieran actualizar.
Fustodio
Notapor Valerofr150 el 22 Sep 2017, 00:11
Venga a dormir, desde todo el respeto.
Valerofr150
Notapor jasoriab el 22 Sep 2017, 08:34
Añado un par de fotos, la primera con la pantalla Sport sin funcionarle las agujas. Para que suceda esto, hay que dejar esta pantalla activa antes de quitar el contacto, y tras arrancarlo de nuevo, no tocarla. Así se consigue que las agujas no se muevan de la posición de las 6.
Siguiente paso, cambiar de pantalla, en mi caso, le doy a siguiente abajo a la derecha, y sale la pantalla del crono:
Y al darle otra vez para que vuelva a aparecer la pantalla con los tres relojes, ya las agujas sí marcan correctamente
@aprietatuercas1974 ¿Sabes si es un bug conocido? ¿Hay algún firmware superior al 0462 para las unidades con pantalla de 8" (HW 41) ?
Última edición por jasoriab el 22 Sep 2017, 09:59, editado 1 vez en total
jasoriab
Notapor Fustodio el 22 Sep 2017, 09:51
@jasoriab tio, adjunta las fotos mejor que subirlas a un server de fotos, es que no se ven.... :rezar:
Fustodio
Notapor jasoriab el 22 Sep 2017, 10:07
Fustodio escribió:@jasoriab tio, adjunta las fotos mejor que subirlas a un server de fotos, es que no se ven.... :rezar:
Solucionado, ya se tendrían que ver todas...
jasoriab
