Corriente desde el fusible del mechero y solucionado
León Mk3 - BRICO - Como instalar la cámara de parking
- Seguidores: 136
- Favoritos: 46
- Vistas: 603.541
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
si te gusta ... agradece el post !!
rojas - Gurú de los leones
- Agradecido: 1888 veces
rojas escribió:Corriente desde el fusible del mechero y solucionado
Viene por el tema de que va pulsada la tensión?
Enviado desde mi PLK-L01 mediante Tapatalk
leonfito - Leoner@ avanzad@
- Agradecido: 85 veces
Si . En estos coches todas las luces van controladas por la bcm
@rojas Una pregunta, para un FR con media system plus 5,8" de junio del 2014 con navegador que cámaras puedo instalar? Las revendes tu? y luego hay que darlas de alta con el vag com no??
carlopecu - Nuev@ por aqui
Puedes poner la normal o la High... pero la High en 5.8 solo tiene líneas dinamicas . Yo no vendo las normales , las instalo solo vendo las HIGH
Rojas para empotrar las camaras high en el paragolpes hay que abrir un agujero redondo como las camaras empotradas chinas o es un hueco cuadrado??
Estoy interesado en una
Caanpulo - Leoner@ habitual
- Agradecido: 42 veces
Es cuadrado , 3x3 ... con un cuchillo se hace en un momentin
He probado a subir la intensidad de marcha atrás como se indica en una de las páginas a 127 en vez de 100 y nada, sale en negro.
Probé a mater un condensador en paralelo previo paso de un diodo para evitar que descargue hacia la marcha atrás, y tampoco funciona. Empiezo a pensar que consume demasiados mA y por eso no arranca.
En la primera prueba antes de poner el condensador, con el contacto si arrancaba y luego con el motor ya no, cuando entraba la pulsada...ahora ni eso! Quiero dejar como última opción la toma del mechero por no llevarla siempre encendida. Además que como no se lo que consume realmente tener un aparato chupando de la red no me mola.
EDITO! El robacorrientes me estaba haciendo mal contacto!! Ahora ya va sollo subiendo la intensidad pero la imagen tiene algo de parasitos, así que probaré el condensador de nuevo a ver si lo deja bien bien.
Yo he quitado todos los robacorrientes , tb me daban fallo ... un empalme bien hecho de gusanillo ... y eso no se va nunca
rojas escribió:Yo he quitado todos los robacorrientes , tb me daban fallo ... un empalme bien hecho de gusanillo ... y eso no se va nunca![]()
Jajajaja totalmente cierto! Pensaba hacer eso, pero me dio respeto cortar el cable gordo de tierra. Acabare soldando bien.
Al final he quitado el filtro y solo deje la intensidad de luz modificada en 127 como se dice en el post. Aun así algo de interferencia tengo, con o sin filtro.
Hola aver que acabo de entrar todos estos problemas que es por una cámara normal? A mi me acaba de llegar de Aliexpress y mi duda es un cable rojo que sale del rca para que sirve si los de corriente van al negativo y marcha atrás no? Y así ya debería de funcionar
felix_guti - Aun con la L
My Leon ST MI 2016 tiene Navi Plus y camara de parking instalado en fábrica.
Si quiero actualizar a la camara High lo que tengo que cambiar? Es necesario cambiar la camara o simplemente instalar una unidad de control (y el codificación con VCDS).
@rojas ¿Me puede ayudar
(lo siento mi "español" porque yo soy portugués y yo uso Google Tradutor para ayudar)
Frankesousa - Nuev@ por aqui
No te preocupes por ese cable rojo; en nuestros Leones no sirve para nada.
marlop - Gurú de los leones
- Agradecido: 1080 veces
Ok ya os comentaré si tengo más problemas graciad
León Mk4 - Actualización mapas MIB3 SEAT 2021 Foro: AudioCar y MultimediaCar Autor: jasoriab Respuestas: 121 |
Donde está la varilla del aceite? Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: vannist Respuestas: 23 |
el leon tdi 150cv tiene estabilizadora atras o no?? Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: cordobitax Respuestas: 1 |
Luces de Cortesía Retrovisores MK4 Foro: General Autor: Angeloxo77 Respuestas: 3 |
León Mk4 - Actualizaciones sistema de infotainment Foro: AudioCar y MultimediaCar Autor: Yundas Respuestas: 1757 |
Usuarios navegando por este Foro: Anthropic, ByteDance (Bytespider), Google [Bot] y 5 invitados
