León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor genialsoft el 06 Sep 2016, 18:01
noxon escribió:Una cosa que no me queda clara... El un león st, hace falta el relé? O solo coger corriente del mechero + marcha atrás?
Ninguna de las dos cosas. conecta la cámara directamente a la marcha atrás y sube la intensidad de la luz (esta explicado en el hilo) y ya lo tienes.
Enviado desde mi S6-Edge
genialsoft
Agradecido: 346 veces
Notapor cvillajos el 06 Sep 2016, 19:21
O coger la corriente del mechero también vale (no hace falta para nada la marcha atrás y subir su intensidad).
cvillajos
Agradecido: 3612 veces
Notapor er_trompe el 06 Sep 2016, 19:24
@cvillajos si coge la corriente del mechero, la camara está siempre encendida lo que mermará su tiempo de vida a no ser que ponga un relé y para lo cual hace falta coger la señal de la marcha atrás. Para evitar comprar e instalar un relé, que pruebe primero con la corriente de la marcha atrás directamente, subiendo el valor de esta a 127 con vagcom, y si así no funciona que todo puede pasar, entonces ya que se conplique con relé y toma de mechero
Enviado desde el zapatófono
Es de bien nacido ser agradecido. Si te ha resultado útil este mensaje, dale al botoncito de gracias ;)
Antes de preguntar, escribe tu duda aqui, posiblemente ahorres tiempo y nos lo ahorres a los demás.
er_trompe
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 124 veces
Notapor marcoa el 06 Sep 2016, 19:44
Bueno señores me he metido en la aventura de la camara me he decidido por esta.
Hasta que me llegue de chinilandia tengo unas dudas puesto que me he mamado todo el tema y no me queda claro, he de decir que es para instalar en un Leon ST . Como veis me la he cogido con relé , mis dudas son bajo mi ignoracia la cual no soy instalador como mucho de vosotros comento las dudas.
camara:
cables rojo y negro conecto con el plafón de leds
1º es ovio que el cable amarillo de la camara( imagen ) va para conectarlo con el cable que preparemos para quadlock pin 6 y 12.
2ª el rojo que es alimentación de la cámara donde lo conectaría que salen del relé que esta es mi duda, el +(positivo) al cable de marcha atras y -( masa ).
3º los azules ni caso no
asi funcionaria con la codificación correspondiente y si no es así como seria porque me hago un lio con que los st la cogen del mechero ect ect .Gracias Un Salud2.
marcoa
Agradecido: 25 veces
Notapor noxon el 06 Sep 2016, 20:39
Ya se que esta todo explicado, pero llevo ya leyendo muchas paginas y cada uno lo hace de una forma.
Asique a cada pagina que voy leyendo veo que se hace de una forma, unos ponen una cosa, otros otra... es un poco lio con mas de 100 paginas y cada uno montándola de una forma.
se podría editar algún comentario de los primeros y poner todos estos nuevos pasos que están en la pagina ni se sabe.
Edito, y las cámaras que llevan 4 leds alrededor? sirven de algo o mejor las que no llevan led?
noxon
Agradecido: 35 veces
Notapor marcoa el 06 Sep 2016, 20:56
nosom +1 estoy contigo a mi me duele hasta la cabeza de ver todo el post y contra mas miro mas dudas me salen y no me queda claro, que luego no digan que si esta explicado . Mi duda es si hay que coger la tesión para alimentar a la cámara si del mechero o marcha atras en fin que no me aclaro. y antes de hacer como es lógico no quiero cortar ningún cable que no sea no vaya ha ser que la lie parda :lol: :lol:
marcoa
Notapor noxon el 06 Sep 2016, 20:59
marcoa escribió:nosom +1 estoy contigo a mi me duele hasta la cabeza de ver todo el post y contra mas miro mas dudas me salen y no me queda claro, que luego no digan que si esta explicado . Mi duda es si hay que coger la tesión para alimentar a la cámara si del mechero o marcha atras en fin que no me aclaro. y antes de hacer como es lógico no quiero cortar ningún cable que no sea no vaya ha ser que la lie parda :lol: :lol:
Si estar esta todo explicado, el caso es que cada uno lo hace al final de una manera, con lo cual en una pagina te dicen que pilles todo del mechero. en otra del la marcha atrás, en otra de los dos sitios,,, y al final es un lio de la leche. jeje
noxon
rojas escribió:Lado izquierdo , detras del guarnecido ... cuidadinnn si usas vagcom en el xperience
Que problema tienen los xperience con el vagcom?
noxon
Notapor cvillajos el 06 Sep 2016, 21:23
er_trompe escribió:@cvillajos si coge la corriente del mechero, la camara está siempre encendida lo que mermará su tiempo de vida a no ser que ponga un relé y para lo cual hace falta coger la señal de la marcha atrás. Para evitar comprar e instalar un relé, que pruebe primero con la corriente de la marcha atrás directamente, subiendo el valor de esta a 127 con vagcom, y si así no funciona que todo puede pasar, entonces ya que se conplique con relé y toma de mechero
Yo la tengo al fusible del mechero únicamente, sin relés ni condensadores (12v limpios) y no creo que le acorte la vida el llevarla encendida siempre bajo contacto. No obstante, cada uno es libre de elegir el método de instalación que mejor le parezca. Todas las alternativas e información de las mismas están en este hilo...
cvillajos
Notapor marcoa el 06 Sep 2016, 21:58
Entiendo que tu alimentas del mechero a la cámara ni cable de marcha atrás ni nada simplemente el positivo y negativo del mechero no.
marcoa
Notapor cvillajos el 06 Sep 2016, 22:01
Concretamente del fusible del mechero con un robafusibles @marcoa
cvillajos
Notapor marcoa el 06 Sep 2016, 22:07
Vale cvillajos esque yo montaría esta que tiene relé y mi duda era donde coger para alimentarla osea que no es necesario coger del cable de marcha atras con que la coga del + y - del mechero o como bien dices tu directo al fusible ya funcionaria No y como bien e entendido con el relé no estaria funcionando todo el tiempo.
marcoa
Notapor MORKAS el 06 Sep 2016, 22:32
marcoa escribió:Vale cvillajos esque yo montaría esta que tiene relé y mi duda era donde coger para alimentarla osea que no es necesario coger del cable de marcha atras con que la coga del + y - del mechero o como bien dices tu directo al fusible ya funcionaria No y como bien e entendido con el relé no estaria funcionando todo el tiempo.
Creo que ese rele no te servirá..la mia que tenia anteriirmente en el plafon..tambien llevaba. Y tuve que descartarlo
MORKAS
Agradecido: 369 veces
Notapor marcoa el 06 Sep 2016, 22:36
:shock: :shock: pues morkas si tenía dudas ahora más todavía.
marcoa
Notapor marcoa el 06 Sep 2016, 22:38
Donde la conectastes y que es lo que te paso
marcoa
