Muchas gracias a los 2, nose de donde sacais tanta información jajaj
León Mk3 - BRICO - Como instalar la cámara de parking
- Seguidores: 136
- Favoritos: 46
- Vistas: 605.540
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Seat Ibiza Style Connect Blue
-Obdeleven Pro
-ELM 327
-Modo espejo sin VIM
-Obdeleven Pro
-ELM 327
JoseXeiko - Asidu@ en la selva
- Agradecido: 44 veces
noxon escribió:Xperience escribió:Alguien por córdoba que se dedique a instalar camara de marcha atrás? Tengo un Xperience con pantalla de 6.5 y unidad en la guantera.
Yo tengo el mismo coche que tu, con la misma unidad que tu.
Mi consejo?
Compra todo y hazlo tu,
no es difícil y ahorraras dinero.
Para otras cosas quizás si es mejor que lo haga otro por X€, pero la cámara no es dificil
La instalación no me asusta, a lo que le temo es a la codificación, que por lo visto el vagcom es complicado en el Xperience. Un saludo
Xperience - Primeros Pasos
- Agradecido: 4 veces
Xperience escribió:noxon escribió:Xperience escribió:Alguien por córdoba que se dedique a instalar camara de marcha atrás? Tengo un Xperience con pantalla de 6.5 y unidad en la guantera.
Mi consejo?
Igual de complicado que para todos... Diferencia: ninguna
- Agradecido: 3612 veces
Hola a todos, a ver si alguien me puede ayudar con esto porque no entiendo lo que pasa. Yo tengo la camara alimentada directamente desde los fusibles, al principio me iba perfectamente y al mes o asi de tenerla instalada al arrancar y meter la marcha atras se queda la pantalla en negro como si la camara no recibiera la corriente pero al pasar unos 10 segundos (o menos) es como si ya le llegara la corriente y ya se ve todo correcto. Tambien me ha pasado alguna vez que haciendo maniobras para aparcar me funciona y de repente a la siguiente maniobra se me vuelve a quedar en negro como si la camara no recibiera corriente.
¿alguien sabe porque pasa esto o a alguien le ha pasado lo mismo?
Herrero_MK3 - Asidu@ en la selva
- Agradecido: 17 veces
Una mala conexión tiene toda la pinta ... tb puedes probar la cámara fuera del coche
si te gusta ... agradece el post !!
rojas - Gurú de los leones
- Agradecido: 1888 veces
Herrero_MK3 escribió:Hola a todos, a ver si alguien me puede ayudar con esto porque no entiendo lo que pasa. Yo tengo la camara alimentada directamente desde los fusibles, al principio me iba perfectamente y al mes o asi de tenerla instalada al arrancar y meter la marcha atras se queda la pantalla en negro como si la camara no recibiera la corriente pero al pasar unos 10 segundos (o menos) es como si ya le llegara la corriente y ya se ve todo correcto. Tambien me ha pasado alguna vez que haciendo maniobras para aparcar me funciona y de repente a la siguiente maniobra se me vuelve a quedar en negro como si la camara no recibiera corriente.
Seguramente sea lo que comenta @rojas , pero prueba también a reiniciar la radio (10segundos pulsado el botón Power), no pierdes nada por probar y a lo mejor tienes algo "pillado" por ahí.
@miceor podrías decirme de donde comprastes la cámara de tu ibiza?. Las medidas de los plafones son diferentes y la más barata que he visto son 68 euros
-Obdeleven Pro
-ELM 327
-Obdeleven Pro
-ELM 327
Yo no la llevo en los plafones.
Desmonté el paragolpes trasero y la puse en el centro haciendo un taladro que coincide con un hueco que hay en la tiranta metalica de la trasera.
La compré por ebay, muy similar a esta :
http://www.ebay.es/itm/170-Universal-Co ... Swq19XBjy3
Me costó 12 lereles.
miceor - Leoner@ mayor del reino
- Agradecido: 1259 veces
pff, me da cosilla toquetear el paragolpes @miceor. Si es posible preferiria usar una que pudiese instalarse en el plafón. Las de seat leon me confirmas que no valdrian no?
Que pasa si la cámara se rompe por lluvia por ejemplo(como he leido por aqui) y deja de funcionar...Nose me da mas confianza en el plafón.
-Obdeleven Pro
-ELM 327
-Obdeleven Pro
-ELM 327
Es un riesgo que he preferido correr, al fin y al cabo en media hora el paragolpes está desmontado sin esfuerzos.
Las camaras que venden en plafón no me gustan nada, la luz que llevan es escasa y azulada.
Prefiero llevarla independiente, del mismo modo que la llevo en el león de serie y no va en el plafón.
miceor escribió:Yo no la llevo en los plafones.
Hola, crees que interferirá en la imagen la bola de remolque? Yo es que la llevo fija. Un saludo
juantsi escribió:https://es.aliexpress.com/store/product/3-14-JAC-Refine-S5-after-the-installation-of-the-original-car-navigation-rearview-camera-special/1669570_32642158699.html?spm=2114.04010208.3.28.vzQPe8&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10000032_119_10000025_10000029_430_10000028_10060_10062_10056_10055_10000062_10054_301_10059_10099_10000022_10000012_10103_10000015_10102_10096_10000018_10000019_10000056_10000059_10109_10052_10053_10107_10050_10106_10051_10000053_10000007_10000050_10084_10083_10118_10000047_10080_10082_10081_10110_10111_10112_10113_10114_10115_10037_10000041_10000044_10078_10079_10077_10000038_429_10073_10000035_10121,searchweb201603_3,afswitch_2,single_sort_2_default&btsid=1dc33f96-7a9c-4714-8710-27a2bfb129c4
CABLE RCA PARA INTALAR CAMARA TRASERA EN LA UNIDAD DE LA GUANTERA.
No está disponible, donde puedo comprar uno igua?
cvillajos escribió:Es MIB y tiene Quadlock detrás. Mírate los esquemas de este foro "hermano" PINs 6 y 12 del conector L donde poner el RVC, que aunque para una de 5,8" (MIB I), creo que el quadlock no cambia con respecto las de 6,5" (MIB2).
http://www.golfmk7.com/forums/showthread.php?p=202594
Saca la radio y haz una foto del conector.
Aún no he sacado la radio, pero he visto esto
Me he puesto en contacto con ellos y dicen que debería funcionar, pero no me lo garantizan al 100%
(no es que me interese ese cable, pero si funciona quiere decir que en el mib2 también se puede activar la cámara trasera en los pines 6 y 12).
Por otro lado, el resto de interfaces para el mib2 lo que hacen es interceptar el cable que va a la pantalla, por ejemplo esta lo que me hace pensar que la entrada de la cámara no está activa
Y por el tercer lado
lebowski - Aun con la L
- Agradecido: 11 veces
lebowski escribió:cvillajos escribió:Es MIB y tiene Quadlock detrás. Mírate los esquemas de este foro "hermano" PINs 6 y 12 del conector L donde poner el RVC, que aunque para una de 5,8" (MIB I), creo que el quadlock no cambia con respecto las de 6,5" (MIB2).
Por otro lado, el resto de interfaces para el mib2 lo que hacen es interceptar el cable que va a la pantalla, por ejemplo esta lo que me hace pensar que la entrada de la cámara no está activa![]()
Y por el tercer ladome interesa más poner vídeo externo que la cámara trasera, pero me da que eso es imposible sin trastear con el firmware.
Al configurar la centralita como se indica en el primer post, lo que estás activando es que al engranar la marcha atrás tome la señal del RVC. Puedes incluso activarlo "por adelantado" (si tienes acceso a un interfaz) sin la cámara instalada para probarlo (yo lo hice, te muestra una pantalla en negro notas el cambio al meter narcha atrás).
Sobre el tema de Vídeo Externo y la MIB gen2 ya está muy hablado en otros hilos. Tu única opción es MirrorLink y modo espejo (con desbloqueo VIM o con APP de LG MirrorDrive)
cvillajos escribió:Sobre el tema de Vídeo Externo y la MIB gen2 ya está muy hablado en otros hilos. Tu única opción es MirrorLink y modo espejo (con desbloqueo VIM o con APP de LG MirrorDrive)
Una idea descabellada: si de verdad la entrada para la cámara funciona (cosa que dudo), podría interceptar el bus que va a la radio y falsear tanto los mensajes de velocidad como el de marcha atrás (que además creo que van en el mismo id).
Claro que si fuese tan sencillo ya estarían vendiendo interfaces con esta función....
Bueno, de aquí a un mes (o más), cuando me lleguen los adaptadores can desde China ya lo averiguaré.
Perdida de potencia motor y Limp Mode!!! Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Paranohia Respuestas: 2 |
Encuesta - Que tipo de Gasoil utilizais Foro: General Autor: pirly Respuestas: 299 |
Manual de taller Foro: General Autor: JesusEli Respuestas: 100 |
Mejor escape para León cupra Foro: Tuning Autor: karmelete300 Respuestas: 100 |
León Mk3 - Autorradios Android Foro: AudioCar y MultimediaCar Autor: ipardoma Respuestas: 1794 |
