León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor javigody el 12 Nov 2017, 00:10
kocki escribió:
javigody escribió:
kocki escribió:
stewei escribió:
lafu1988 escribió:
stewei escribió:No sé realmente como lo habéis hecho (me refiero al procedimiento de actualizar), pero a mi al menos si me aparecen las flechas que indican la dirección del aire y eso.
- Unidad 08 (aire acondicionado): HW H04 // SW 0911.
- Unidad 5F (electrónica de información): HW H42 // SW 0897.
Yo llevo esa combinación. ¿Cuál es la vuestra @carlosgzlez @lafu1988?
Segun mi copia de seguridad que subí al foro tengo...
Climatronic:
Número de software: 5F0907044H Versión de software: 0911
Número de hardware: 5F0907044H Versión de Hardware: H04
Y en la 5F tengo H24 y S346 que actualicé como se dice en el foro todos los pasos y se realizó todo con éxito. Quité los errores de actualización y volví activar la opción de mirrorlink pero las flechas del clima no se si se borraron al actualizar o después porque como no uso mucho esa pantalla...
Gracias y saludos
@lafu1988 Yo creo que una parte muy importante de la actualización es cuando, una vez finalizada la actualización, pide que se conecte la maquina de diagnosis para COMPARACION. Yo al menos cuando actualicé, cuando me salió esa pantalla no le di a cancelar y luego hice los pasos de eliminar el error. NO. Lo que hice fue conectar el OBDEleven, meterle los códigos según la calculadora XOR en el campo correspondiente y automáticamente la pantalla dio un mensaje que ponía "Comparación de la versión finalizada. Software actualizado", y abajo a la derecha el botón de "reiniciar".
Siguiendo esos pasos, no he tenido ningún tipo de problema (como ya comenté mis impresiones cuando actualicé). A continuación os pongo unas fotos que le acabo de hacer a la pantalla de Setup del climatizador:
Aquí muestra las flechas en rojo:
Aquí, al bajar la temperatura, cambian a color azul:
Si necesitáis alguna pregunta y os puedo ayudar aquí estoy. Pero creo que el próximo que actualice su unidad (ya sea una High o una H24) cuando le salga la pantalla de conectar la maquina de diagnosis debería de probar a hacer lo de conectarle el OBD y ponerle el código que le corresponda, y no darle a cancelar y después quitarle el error.
Un saludo :ok:
Después de actualizar la unidad (la mia es de 6,5" con mirrorlink y sin navi), al darle a la tecla Setup del climatizador, me aparece arriba en la pantalla las temperaturas y todo lo demás, pero no me aparece la imagen del salpicadero con las salidas de aire, en esa parte está en negro.
¿Sabrías como poner la imagen del salpicadero con lo de las salidas de aire? Con OBDEleven, creo que va a ser tocando algo ahi, porque todo lo demás funciona, sólo me falta la imagen.
Quizás debas actualizar la unidad del climatizador.
Enviado desde mi SM-G950F mediante Tapatalk
Para eso ¿tengo que pedir cita en el concesionario? La verdad es que no se cómo se actualiza la unidad del climatizador.
Si eres de Málaga o cerca te puedo ayudar
SEAT León MK3 FR 1.4 TSI 150CV ACT
Instalador en Málaga -> VIM, bricos MK3, tempomat MK1 y más
--- ¡Colabora con nosotros y con la comunidad con tus backups de OBDeleven/Vagcom/VCDS en el siguiente enlace!: viewtopic.php?f=8&t=120732 ¡Gracias!---
javigody
Agradecido: 274 veces
Notapor miceor el 12 Nov 2017, 00:27
Lo del climatizador no hace falta actualizar nada.
Está especificado en el post de las actualizaciones los pasos a seguir en caso de perder la visualización en pantalla.
OTROS FALLOS Y ERRORES
Si ves que la figura de tu coche en la sección CAR no se ajusta a lo que deberia de salir (Otro formato de coche) y además en la sección SETUP del climatizador no te aparece el gráfico o en el OPS.
Lo puedes solucionar de la siguiente manera:
En el módulo 08:
Codificación Modo Texto
Derivado del vehiculo --- (Cambiar a OFFROAD)
Techo ---- (Cambiar a Panorámico)
Luego en el módulo 5f
Car_derivate --- (Cambiar a 2)
ESTO UNICAMENTE EN EL CASO DE QUE ADEMAS LA IMAGEN DEL COCHE EN CAR NO SEA EL DE TU COCHE
Resetear ajustes de System y Car y reiniciar el Infotainment.
Esto es para un modelo ST, para otros probar otras combinaciones.
miceor
Agradecido: 1259 veces
Notapor tevaadarelsol el 12 Nov 2017, 00:36
miceor escribió:Lo del climatizador no hace falta actualizar nada.
En el módulo 08:
@miceor, con esto se podría conseguir que el coche del infotainment salga con techo solar? Mi coche lo lleva, pero hace un tiempo estuve probando estás opciones y no conseguí que el dibujo de la pantalla saliese el coche con techo...
Sent from my Moto G (5S) Plus using Tapatalk
tevaadarelsol
Agradecido: 200 veces
Notapor miceor el 12 Nov 2017, 00:40
Me temo que no. Hay unas imagenes limitadas predefinidas.
En los MY17 y 18 están ampliadas y se pueden sacar los colores del coche, pero ya los detalles como techo, llantas diferentes y componentes detallados creo que tampoco aparecen.
miceor
Notapor tevaadarelsol el 12 Nov 2017, 00:53
Vale, mi duda venía por la codificación del climatizador de techo panorámico... Aunque si no tiene nada que ver, qué tiene que ver esa codificación con el modelo a mostrar?
tevaadarelsol
Notapor kocki el 12 Nov 2017, 09:29
davidz800e escribió:Bueno señores, muchas gracias a todos los que hacen posible que gente que no tiene conocimientos en estos temas podamos llegar a actualizar e ir aprendiendo, acabo de actualizar a la 346 y todo genial, los únicos fallos percibidos han sido la versión de carrocería en el menú car y la visualización del setup del clima, todo solucionado siguiendo las pautas del post, ya están todos los fallos de la 5f borrados y todo ok, un saludo!
Enviado desde mi Aquaris E5 mediante Tapatalk
¿Podrías decirme cómo solucionaste lo del clima? Es que a mí el coche en el menú car,
me sale bien.
kocki
Agradecido: 26 veces
Notapor kocki el 12 Nov 2017, 09:34
En el módulo 08:
A mí en el menú car me sale el coche que es, incluso el color, donde no me aparece imagen es donde el climatizador, me salen los números y puedo cambiar temperaturas, pero no tengo imagen del salpicadero.
kocki
Notapor miceor el 12 Nov 2017, 09:46
Pues realiza los cambios marcados en negrita.
miceor
Notapor fifi49 el 21 Nov 2017, 22:43
Hello, my name is Pierre, i comme from France, i sorry i haven't spoken Spanish for a while :oops:
I would like to have informations about full link and update the software
I have a Leon from january of 2015. I have mirror link MIB2 with HHD
SW : 041
LW : 0123
part nb : 5f0035043
Is it possible to uptade my MIB2 to get the full link, i have read this post but idon't find information with my sofware number.
Thanks a lot
fifi49
Notapor Route el 24 Nov 2017, 09:02
En el módulo 08:
Para entrar en modo texto es en obd o en vag?
Route
Coche: Leon MK3 1.5 TGI 130cv
Notapor cvillajos el 24 Nov 2017, 11:40
En el módulo 08:
Con ambos puedes codificar en modo texto (bits/bytes).
cvillajos
Agradecido: 3612 veces
Notapor kocki el 25 Nov 2017, 04:18
miceor escribió:Pues realiza los cambios marcados en negrita.
Ya realicé los cambios que estaban en negrita,restablecí los datos de fábrica y reinicié el infoentretaimemt, pues la imagen del salpicadero sigue sin salir, por lo demás en menú car me sale la imagen bien, ¿Alguna idea, de por qué no muestra la imagen en la pantalla al darle a la tecla setup del climatizador?
Por cierto, la imagen en car, me sigue saliendo bien.
En el módulo 08:
Lo de resetear los ajustes de car y reiniciar el infotainment, lo he hecho, pero lo de "resetear ajustes del System" ¿cómo hago eso?
Última edición por kocki el 25 Nov 2017, 11:19, editado 2 veces en total
kocki
Notapor Luisete86 el 25 Nov 2017, 07:22
Hice la primera revision de los dos años y le pregunte por la actualizacion del software y me dijo que no había, que sino le hubiera salido al hacer el chequeo :S
Luisete86
Agradecido: 34 veces
Notapor KikeBG el 03 Dic 2017, 13:36
fifi49 escribió:Hello, my name is Pierre, i comme from France, i sorry i haven't spoken Spanish for a while :oops:
SW : 041
LW : 0123
part nb : 5f0035043
Thanks a lot
Hello Pierre. It is not possible to upgrade to full link in cars manufactured before May 2015. You have to change the screen and the module. I know a person who does it for € 2000
KikeBG
Notapor [GuErRa] el 08 Dic 2017, 11:33
Tres días leyéndome todo el post. Increíble la cantidad de info que sacáis. Por lo que he entendido, los que tenemos HW30 tenemos que ir si o si al taller y lo actualizarán si quieren no? Yo tengo la SW 0351 y he leído por aqui compañeros que tienen la 0359. Es correcto no?
[GuErRa]
