León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor rojas el 02 Feb 2017, 21:08
angeljimenez escribió:alguna camara en condiciones? la mia comprada en aliexpress por 27€ da muy mala calidad... cualquier destello y no ves nada
https://youtu.be/muTfmXtGVck
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1888 veces
Notapor angeljimenez el 02 Feb 2017, 21:55
esa es una pasada rojas, dudo que se pueda con mi pantalla de 5,8" xd
de todas maneras sale bien de precio? es quitar la que tengo del brico de 30€ y poner esta o mas royo?
angeljimenez
Agradecido: 17 veces
Notapor lebowski el 02 Feb 2017, 22:29
juantsi escribió:
Mediasystem plus es cuando tienes la pantalla junto a la unidad en la guantera. y Ops son los sensores de aparcamiento, que sale el dibujo del coche en la pantalla..
OK, tengo la segunda (sensores con dibujo) pero no la primera (no hay nada en la guantera).
lebowski
Notapor Xperience el 06 Feb 2017, 16:44
Alguien por córdoba que se dedique a instalar camara de marcha atrás? Tengo un Xperience con pantalla de 6.5 y unidad en la guantera.
Xperience
Notapor lebowski el 09 Feb 2017, 19:04
No he leído las 129 paginas pero he buscado en el tema "mib" y "mib2" sin resultado.
En mi alhambra con mib2 la opción de cámara trasera iba junto al navegador, por lo que supongo que no hay posibilidad de conectar una cámara como en este brico (1. no tengo navegador y 2.la cámara oem es RGB), ¿o se trata solo de una política comercial de seat y es posible hacerlo de manera no oficial?
lebowski
Notapor noxon el 09 Feb 2017, 22:31
Xperience escribió:Alguien por córdoba que se dedique a instalar camara de marcha atrás? Tengo un Xperience con pantalla de 6.5 y unidad en la guantera.
Yo tengo el mismo coche que tu, con la misma unidad que tu.
Mi consejo?
Compra todo y hazlo tu,
no es difícil y ahorraras dinero.
Para otras cosas quizás si es mejor que lo haga otro por X€, pero la cámara no es dificil
noxon
Agradecido: 35 veces
Notapor JoseXeiko el 09 Feb 2017, 23:40
Buenas noches, quería saber si podría instalar la cámara trasera en un ibiza de octubre 2016, cabe decir que tengo pantalla 6,5 full link SIN NAVEGADOR. Se que no se pueden reproducir videos si no es con mirrorlink, y por eso quería ver si la cámara funcionaria en mi coche.
Siento las molestias si está comentado en anteriores posts, pero no lo he encontrado por ningún sitio.
Habría mucha diferencia a la hora de pasar los cables de la parte trasera a la guantera?
Gracias de antemano
Seat Ibiza Style Connect Blue :culo2:
-Obdeleven Pro
-ELM 327
-Modo espejo sin VIM
JoseXeiko
Agradecido: 44 veces
Notapor cvillajos el 10 Feb 2017, 00:05
- @JoseXeiko :
@miceor la tiene montada en un Ibiza http://www.clubseatleon.net/viewtopic.php?f=9&t=106679&p=1908932&hilit=C%C3%A1mara+ibiza#p1908932 acostumbra a usar el buscador (esta era fácil) :ok:
- @lebowski :
He estado mirando por Internet la radio del
Alhambra con la referencia que pusiste en otro post (te acuerdas que dudaba de si era MIB o RNS/RCD por las ranuras SD y el CD/DVD en la propia pantalla?) Pues bien, sí es una MIB II parecidísima a la Composition Media/Discover Media del Tiguan (con ranuras SD en los laterales y CD/DVD en el frontal). Por tanto, podrías montar la cámara sin problemas. Mira un ejemplo a ver si se parece a la tuya: https://www.google.es/search?q=camara+marcha+atras+discover+media&client=ms-android-bq&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwit4tGjjITSAhVM0hoKHdMuAqkQ_AUICCgC&biw=360&bih=559#tbm=isch&q=rear+camera+discover+media&imgrc=tQmdcDm7hA2UzM:
cvillajos
Agradecido: 3612 veces
Notapor JoseXeiko el 10 Feb 2017, 00:09
Si, @cvillajos ese mensaje si lo vi, pero la duda me entra si influye el que sea 6,5 sin navegador. Alomejor el ibiza de @miceor si lo tiene y por eso a el si le funciona.
Repito, perdon por las molestias, y gracias
Enviado desde mi SM-A310F mediante Tapatalk
-Obdeleven Pro
-ELM 327
JoseXeiko
Notapor cvillajos el 10 Feb 2017, 00:18
JoseXeiko escribió:Si, @cvillajos ese mensaje si lo vi, pero la duda me entra si influye el que sea 6,5 sin navegador. Alomejor el ibiza de @miceor si lo tiene y por eso a el si le funciona.
Navegador o no es indiferente para montarla.
cvillajos
Notapor lebowski el 10 Feb 2017, 09:02
cvillajos escribió:He estado mirando por Internet la radio del
Más bien la duda es sobre la terminología distinta para definir el mismo aparato (que si composition media, que si discover pro, que si mib 2, etc.) y la falta de información detallada (conexiones, posibilidades, trucos, etc.).
cvillajos escribió: Pues bien, sí es una MIB II parecidísima a la Composition Media/Discover Media del Tiguan (con ranuras SD en los laterales y CD/DVD en el frontal). Por tanto, podrías montar la cámara sin problemas.
No lo tengo tan claro: yo también he estado buscando y por lo visto los kits son para poner la cámara oem, no sencillamente una cámara cualquiera con señal CVBS y además parece que solo valen para el modelo con navegador. Ya te digo que la información detallada brilla por su ausencia (quizás en foros alemanes haya algo pero la barrera del idioma es insalvable).
Por otro lado antes de cascar 500€ para una triste cámara trasera (que, por cierto, ya he pedido en aliexpress), pongo una pantalla extra y ya está. A mi lo que me interesa es la manera "no oficial" de hacerlo, no sé si me explico....si es que existe ;)
lebowski
Notapor cvillajos el 10 Feb 2017, 09:29
Composition Media (VW) = MediaSystem (Seat)
Discover Media (VW) = NavySystem (Seat)
Todas ellas MIB (modular infotainment baukasten)
Es MIB y tiene Quadlock detrás. Mírate los esquemas de este foro "hermano" PINs 6 y 12 del conector L donde poner el RVC, que aunque para una de 5,8" (MIB I), creo que el quadlock no cambia con respecto las de 6,5" (MIB2).
http://www.golfmk7.com/forums/showthread.php?p=202594
Saca la radio y haz una foto del conector.
cvillajos
Notapor rojas el 10 Feb 2017, 09:35
La información está , lo que no está lógicamente es en todos los post ...
Las unidades de vw , audi y skoda no nos sirven de mucho asiq no las vamos a mencionar , no es relevante , lo volvemos a refrescar:
MIB1 :
5F0035024 sin navy
5F0035846 con navy
5F0035858 con navy y DAB
MIB2 Standard:
5QA035024 sin navy
5QA035846 con navy
5QA035858 con navy y DAB
MIB2 HIGH:
5F0035020 :
4 nucleos en lugar de dos de la std , Con wifi , disco duro 10GB , DAB , fullink , DVD, videos en pendrive , Harman cardon y sonido DSP es lo más destacable entre otras cosas
5F0035043:
Lo mismo que la 020 pero sin DAB
En todas estas se puede instalar cámara de Parking, a excepción de las 5" que no se puede
No he puesto las 5" xq no recuerdo las referencias.
rojas
Notapor lebowski el 10 Feb 2017, 11:15
@cvillajos la desmontaré en cuanto pueda, pero ¿no habrá problemas al desconectar los conectores con el código de bloqueo?
@rojas la mía es 7N5035200C, o sea ninguna de las mencionadas (es un alhambra, no un león).
lebowski
Notapor cvillajos el 10 Feb 2017, 11:41
lebowski escribió:@cvillajos la desmontaré en cuanto pueda, pero ¿no habrá problemas al desconectar los conectores con el código de bloqueo?
Ninguno, porque ya no tienen código de bloqueo (en su lugar está la protección de componentes).
Supongo que la contestación de @rojas iba dirigida a @JoseXeiko , que preguntaba por un Ibiza.
cvillajos
