León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor Martín st el 05 Ene 2015, 23:37
Ya tengo el león, y la cámara casi controlado oleee
Martín st
Coche: Leon MK3 1.4 TSI 122cv
Agradecido: 26 veces
Notapor rojas el 06 Ene 2015, 12:13
Q bonico martin !!
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1889 veces
Notapor Martín st el 06 Ene 2015, 17:03
Gracias rojas, ahora un buen rodaje y a disfrutar
Martín st
Notapor Kampedtre el 07 Ene 2015, 09:09
rojas escribió:
Kampedtre escribió:Me surge una duda, tengo este RCA pero a esta hembra le llegan dos cables...cual pongo??
Cualquiera de.los dos
Gracias!!
Kampedtre
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 28 veces
Notapor Kampedtre el 07 Ene 2015, 19:04
Bueno, hoy me puesto al lío y me tenido que quedar a medias :(... El primer problema es el tamaño del conector de la luz de matrícula, es muy corto y para manejarte por esa zona es jodida
El siguiente problema a sido a la hora de pasar los cables, no hay ningún pasa muros en la versión ST al menos visible, y apartado moqueta y revestimientos laterales y no e podido ver nada
Así que si alguno con un ST se a animado y a podido pasar los cables, que me diga por donde y me ilumine el camino!! :D
Kampedtre
Notapor rojas el 08 Ene 2015, 11:54
prueba en las esquinas , por donde yo pase el cable de video ahi tendras un paso seguramente hasta la parte de abajo del coche. lleva alimentacion y video por ahi.
este :
Apartamos un poco la moqueta y veremos otro tetoncillo de goma como el que hemos visto antes ,justamente en el rincon
confirmanos !! :ok:
rojas
Notapor Kampedtre el 08 Ene 2015, 14:45
Luego si puedo intento desarmar de nuevo y paso foto, de todas formas pase el cable de alimentación por el agujero donde se atornilla el faro trasero, quedo bien, pero luego pensé que tenía que pasar RCA y no me cabía así que tengo que desarmar y buscar por los lateras por donde tu dices, gracias rojas!! ;)
Kampedtre
Notapor rojas el 08 Ene 2015, 17:41
Kampedtre escribió:Luego si puedo intento desarmar de nuevo y paso foto, de todas formas pase el cable de alimentación por el agujero donde se atornilla el faro trasero, quedo bien, pero luego pensé que tenía que pasar RCA y no me cabía así que tengo que desarmar y buscar por los lateras por donde tu dices, gracias rojas!! ;)
ademas , yo no quite moqueta ni nada , solo la aparte un poco con la mano
rojas
Notapor rocketboy el 08 Ene 2015, 23:41
Hola, pues no hay manera...
Lo tengo todo montado menos la cámara en el hueco de la matricula. Al final conseguir coger la corriente del mechero del maletero (masa y positivo) y lo conecté a un relé con el negro-azul de la marcha atrás y los cables de la cámara. El RCA conectado al quadlock y la codificación hecha.
Cuando meto marcha atrás ya sea en movimiento o con el contacto puesto aparece la pantalla pero no se ve nada. La luz de la cámara se enciende, pues le llega corriente.
Empiezo a pensar que la cámara no funciona. Por si acaso he encargado otra.
"Competir es vida. Cualquier cosa antes o después es sólo esperar"
Steve McQueen
rocketboy
Notapor rojas el 08 Ene 2015, 23:53
rocketboy escribió:Hola, pues no hay manera...
tienes una foto de la camara sin instalar?
para probarla ponla en la television de casa , alimentala con 12v y asi compruebas si funciona o no
de donde eres? , si estas por madrid pasate y te echo una mano
rojas
Notapor rocketboy el 09 Ene 2015, 15:13
Muchas gracias, Rojas. Soy de Barcelona y ya me hubiera gustado poder quedar contigo para ésto...
Definitivamente creo que la cámara no funciona. La he conectado a la TV y con una bateria de 12v que tenia por casa. Se enciende la luz pero no da señal ninguna a la tele.
Aqui va la foto de la cámara. Espero que llegue la otra y sea éste el problema.
De nuevo, te agradezco mucho el interés y la ayuda.
Steve McQueen
rocketboy
Notapor Kampedtre el 09 Ene 2015, 18:21
rocketboy escribió:Muchas gracias, Rojas. Soy de Barcelona y ya me hubiera gustado poder quedar contigo para ésto...
Pues es idéntica a la mía!! :O una curiosidad(que veo que lo tienes todo montado) por donde as pasado los cables para llegar al parachoque delantero?? Esque me puse y no hubo manera...
Kampedtre
Notapor Kampedtre el 09 Ene 2015, 18:22
Parachoque trasero perdón...
Kampedtre
Notapor rojas el 09 Ene 2015, 20:52
@rocketboy que se encienda la luz no tiene nada que ver , ya que es un led y lleva un circuito independiente a la camara . Entiendo que has alimentado la camara con el conector rojo el que esta pegado al de video , no?
Ten en cuenta que no suelen fallar estas camaras aunq no digo que por mala suerte no te haya tocado la china , nunca mejor dicho :mrgreen:
verifica que le llegue corriente por el conector rojo , si es necesario corta el conector y pela la punta a los cables no sea que no este haciendo buen contacto por dentro .
a ver q tal
rojas
Notapor Martín st el 10 Ene 2015, 11:01
Buenos días peña, campe como ba el tema de la cámara yo quiero empezar ya mismo, si no es mucho pedir me puedes dar el enlace de la cámara como eres de Barcelona y el tema del cable de vag com,
Bueno poco a poco cuando me ponga a realizar la intalacion ( tengo la ayuda de un crack) si te sale dudas por donde pasar el cable o la tengo yo no dudas en pedir ayuda
Gracias buena gente
PD soy del baix llobregat
Martín st
Hilo del León mkIV e-hybrid
Foro: General
Autor: vkr84
Respuestas: 667
Incidencias varias nuevo Seat Leon
Autor: ma.cantero
Respuestas: 363
LEON 1.4 TGI
Foro: General
Autor: Balilla
Respuestas: 2932
No sincroniza marcha atrás Mk3 1.5 TGI
Autor: LoOpeZ
Respuestas: 0
Reprogramacion Cupra Leon 190 cv
Foro: Preparaciones de motor / Racing
Autor: JosemaMoreno
Respuestas: 0
Usuarios navegando por este Foro: Anthropic, Facebook/Meta/ExternalAgent, Semrush y 3 invitados
