León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor genialsoft el 21 Mar 2017, 16:59
stewei escribió:@genialsoft Veo en las imagenes que el angulo de vision es bueno. ¿podrias poner algunas fotos mas en algun aparcamiento con coches a los lados o similar?? Gracias!!!
Aquí tienes un ejemplo aparcando en bateria en zona azul. No he aparcado centrado, y abro la puerta para que veas la relación entre donde marca la línea de la izquierda y donde está al abrir la puerta. Amplia el video para verlos bien.
genialsoft
Agradecido: 346 veces
Notapor Esteban_m el 21 Mar 2017, 17:13
Antes de Nada, en mi primer post quería daros la enhorabuena por este pedazo de ilo.
Al lio, en breve pasaré a formar parte del club de propietarios Seat León (entre esta semana y la que viene). Total, que como me viene sin cámara trasera e venido a parar aquí:). Ya sé que lo suyo es hacerlo uno mismo, pero después de leer la mitad del ilo, me veo totalmente incapaz de hacerlo, maxime cuando será recien estrenado....
¿Me recomendais algún taller (o experto) que me lo haga en Madrid?. Hasta ahora el presupuesto más bajo que he encontrado son 500€, y no me cuadra nada con el precio del material/mano de obra que indicáis por aquí.
Muchas gracias a todos.
Esteban_m
Notapor stewei el 21 Mar 2017, 23:46
@genialsoft Gracias por la molestia del video. Seguramente me pille una camara de esas:
https://es.aliexpress.com/item/2016-New ... 3.6.yivbbq
Bueno, sera una igual que esa pero que en la app de ali sale por menos de 7€ jajjajajajajja
stewei
Agradecido: 465 veces
Notapor genialsoft el 22 Mar 2017, 17:23
stewei escribió:@genialsoft Gracias por la molestia del video. Seguramente me pille una camara de esas:
Si es que solo por las cámaras y los pedales los chinos me tienen ganado :cuñao:
genialsoft
Notapor juanbb el 22 Mar 2017, 18:36
Yo puse esa y se veía mejor que la original.
juanbb
Agradecido: 355 veces
Notapor LuichiFR el 22 Mar 2017, 20:18
Imagen Yo pille esta en Aliexpress...Después de casi un año va perfecta y quefa muy disimulada ya que había varios colores. Ojo con las que pone que son 360° ya que luego tendréis que centrar la imagen y cuesta la vida. Y otra cosa para aquellos que hagan taladros como yo. Si lo hacéis centrado con los plafones de la matrícula. No os preocupeis...Yo metí el dedo después de hacer el agujero y había distancia como para pillarlo con la broca.
Enviado desde mi Redmi Note 3 mediante Tapatalk
LuichiFR
Notapor LuichiFR el 22 Mar 2017, 20:19
LuichiFR
Notapor Rubimania el 26 Mar 2017, 23:42
Hola buenas estoy instalando la cámara y al codificar por observen me da error
Me sale en el obd unidad de control o responde la unidad 10 es la 0e? La de media player 1?
Y luego me sale el parkpilot no está disponible
Al arrancar y poner marcha atrás ace el amago de ponerse se queda en negro y al rato da error
Tengo los sensores tambien estos de serie.
Ahora me pita solo no me sale en la pabtalla
Rubimania
Notapor cvillajos el 27 Mar 2017, 10:37
Rubimania escribió:Hola buenas estoy instalando la cámara y al codificar por observen me da error
En OBDeleven el "Park/Steer Assist" no es la 10, es la 76.
cvillajos
Agradecido: 3612 veces
Notapor Rubimania el 27 Mar 2017, 14:40
Y que parámetros e de poner ? Me e liado un poco con el obd
Rubimania
Notapor cvillajos el 28 Mar 2017, 06:30
Pues tienes que dejarlo exáctamente como se indica en el primer post, usando la codificación en modo binario de OBDeleven y teniendo en cuenta que la stg 10 es la 76 en este último interface:
entramos en stg 5F MMI 3G <> Coding - 07 <> byte 19 , seleccionar Bit 4 se quedara el valor en 10.
byte 18 , seleccionar Bit 4 se quedara con valor 10
entramos en stg 10 park assist <> coding 07 <> y lo dejamos asi [byte 2->0010101]
cvillajos
Notapor brot1cz el 29 Mar 2017, 19:20
Necesito consejo. puede hacer esta cámara de radio
5F0035871
brot1cz
Notapor cvillajos el 30 Mar 2017, 20:50
brot1cz escribió:Necesito consejo. puede hacer esta cámara de radio
5F0035871
Es la de 5" así que no, no puede.
cvillajos
Notapor Oregon el 04 Abr 2017, 01:13
Una pregunta,
Me vais a matar pero he estado mirando paginas atrás y no la he visto..
Esto anula la garantia que te da seat de algún modo??
Oregon
Agradecido: 29 veces
Notapor cvillajos el 04 Abr 2017, 06:43
Oregon escribió:Una pregunta,
Pues depende del componente que quieras pasar por garantía...
¿Afecta su instalación al motor, turbo, transmisión, dirección, elevalunas, etc? Pues no te pueden anular su garantía. ¿Que da la casualidad que te jode algo de la radio o haces mal la instalación y te cargas algún elemento manipulado? Pues te pueden decir que no entra en garantía.
cvillajos
Usuarios navegando por este Foro: Anthropic, Bing [Bot] y 5 invitados
