León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor genialsoft el 16 Ene 2017, 21:28
gambaloca escribió:Lo primero dar las gracias a rojas por su esfuerzo y dedicación.
Vamos al lio. Levaba leyendo el hilo unos meses y me he lanzado a la aventura y me he animado a poner la cámara en un leon st con pantalla de 5,8" y con sensores delanteros y traseros.
Compré la siguiente cámara (la pedí en Amazon y me tardo 4 días) porque no quería ni taladra la zona del paragolpes pintada ni cambiar los plafones, para evitar diferencias de color de los led o ver la imagen desplazada hacia un lado.
https://www.amazon.es/gp/product/B01J1N ... UTF8&psc=1
He desarmado la cámara del soporte y la he pegado en el portamatriculas. El cable le he metido por un agujero que hice en el paragolpes en la zona que viene sin pintar.
La he alimentado de los cables azul/negro (marcha atrás) y marrón (como indica rojas en el primer post). Estos cables los he encontrado retirando un poco el guarnecido del lado izquierdo del maletero (donde se encuentra la toma del mechero). Así que tengo todo montado y conectado menos el rca y los pines quadlock que van en la unidad de la guantera. De momento no he puesto ni rele, ni condensador porque no se ni como se ve.
El problema que tengo es que aún no me han llegado las herramientas para sacar la unidad de la guantera y no puedo conectar los pines quadlock. He probado a intentar sacarla con unos hierros que tenia de otra radio, pero no hay manera.
Alguien me puede decir cómo se puede sacar la unidad de la guantera sin la herramienta de extracción que todos habéis comprado.
Abre la guantera, la desencajas apretando por los lados para que se abra el todo. Después tiras hacia fuera del embellecedor que rodea la unidad de la guantera, sale fácil. Ahora verás la unidad y las patillas para soltarla, aprietas a cada lado con los deditos eh voilà. Es más fácil así que con los hierros.
genialsoft
Agradecido: 346 veces
Notapor er_trompe el 17 Ene 2017, 01:07
Yo me hice la herramienta cortando una tarjeta de puntos de un supermercado. En internet tienes los planos y las medidas para hacerla
La idea es que hagas lo de este vídeo
https://www.youtube.com/shared?ci=r4AXn2XkMnw
Es de bien nacido ser agradecido. Si te ha resultado útil este mensaje, dale al botoncito de gracias ;)
Antes de preguntar, escribe tu duda aqui, posiblemente ahorres tiempo y nos lo ahorres a los demás.
er_trompe
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 124 veces
Notapor Kipu el 17 Ene 2017, 14:15
Osea, que para los de 5" nos olvidamos. Es que pregunte el otro día a un instalador y me dijo que creía que si, tenía que mirarme si había un interface. No se si se podra así pero solo el interface salen carísimos.
http://www.car-interface.com/vendita/en/interfaces-a-v-video-seat/633-video-interface-for-seat-media-system-with-colour-display.html
https://www.audioledcar.com/es/interface-cámara-parking-seat-leon-3-2012-2017.html
Si a esto le sumas cámara e instalación... Que opináis
Saludos. ;)
Kipu
Agradecido: 16 veces
Notapor aborrasc el 17 Ene 2017, 16:19
Primero de todo muchas gracias a @rojas por el brico, como todos los que haces esta super bien. Te quería hacer un par de preguntas que no he sabido encontrar en el foro, la primera de ellas es si has probado y es posible poner en el leon el sistema de cámara 360º que lleva el Ateca. Y la segunda, es que llevo la pantalla 6,5 sin navegador en un mk3 2016, cómo funcionaria el tema de las líneas dinámicas y que significa cámara high?
Muchas gracias.
aborrasc
Notapor gambaloca el 18 Ene 2017, 12:46
er_trompe escribió:Yo me hice la herramienta cortando una tarjeta de puntos de un supermercado. En internet tienes los planos y las medidas para hacerla
Podrias mandarme por privado el enlace ???
gambaloca
Notapor er_trompe el 18 Ene 2017, 16:13
@gambaloca que enlace?
er_trompe
Notapor er_trompe el 18 Ene 2017, 16:18
No se si es esto a lo que te refieres. La subo por si te sirve
er_trompe
Notapor gambaloca el 18 Ene 2017, 17:35
er_trompe escribió:[ Imagen ]
Muchas gracias. Lo voy a intentar...
gambaloca
Notapor Edu1589 el 20 Ene 2017, 11:59
Mira esto en eBay http://www.ebay.co.uk/itm/260697709522
Enviado desde mi SM-G900F mediante Tapatalk
Edu1589
Agradecido: 9 veces
Notapor er_trompe el 20 Ene 2017, 12:34
Edu1589 escribió:Mira esto en eBay http://www.ebay.co.uk/itm/260697709522
Edu si no tienes prisa por recibirlas y buscas un poco, las encuentras mas baratas
Edito:
http://www.ebay.com/itm/331892279719
El envío una vez que te logueas, sale gratis
er_trompe
Notapor gambaloca el 21 Ene 2017, 12:31
Ya he conseguido sacar la unidad de la guantera y terminar todo el tema de cableado. He codificado con obdeleben y todo perfecto.
Eso si algún problema tenía que surgir. Se vé en blanco y negro. En teoria la camara acepta pal y ntcs. Hay alguna forma de ver si es compatible con NTCS?? , O tendría que mirar a ver si el problema está en otro lado...????
gambaloca
Notapor aguscalderon el 22 Ene 2017, 19:28
Voy a la mitad del hilo, ordené esta: http://www.ebay.com/itm/Waterproof-Rear-View-Parking-Reverse-Night-Vision-Camera-For-VW-Golf-MK6-GTI-MK7-/272285466354?hash=item3f657a7ef2:g:3esAAOSwGIRXbfDY
Ahora a esperar
¿Alguien sabe si los pines quadlock se pueden comprar en recambios?
________________________________________________
Saludos desde México, Leon Connect 2016 1.4 TSI 150
aguscalderon
Agradecido: 10 veces
Notapor Edu1589 el 23 Ene 2017, 22:04
Ok gracias
Enviado desde mi SM-T550 mediante Tapatalk
Edu1589
Agradecido: 9 veces
Notapor miceor el 24 Ene 2017, 07:28
aguscalderon escribió:Voy a la mitad del hilo, ordené esta: http://www.ebay.com/itm/Waterproof-Rear-View-Parking-Reverse-Night-Vision-Camera-For-VW-Golf-MK6-GTI-MK7-/272285466354?hash=item3f657a7ef2:g:3esAAOSwGIRXbfDY
Ahora a esperar
Los pines sueltos no los venden en la SEAT, venden el pin con el cable puesto de unos 40 cm y cuesta 4,5 Euros cada uno.
miceor
Agradecido: 1259 veces
Notapor BhEaN el 24 Ene 2017, 09:18
Ahora a esperar
Buenas...
No estoy seguro ahora mismo de qué pines son exactamente esos "quadlock" que comentais, pero en principio en la Seat SI que venden todos los pines de todos los conectores del coche... me extrañaría mucho que hubiera unos en concreto que no los tuvieran...
Agradecido: 1580 veces
