León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor Helrique el 18 Dic 2017, 11:36
miceor escribió:Bueno, pues os pongo algunas actualizaciones QUE HE ENCONTRADO DE CASUALIDAD para Mib1 y Mib2.
Mib1 - Pantalla de 5.8"
Versión de la actualización : 0480 (Ultima versión compatible con el dispositivo)
Equipos compatibles con esta actualización : MIB 1GEN 5,8" con HW:041 FW:0425
Descargar el archivo desde:
Drive--- https://drive.google.com/open?id=0BxJGznK3NRXVRGRFWlJwaDhjNlU
Descomprimir el archivo. La estructura final debe quedar de la siguiente forma:
Carpeta: SEAT_NAV_SSB
Carpeta: SEAT_PLUS_SSB
Archivo: metainfo2.txt
Copiar las dos carpetas y el archivo en una tarjeta SD Class 10 de 8 GB (Si usais una tarjeta lenta, la actualización se puede eternizar, con la Class 10 tarda unos 40 minutos)
Hola, gracias por aceptarme en esta casa.
Quiero saber si puedo actualizar esta versión en mi coche Seat Leon ST1.6 TDI CR Style Ecomotive (5F8) de mayo de 2014.
Agradezco ayuda,
muchas gracias.
Helrique
Helrique
Notapor stewei el 20 Dic 2017, 10:48
warcryrivas escribió:
Igor escribió:Buenas me entregaron el coche el lunes con la pantalla de 8 pulgadas y tiene infotainmet h41 con software 0468 como puedo actualizar a la 0818.gracias igual aprietatuercas me podría orientar . Gracias.
Yo estoy igual, la única solución que he encontrado es llevar el coche a la seat, y dejarlo para que lo actualicen, pero vamos que seguro segurísimo que tiene que haber una opcion de bajarse la actualización, además el propio infotaiment te indica como actualizarlo, vamos como las Tv....
@warcryrivas @Igor ¿Qué referencia de unidad 5F teneis cada uno? ¿Son navi sistema plus? ¿navi normal?
stewei
Agradecido: 465 veces
Notapor jasoriab el 20 Dic 2017, 11:10
@Igor, ¿dónde has visto que esté disponible esa versión para la unidad H41? Mi coche monta la misma revisión de HW, con la versión de SW 0462, siendo de julio de este año.
¿Montas DCC? Te lo pregunto para averiguar si con esa revisión de SW han corregido el problema con las agujas de los relojes en la pantalla de SportHMI
@stewei Yo monto el navi normal, con la misma versión HW.
jasoriab
Agradecido: 2055 veces
Notapor warcryrivas el 20 Dic 2017, 11:14
Yo no tengo navegador
De infotaiment tengo la del leon My18
Número de pieza del dispositivo : 5QA035824B
Hardware: H41
Software: 0468
Codec Media: 4101.0.0.0
Bluetooth versión: C300
Full Link: 4101.438.1.5
Radio database versión: 1.9.4
USB surfstick versión: 4101.438.1.4
warcryrivas
Notapor cuenka16 el 20 Dic 2017, 11:21
Yo les acabo de decir que si me actualizaban de la 468 a la 818 y me han dicho que las actualizaciones es solo para los que fallan y que me peinase para el otro lado
Enviado desde mi Redmi Note 3 mediante Tapatalk
cuenka16
Notapor Igor el 20 Dic 2017, 13:06
Yo tengo lo mismo que warcryrivas.
Igor
Notapor stewei el 20 Dic 2017, 13:19
Pues entonces lamento deciros que yo, al menos, no os puedo ayudar con dichas versiones... :(
Un saludo :ok:
stewei
Notapor jasoriab el 29 Dic 2017, 12:54
Acabo de venir del concesionario. Le hes consultado el problema que tengo con las agujas de los relojes del modo sport, que consiste en que si apago el coche en esa pantalla, y vuelvo a arrancarlo se mantiene la pantalla de los relojes, se van actualizando los numeros que hay en el centro de ellos (temperatura y presión del turbo llevo) pero ninguna de las tres agujas no se mueven, quedan 'clavadas' en las posición de las 6
Para solucionarlo, basta con cambiar a otra pantalla y volver a la anterior de los relojes, para que las agujas se muevan correctamente...
Pues resulta, que según mi numero de bastidor, no hay actualizaciones pendientes para el coche (es de julio 2018), teniendo en el infotainment la versión de firmware 462 HW 41, y en unos mensajes anteriores, dos compañeros montan el mismo HW 41, pero con firmware 468
La consulta la han realizado metiendo el número de bastidor en su ordenador, no sé si ese es el procedimiento correcto, o me han dado largas... :cry: :cry:
@aprietatuercas1974 ¿sería posible que lo consultaras si te paso por privado el número de bastidor de mi coche? ¿Te suena alguna nota o correo con dicho error?
¡¡ Muchas gracias por adelantado!!
jasoriab
Notapor aprietatuercas1974 el 29 Dic 2017, 13:05
Buenas,que versuion de hw y de software ademas de referencia de equipo es el tuyo y el otro que comentas.
Con lo que refieres a el bastidor,por desgarcia las actualizaciones del infotaiment se realizan con una sd,y al no ser que exista una nota tecnica con un problema no habra actualizacion por parte de seat.
aprietatuercas1974
Agradecido: 358 veces
Notapor jasoriab el 29 Dic 2017, 13:41
aprietatuercas1974 escribió:Buenas,que versuion de hw y de software ademas de referencia de equipo es el tuyo y el otro que comentas.
Sí, por supuesto, estos son los datos del mío
Nº de pieza del dispositivo: 5QA035846B (con navegador)
Hardware: H41
Software: 0462
Y el de @warcryrivas, (mensaje del 20 de diciembre, en este mismo hilo)
Número de pieza del dispositivo : 5QA035824B (sin navegador)
Hardware: H41
Software: 0468
Sí, he leído que las actualizaciones hay que hacerlas por SD ya que la imagen del firmware ocupa varios gigas, pero pensaba que metiendo el bastidor del coche, debería aparecer si hay alguna actualización disponible
Jose
jasoriab
Notapor Helrique el 30 Dic 2017, 10:48
Hello, I did the upgrade but did not clear the error:
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 121989 km
Date: 2017.12.29
Time: 20:46:52
Voltage terminal 30: 12.0 V
How to solve?
Thank you for your help.
Thank you.
Helrique
Notapor mams69 el 30 Dic 2017, 12:25
Estoy un poco perdido.
Que version es la ultima que hay para el en System Plus (con HDD)?
Y donde puedo ver la que yo tengo.
Muchas gracias.
mams69
Notapor Helrique el 30 Dic 2017, 19:59
Hola, después de la referida actualización (Mib 1 - Pantalla de 5.8 ") quedó con el error abajo.
He borrado con VagCom, pero siempre aparece.
Saben cuál es la solución?
Agradezco que me ayuden a resolver. Gracias.
Error:
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5F0 035 846 A HW: 5F0 035 846 A
Component: MU-S-N-ER 040 0480
Serial number: E1F00104142639
Coding: 04730301D70A000021110001000800002F0106040100010046
Shop #: WSC 00049 770 00124
ASAM Dataset: EV_MUStd6C1PASE 002030
ROD: EV_MUStd6C1PASE_VW37.rod
VCID: 264390BD59369E7195-8072
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H60 0032
Serial number: SEZ8Z9PT9007N9
1 Fault Found:
B201A 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 8
Mileage: 122031 km
Date: 2017.12.30
Time: 13:21:29
Voltage terminal 30: 12.3 V
PrtSc:
Helrique
Notapor cvillajos el 31 Dic 2017, 06:10
Helrique escribió:Hello, I did the upgrade but did not clear the error:
1 Fault Found:
B201A 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 121989 km
Date: 2017.12.29
Time: 20:46:52
How to solve?
Thank you.
You have the solution explained on page 41. Search for it.
Regards!!
cvillajos
Agradecido: 3613 veces
Notapor KiHoX el 02 Ene 2018, 17:39
Llevé mi coche a la Seat de Alcobendas porque 5 de cada 10 veces, cuando arranco el coche el infotainment se me reinicia y el mecanico me dijo que era un comportamiento normal y que no me lo iba a actualizar. :(
Última edición por KiHoX el 05 Ene 2018, 11:55, editado 1 vez en total
KiHoX
Problema con aire acondicionado León fr mk1 !!
Foro: Leon I - Mecánica / Electricidad / Electrónica
Autor: Paranohia
Respuestas: 33
Tengo un Leon
Foro: Presentaciones
Autor: Timoteo
Respuestas: 2
León MK4 1.5 e-Hybrid 204cv
Autor: javiernick
Respuestas: 4
Hilo del León mkIV e-hybrid
Foro: General
Autor: vkr84
Respuestas: 658
RUIDOS en el Nuevo Leon MK4
Autor: Tik0
Respuestas: 424
