excelente brico si señor,
sabes si se puede hacer en una seat alambra 2016?
León Mk3 - BRICO - Como instalar la cámara de parking
- Seguidores: 136
- Favoritos: 46
- Vistas: 605.365
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
luisfm - Nuev@ por aqui
Re: BRICO como instalar la Camara de parking en Seat leon MK
MORKAS escribió:marcoa escribió:Hola compis haber si ha alguien mas le ha pasado lo que me ha pasado a mí. He hecho la instalación de la cámara hace unos meses todo bien pero he decidido de cambiar las bombillas de luz trasera marcha atras y intermitentes por luz leds, hay es donde viene el problema . Cambio la bombilla de luz marcha atras por una de led y al engranar la marcha atras con el motor parado todo bien , pero cuando encendi el coche![]()
me hace un ruido como a cortocircuito y la pantalla se me ve con interferencias y en negro .Ha alguien mas le ha pasado y que solucion tiene pues tube que poner la bonbilla halogena que traia. Gacias Un Salud2.
Precisamente eso me pasa a mi..pero el ruido a corto..es en el led de las puertas...que tengo el mod de luz blanca en las puertas al dar marcha atras..es posible que sea por el tipo de bombilla
pues compañeros creeis que subiendo el valor de la luz de marcha atras a 127 se resuelve el problema. Alguien me lo puede confirmar ? o no tiene nada que ver. GRACIAS un Salud2.
marcoa - Asidu@ en la selva
- Agradecido: 25 veces
marcoa escribió:MORKAS escribió:marcoa escribió:Hola compis haber si ha alguien mas le ha pasado lo que me ha pasado a mí. He hecho la instalación de la cámara hace unos meses todo bien pero he decidido de cambiar las bombillas de luz trasera marcha atras y intermitentes por luz leds, hay es donde viene el problema . Cambio la bombilla de luz marcha atras por una de led y al engranar la marcha atras con el motor parado todo bien , pero cuando encendi el coche![]()
Conpañeros me auto contesto ya que nadie me ha sabido responder para el que le pase lo mismo o le haya pasado efectivamente subiendo el valor de intensidad de la bonbilla de marcha atras a 127 solucionado compañeros.Un Salud2.
Rectifico...el ruido que me hacia al poner led en marcha atras.. (una bombilla caca..supongo)...es el relé del montaje de la camara trasera...pero probe con otra bombilla mejor..y perfecto..
MORKAS - Mi Leon me tiene miedo
- Agradecido: 369 veces
MORKAS escribió:marcoa escribió:MORKAS escribió:marcoa escribió:Hola compis haber si ha alguien mas le ha pasado lo que me ha pasado a mí. He hecho la instalación de la cámara hace unos meses todo bien pero he decidido de cambiar las bombillas de luz trasera marcha atras y intermitentes por luz leds, hay es donde viene el problema . Cambio la bombilla de luz marcha atras por una de led y al engranar la marcha atras con el motor parado todo bien , pero cuando encendi el coche![]()
No se MORKAS yo lo he probado subiendo la intensidad a 127 con OBDeleven y sin problemas. Pudiera ser por la mierda de bombilla pero lo he rectificado como bien he dicho un Salud2.
Muy buenas,
estoy interesado en hacer este brico al st 184 dsg que estoy esperando (en teoría me le darán la semana 5).
La pregunta es la siguiente:
¿sabéis si el modelo 2017 se podrá codificar por obdeleven?
¿Es sencillo de hacer la codificación? El resto de meter cables reles y demás no tengo problema ninguno.
Imagino que lo demás será hacerlo igual ¿no?
samucalle - Nuev@ por aqui
Acabo de hacer la instalación en un león mk3 de 2014, alguien me puede indicar como hacer la codificación con el obdeleven?
Estoy mirando, pero no lo veo por ningún sitio y no quiero tocar algo que no deba.
Gsi&Fr Power
Aker - Leoner@ habitual
- Agradecido: 18 veces
Aker escribió:Acabo de hacer la instalación en un león mk3 de 2014, alguien me puede indicar como hacer la codificación con el obdeleven?
Igual que con VagCom. Lo tienes en el primer post.
- Agradecido: 3612 veces
cvillajos escribió:Aker escribió:Acabo de hacer la instalación en un león mk3 de 2014, alguien me puede indicar como hacer la codificación con el obdeleven?
Teniendo el post no he sido capaz, tiene los mismos nombres?
Al ser del 2014 tengo gen1.....estoy un poco liado
Gsi&Fr Power
Aker escribió:cvillajos escribió:Aker escribió:Acabo de hacer la instalación en un león mk3 de 2014, alguien me puede indicar como hacer la codificación con el obdeleven?
El BRICO es de @rojas cuando tenía la pantalla de 5.8" (MIB gen1), así que sí, es todo igual. Si mal no recuerdo unicamente hay que codificar la cámara y el OPS (si lo tienes), y todo es LongCoding por lo que en OBDeleven en modo hexadecimal solo tienes que activar los bits indicados.
Mañana volveré a intentarlo, gracias
Gsi&Fr Power
rojas escribió:Hola , si el equipo es de 5.8 si puedes tener cámara y entrada de vídeo por el mitsumi .... si es de 5" ( SD en pantalla ) ninguna de las 2.
Buenas compañeros y feliz 2017
Tengo un león st fr del 2014 1.4tsi, lo compré hace 1 mes, ya tengo todo lo necesario para montar la cámara, solo me falta que llegue el obdeleven para activarlo. Mi duda es que he leído que si la pantalla tiene la entrada de sd en la pantalla no puedo montarla, ¿entendí bien? Espero que que no, xq sino mi gozo en un pozo
Aunque ahora con culo(st) desde 2003 enamorado de la fiera de seat
Se agradece dándole al
Pedrost - Aqui + que con la novi@
- Agradecido: 281 veces
No compréis nada rojas a mí me engaño me cobro 967e poniendo park assist
JUANILLO101976 - Aun con la L
- Agradecido: 10 veces
JUANILLO101976 escribió:No compréis nada rojas a mí me engaño me cobro 967e poniendo park assist
Vaya, no sabiamos nada de este asunto.
miceor - Leoner@ mayor del reino
- Agradecido: 1259 veces
Hos lo digo lo que paso a mí para que se entere los compañeros
Estadistica arbol de levas Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: guiller Respuestas: 2526 |
Problema con aire acondicionado León fr mk1 Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Paranohia Respuestas: 15 |
DSG 7 en Leon IV (MK4) Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: tiopas Respuestas: 44 |
mantenimiento león lll 1.5 tsi 130cv Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: Aaron1990r Respuestas: 0 |
Usuarios navegando por este Foro: Anthropic, CUPRAitoR, Google [Bot] y 2 invitados
