León Mk3 - Actualización infotainment
- Seguidores: 188
- Favoritos: 42
- Vistas: 653.605
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Pedritoleon - Asidu@ en la selva
- Agradecido: 10 veces
Re: Actualización infotainment
Pedritoleon escribió:Yo le hecho t mismo si no t lo crees t mismo yo no pongo bulos
Tu? por favor.... disculpe. Siento la ironía, pero es que no puedo estar más de acuerdo con mi compañero @javigody . Es que ya cansas eh..... Por aquí nada más que soltando "perlitas" de si "yo tener esto, yo tener aquello, yo no pongo bulos, bla bla bla...." Anda que no sabia el compañero como cogerte las vueltas con este tema, y más teniendo él la actualización y haberla hecho y trasteado con ella para ver diferencias. "Yo lo hago por ayudar A LA gente ,(coma) no como otras PERSONAS que quieren hacer negocio" (me duele la vista...)
Lo dicho: has quedado "retratado".
Un saludo y hasta la próxima
- Agradecido: 465 veces
Y la mía no es 43g es 20G cuando os hago video haver que decís haver quien es el que pone bulos tengo coche equipado y no por vosotros no os doy ni un duro engañar a la gente y haciendo negoció
Le has puesto el reloj de kw?..como?..mola...o tienes un CUPRA?.
MORKAS - Mi Leon me tiene miedo
- Agradecido: 369 veces
me vino así cuando me la enviaron hakeado a t no t sale
y me funciona bien kw menú sport
MORKAS escribió:Le has puesto el reloj de kw?..como?..mola...o tienes un CUPRA?.[ Imagen ]
@MORKAS no es exclusivo del Cupra dicho reloj. Al pedir el DCC, viene la pantalla SportHMI, y es uno de los relojes seleccionables, junto a los de presión de turbo, temperatura del aceite, temperatura del agua e indicador de fuerzas G.
Lo malo es que la potencia aparece en KW, no se puede cambiar a caballos...
- Agradecido: 2046 veces
De que esa foto que has puesto no se corresponde con la supuesta versión que has instalado no dices nada?Pedritoleon escribió:Yo le hecho t mismo si no t lo crees t mismo yo no pongo bulos
Enviado desde mi SM-N950F mediante Tapatalk
SEAT León MK3 FR 1.4 TSI 150CV ACT
Instalador en Málaga -> VIM, bricos MK3, tempomat MK1 y más
--- ¡Colabora con nosotros y con la comunidad con tus backups de OBDeleven/Vagcom/VCDS en el siguiente enlace!: viewtopic.php?f=8&t=120732 ¡Gracias!---
javigody - Aqui + que con la novi@
- Agradecido: 274 veces
Hola mi pregunta es la siguiente, en el concesionario no hacen las actualizaciones, o hay que buscarse la vida, el lunes 19 tengo la revisión de los 30000 ml km, tendre que deciserlo haber que contestan.
pepo55 - Asidu@ en la selva
- Agradecido: 6 veces
pepo55 escribió:Hola mi pregunta es la siguiente, en el concesionario no hacen las actualizaciones, o hay que buscarse la vida, el lunes 19 tengo la revisión de los 30000 ml km, tendre que deciserlo haber que contestan.
@pepo55 Hasta donde yo sé, para que un concesionario te "intente" realizar una actualización del infotainment tiene que ser porque les comentes que tienes un problema con dicha unidad (ya sea reinicios, mal funcionamiento del bluetooth, etc), y aun así, parece que les cuesta la propia vida o simplemente te digan la frase famosa de que "no hay actualización disponible de esa unidad" o "es así".
¿Qué HW/SW es tu unidad? alomejor te podemos echar una mano los que estamos aquí.
Vaya..yo llevo dcc..pero claro...yo tenia la de 5.8 y cambié a esta hack...sera eso..ok..confio en que algun dia se pueda activar....graciasjasoriab escribió:MORKAS escribió:Le has puesto el reloj de kw?..como?..mola...o tienes un CUPRA?.[ Imagen ]
mi numero de equipo es H30 0359 y el dispositivo es 5QA035824A haber si me podes ayudar,gracias y un saludo
Ojo! Mi León tiene las mismas llantas y no aparecen en el sistema de infoentretenimiento!
5QA035824A H30 0359
¿Afectado por los Reinicios del sistema infotainment?
Yo también, visita el siguiente enlace para más información:
https://www.clubseatleon.net/viewtopic.php?f=9&t=125535
craken - Leoner@ habitual
- Agradecido: 31 veces
pepo55 escribió:mi numero de equipo es H30 0359 y el dispositivo es 5QA035824A haber si me podes ayudar,gracias y un saludo
Tengo la misma versión de sw y hw. Por los comentarios de otros compañeros en este hilo, no parece haber actualización para esta versión, al menos aún.
levorg - Aqui + que con la novi@
- Agradecido: 206 veces
Gracias de todas formas el lunes preguntare haber, la verdad que hay a veces que no enciende y lo hace al rato solo o paro apago el contacto y vuelvo a poner en marcha el coche y ya funciona.
Cupra leon VZ 300 restyling Foro: General Autor: Artichoke Respuestas: 2 |
Leon MK2 - Altavoces de las puertas no funcionan Foro: AudioCar y MultimediaCar Autor: Antoniiooo Respuestas: 0 |
León Mk4 - Actualización mapas MIB3 SEAT 2021 Foro: AudioCar y MultimediaCar Autor: jasoriab Respuestas: 123 |
el leon tdi 150cv tiene estabilizadora atras o no?? Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: cordobitax Respuestas: 4 |
León Mk4 - Actualizaciones sistema de infotainment Foro: AudioCar y MultimediaCar Autor: Yundas Respuestas: 1757 |
Usuarios navegando por este Foro: Anthropic, Majestic-12 [Bot], SentiBot y 4 invitados
