León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor Pynzeta el 08 Dic 2017, 14:08
[GuErRa] escribió:Tres días leyéndome todo el post. Increíble la cantidad de info que sacáis. Por lo que he entendido, los que tenemos HW30 tenemos que ir si o si al taller y lo actualizarán si quieren no? Yo tengo la SW 0351 y he leído por aqui compañeros que tienen la 0359. Es correcto no?
Cojo sitio...
Pynzeta
Agradecido: 118 veces
Notapor kocki el 08 Dic 2017, 15:13
miceor escribió:Lo del climatizador no hace falta actualizar nada.
Está especificado en el post de las actualizaciones los pasos a seguir en caso de perder la visualización en pantalla.
OTROS FALLOS Y ERRORES
Si ves que la figura de tu coche en la sección CAR no se ajusta a lo que deberia de salir (Otro formato de coche) y además en la sección SETUP del climatizador no te aparece el gráfico o en el OPS.
Lo puedes solucionar de la siguiente manera:
En el módulo 08:
Codificación Modo Texto
Derivado del vehiculo --- (Cambiar a OFFROAD)
Techo ---- (Cambiar a Panorámico)
Luego en el módulo 5f
Car_derivate --- (Cambiar a 2)
ESTO UNICAMENTE EN EL CASO DE QUE ADEMAS LA IMAGEN DEL COCHE EN CAR NO SEA EL DE TU COCHE
Resetear ajustes de System y Car y reiniciar el Infotainment.
Esto es para un modelo ST, para otros probar otras combinaciones.
He hecho todo como está descrito arriba y efectivamente, me aparece la imagen del salpicadero en la pantalla al darle a la tecla setup del climatizador, pero... en el menú car, me aparece una ranchera, he cambiado en el módulo 5F varios numeros en car derivate y si pongo el 1, me aparece mi coche en el menú car, pero me desaparece la imagen del climatizador en la pantalla.
Alguien que le aparezca el coche de 5 puertas en el menú car y haya conseguido poner la imagen del climatizador con ese coche, podría mandarme una captura de pantalla o poner aqui la codificación, es que he probado un montón de cosas y si me aparece el coche bien, me desaparece el salpicadero en la pantalla (setup del climatizador) y viceversa...
A ver si alguien me puede ayudar con la codificación.
kocki
Agradecido: 26 veces
Notapor flotter el 08 Dic 2017, 17:53
Buenas
Como codificar para que salga la información Sport en un info 6.5 gen 2?? Al igual que codifique el off road imagino que este se podrá también
SEAT TOLEDO MK4 1.6 TDI
flotter
Coche: Leon MK2 2.0 16v 140cv
Notapor aigort el 08 Dic 2017, 17:54
flotter escribió:Buenas
No se puede configurar. Es necesario código SWAP
Enviado desde mi MI NOTE LTE mediante Tapatalk
aigort
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 52 veces
Notapor jairin13 el 08 Dic 2017, 17:56
Bueno gracias a @stewei tengo mi infotaiment actualizado también. Recomendable le da otra visión en el menú principal muy chula. 0 problemas.
jairin13
Notapor flotter el 08 Dic 2017, 17:57
Quieres decir que si pagas en seat te dan un código lo metes en el navi y listo no ?? Sabéis si cuesta mucho???
Un saludo y gracias
flotter
Notapor aigort el 08 Dic 2017, 18:35
Un saludo y gracias
No , por que no está a la venta en recambios.
aigort
Notapor Adlon el 10 Dic 2017, 01:24
hi,
whats up?
can anyone please reupload the MIB 1GEN 5,8 first file?
the second one is availiable for download but the first one is down
thanks a lot
Adlon
Notapor balbu el 13 Dic 2017, 21:19
Tengo el hardware h30 con software 0351. Puedo actualizar con la versión que hay en la página 41 agrego foto para que se vea mejor
balbu
Notapor Pynzeta el 14 Dic 2017, 09:56
balbu escribió:Tengo el hardware h30 con software 0351. Puedo actualizar con la versión que hay en la página 41 agrego foto para que se vea mejor
estoy exactamente el la misma posicion... a ver si @aprietatuercas1974 no arroja algo mas de luz...
Pynzeta
Notapor Juande667 el 14 Dic 2017, 13:20
N
Seat Leon 1M 1.9 TDI 90 CV Stella ALH ._] Funcionando[_.
Seat Leon MK3 2.0 TDI CR 150CV FR Advanced ._] Gozando [_. --->Galería<---
Juande667
Agradecido: 22 veces
Notapor Igor el 14 Dic 2017, 20:06
Buenas me entregaron el coche el lunes con la pantalla de 8 pulgadas y tiene infotainmet h41 con software 0468 como puedo actualizar a la 0818.gracias igual aprietatuercas me podría orientar . Gracias.
Igor
Notapor warcryrivas el 16 Dic 2017, 12:59
Igor escribió:Buenas me entregaron el coche el lunes con la pantalla de 8 pulgadas y tiene infotainmet h41 con software 0468 como puedo actualizar a la 0818.gracias igual aprietatuercas me podría orientar . Gracias.
Yo estoy igual, la única solución que he encontrado es llevar el coche a la seat, y dejarlo para que lo actualicen, pero vamos que seguro segurísimo que tiene que haber una opcion de bajarse la actualización, además el propio infotaiment te indica como actualizarlo, vamos como las Tv....
warcryrivas
Notapor Igor el 16 Dic 2017, 13:53
Yo he preguntado en el conce y tenemos que mirarlo haber.....
Así que si quieren pueden hacerlo pero bueno veremos si se animan a actualizarlo. Y si en el propio infotainmet cuando miras las versión que tienes en la esquina izquierda pone actualizar yo le he dado y pone que necesita datos no se si con los datos del teléfono le valdría para actualizar o si luego pedirá algo más.
Igor
Notapor warcryrivas el 17 Dic 2017, 23:24
Pone actualizar, pero no se puede mediante internet, las opciones con meter un usb o una Sd con el archivo y lo reconoce, el problema es que no sabemos de donde se bajan esos archivos.
warcryrivas
