León Mk3 - BRICO - Como instalar la cámara de parking
- Seguidores: 136
- Favoritos: 46
- Vistas: 595.739
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Hola aver estoy en el último paso con el ordenador activarlo no encuentro y no entiendo q e lo de stg 5f ..... Si me lo podéis esplicar
felix_guti - Aun con la L
Perdonad otra vez q soy un pesado
Pero sin Acer el último paso me funciona pero en parado bien pero arrancado me crea interferencias y se me termina apagando q me pasa? E echo el brico de la primer página
felix_guti escribió:Perdonad otra vez q soy un pesado
De donde has cojido el positivo para la camara?
Enviado desde mi SM-N9005 mediante Tapatalk
Cuando pienses que estas al limite, estaras a un 50% de llegar al mismo.
IvanMc2 - Leoner@ habitual
- Agradecido: 129 veces
IvanMc2 escribió:felix_guti escribió:Perdonad otra vez q soy un pesado
Luz de marcha atrás como en el brico
@felix_guti ,
Si no tienes sensores de aparcamiento no tendrás centralita 10.
Si coges corriente de la luz de marcha atrás la electricidad no viene limpia y tienes que poner un relé.
- Agradecido: 3610 veces
Puedes coger la corriente del fusible del mechero, del mechero del maletero si es ST... o de la luz de marcha atras y subir su valor .
si te gusta ... agradece el post !!
rojas - Gurú de los leones
- Agradecido: 1887 veces
Como subo su valos
E pedido un relé para Acer lo del relé q lo e visto en la página 3 pero si es mejor lo de subir el valor .
T refieres al valos del fusible o con van com
marcoa escribió:Hola compis haber si ha alguien mas le ha pasado lo que me ha pasado a mí. He hecho la instalación de la cámara hace unos meses todo bien pero he decidido de cambiar las bombillas de luz trasera marcha atras y intermitentes por luz leds, hay es donde viene el problema . Cambio la bombilla de luz marcha atras por una de led y al engranar la marcha atras con el motor parado todo bien , pero cuando encendi el coche![]()
me hace un ruido como a cortocircuito y la pantalla se me ve con interferencias y en negro .Ha alguien mas le ha pasado y que solucion tiene pues tube que poner la bonbilla halogena que traia. Gacias Un Salud2.
Precisamente eso me pasa a mi..pero el ruido a corto..es en el led de las puertas...que tengo el mod de luz blanca en las puertas al dar marcha atras..es posible que sea por el tipo de bombilla
MORKAS - Mi Leon me tiene miedo
- Agradecido: 369 veces
Subir las intensidades de las bombillas y cambiarlas a led
Hola tengo una nueva duda Aver voy a poner el relé y en el empalme de la luz de marcha atrás y el negativo tengo también empalmado un párking sistem universal.
Aver lo puse todo ayer a la vez en principio parece que el párking sistem va bien no como la cámara q al arrancar ace cosas raras la pantalla .
Ahora mi pregunta es que ago paso todo por el relé o solo la cámara ?
Buenas, yo cogí tensión del mechero. Es decir cuando doy el contacto la cámara está encendida. Hay alguna codificación posible para que al dar al botón de park pilot y luego dar dar al de RVC se vea la cámara sin meter la marcha atrás?
Desde el corazón de la Ribera del Duero,
marcosgumiel - Nuev@ por aqui
- Agradecido: 12 veces
rojas escribió:Por cierto , tengo una buena y una mala noticia ...
Como casi siempre elegimos la mala 1º es la que voy a decir![]()
cuando hice el brico , al terminar , probe la camara lo hice con el coche detenido en la plaza de garaje . La sorpresa me la he dado hoy al coger el coche , voy a engranar la marcha atras y se ha puesto la pantalla en negro![]()
la buena noticia es que tiene solucion ademas de rapido no es nada complicado :
Bien , se me vino a la cabeza rapidamente el jodio relé ( en los coches modernos con linea canbus todo los positivos que salen de la red de abordo la señal no es de 12v continua , sino que va por pulsos , esto da lugar a que la camara no se vea o se haga de forma incorrecta con muchas interferencias ). bien , tenia por casa un rele de 4 patillas asique lo cogi volvi a quitar el plastico del maletero y en el hueco donde deje el empalme lo cogi y separe el positivo , le puse 3 terminales faston ( 1 al positivo de la marcha atras , 1 al rojo de alimentacion de la camara y otro a la masa con el cable negro que va a la camara) , despues he sacado la luz derecha del maletero ( sale facilmente haciendo palanca con un destornillador por el lado derecho) hay 2 cables , uno marron (masa) y otro azul/rojo , saque un cable con un robacorrientes del positivo (azul/rojo)
y con la ayuda de una guia pasacables lo lleve hacia el hueco donde tengo los demas cables preparados facilmente , le puse otro terminal faston y me puse a conectarlos al relé.
La idea es tener un cable positivo que mande corriente a la camara cuando accione la marcha atras ,cada patilla del rele tiene una numeracion ( 30 , 85 , 86 y 87 ), para ello conectamos el positivo de la luz de maletero al 87 , el rojo de la camara al 30 , la masa con el negro de la camara al 85 y el positivo de la marcha atras al 86.
el funcionamiento es sencillo , cuando engranamos la marcha atras le estamos dando corriente al rele y este deja pasar la corriente limpia 12v continua que entra por la patilla 87 y sale por la patilla 30 hacia la camara .
Bien ... una vez conectado lo pruebo y ... funciona! y ahora si con motor arrancado y todo , salvo un pequeño detalle con el que no contaba , parasitosse ve pero con algunas lineas longitudinales , se ve bien , pero quiero una imagen perfecta
hecho mano de google y hay gente que ha montado camaras de aparcamiento y con el mismo problema veo que lo han solucionado con un filtro .
Echo mano al trastero y encuentro una radio vieja con pantalla que no funciona y casualmente tiene un filtro con fusible de 3A incluido![]()
, se lo corto y me vuelvo al coche nuevamente con el filtro , otra vez al hueco donde esta el rele , le corto el cable que va a la camara y le intercalo el dichoso filtro...
Por fin solucionado , se ve perfecto con motor en marcha y todo!
indicar que no hace falta este tipo de filtro , con un condensador q cuesta menos de 1 € , arreglado ! 10000mf / 16v o 25v , de las dos patillas una al positivo y otro al negativo
Hola e echo asta aqi el brico al igual que tu y me sige pasando lo de que cuando arrancas se va la pantalla .
Lo único q e exo distinto es cojer la masa del tornillo que sujeta el cinturón trasero pero eso sería indiferente no?
Y e pensado también Aver si va a ser por coger el positivo de la luz de maletero que al cerrar portón corta corriente
Que puede ser?
Encuesta - Que tipo de Gasoil utilizais Foro: General Autor: pirly Respuestas: 258 |
Verdad sobre problemas Seat león Mk4 Foro: General Autor: 130sport Respuestas: 6 |
mods obd virtual cockpit MK3 Foro: Informática / Interfaces / Diagnosis Autor: cuenxis Respuestas: 501 |
OBDeleven - Dudas y Mods para León MK4 Foro: Informática / Interfaces / Diagnosis Autor: miceor Respuestas: 678 |
