Lo más fácil es coger positivo del mechero ... ahí no hay fallo
León Mk3 - BRICO - Como instalar la cámara de parking
- Seguidores: 136
- Favoritos: 46
- Vistas: 603.566
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
si te gusta ... agradece el post !!
rojas - Gurú de los leones
- Agradecido: 1888 veces
Ya si yo por mi encantado de Acer eso si así fuese bien pero y si lo ago y sigo igual
felix_guti - Aun con la L
Seguro q no . Si no se viera ya tendrías que revisar el cable de vídeo o el correcto funcionamiento de la cámara en una tv x ejemplo
Ya pero eso sería raro no por que me fallaría siempre no solo cuando arranco
rojas escribió:Seguro q no . Si no se viera ya tendrías que revisar el cable de vídeo o el correcto funcionamiento de la cámara en una tv x ejemplo
Ok comprobado así x encima con un cable positivo al mechero es el cable de la luz de maletero también ahora dos cosa una como desarmo el mechero delantero para sacar el cable y dos si dejó el relé es mejor no para q no vaya encendida la cámara siempre
Entonces cogiendo positivo del fusible del mechero seguro q se soluciona
Saca el cubilete del reposabrazos. Sale tirando para arriba facilmente.
Desengancha el conector del mechero desde dentro del cubilete.
Lleva dos cables:
Marron = Masa
Negro/Rojo = Positivo.
Conecta el cable como mejor te parezca y a correr.
Lleva dos cables:
Marron = Masa
miceor - Leoner@ mayor del reino
- Agradecido: 1259 veces
Sacalo del módulo de fusibles con un adaptador de fusible
felix_guti escribió:Hola tengo una nueva duda Aver voy a poner el relé y en el empalme de la luz de marcha atrás y el negativo tengo también empalmado un párking sistem universal.
Aver lo puse todo ayer a la vez en principio parece que el párking sistem va bien no como la cámara q al arrancar ace cosas raras la pantalla .
Ahora mi pregunta es que ago paso todo por el relé o solo la cámara ?
¿Has intentado hacer la modificación de la intensidad de la luz de marcha atrás? Hay compis que han corregido el problema con este método (necesario OBDEleven o cable Vag-Com)
1. 09 - Cent. elect.
2. Código de acceso: 31347
3. 10-Adaptación
4. Seleccionar: Leuchte29RFL RA64 - Dimmwert AB 29
5. Cambiar valor a: 127
marlop - Gurú de los leones
- Agradecido: 1080 veces
felix_guti escribió:Ya pero eso sería raro no por que me fallaría siempre no solo cuando arranco
Subele la intensidad a la luz de marcha atras, seguro que lo solucionas
Enviado desde mi SM-N9005 mediante Tapatalk
Cuando pienses que estas al limite, estaras a un 50% de llegar al mismo.
IvanMc2 - Leoner@ habitual
- Agradecido: 129 veces
marlop escribió:felix_guti escribió:Hola tengo una nueva duda Aver voy a poner el relé y en el empalme de la luz de marcha atrás y el negativo tengo también empalmado un párking sistem universal.
3. 10-Adaptación
Ya lo e solucionado sacándolo del positivo del mechero
marcosgumiel escribió:Buenas, yo cogí tensión del mechero. Es decir cuando doy el contacto la cámara está encendida. Hay alguna codificación posible para que al dar al botón de park pilot y luego dar dar al de RVC se vea la cámara sin meter la marcha atrás?
Me autocito y llamo a @rojas a ver si sabes algo al respecto.
Desde el corazón de la Ribera del Duero,
marcosgumiel - Nuev@ por aqui
- Agradecido: 12 veces
marcosgumiel escribió:marcosgumiel escribió:Buenas, yo cogí tensión del mechero. Es decir cuando doy el contacto la cámara está encendida. Hay alguna codificación posible para que al dar al botón de park pilot y luego dar dar al de RVC se vea la cámara sin meter la marcha atrás?
No es posible , hasta donde se ... solo lo puede hacer la cámara HIGH en 6.5"
3. 10-Adaptación
@rojas, podrías poner está codificación en el primer post para que no se pierda entre todas las paginas y este localizable? Es de las soluciones más "sencillas" de implementar.
leonfito - Leoner@ avanzad@
- Agradecido: 85 veces
Claro
Cupra leon VZ 300 restyling Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: Artichoke Respuestas: 0 |
el leon tdi 150cv tiene estabilizadora atras o no?? Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: cordobitax Respuestas: 4 |
Donde está la varilla del aceite? Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: vannist Respuestas: 25 |
Correa bomba de aceite Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: Leoncio 1.5 Respuestas: 22 |
