León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor Alex_13 el 08 Dic 2018, 00:01
Buenas noches!!
esta mañana he actualizado mi 6,5".. y me ha surgido 2 problemas de los cuales ya citáis.
El primer error, es que me ha desaparecido el dibujo al entrar en el Setup del clima.. y leyendo la solución a ese problema... no sé a donde dar ,v ya que no se que sigifica "CODIFICACION MODO TEXTO" (Adjunto captura para que me digáis donde dar)
Y el segundo error, es la desaparición del Mirror Link... que siguiendo los pasos para solucionarlo, dentro de "vehicle configuration" tampoco veo la opción mirror link...
a ver si podéis ayudarme, y mil gracias.
Alex_13
Notapor cvillajos el 08 Dic 2018, 01:02
Alex_13 escribió:Buenas noches!!
1.- "Coding - 07" -> "LongCoding helper"
2.- Sigue bajando el scroll del desplegable. Hay muchos más canales de adaptación de los que muestras.
cvillajos
Agradecido: 3610 veces
Notapor Alex_13 el 08 Dic 2018, 09:36
No puedo hacer más scroll.. llega hasta ahí :o
Alex_13
Notapor cvillajos el 08 Dic 2018, 12:24
Alex_13 escribió:No puedo hacer más scroll.. llega hasta ahí :o
Si miras en la biblioteca de centralitas: viewtopic.php?f=8&t=120732 cualquier 5QA035824A veras como de "vehicle_configuration" tienes muchos más de 30 subcanales de adaptación... Bastantes más...
Veo que estás con VCDS 14.10. Su tienes ese cable prueba con otro más moderno. Si tienes un cable más moderno, peri has instalado esa versión porque está en español, instala el VCDS correspondiente al cable con ficheros de centralitas más actualizados (y aprendes inglés :si: )
cvillajos
Notapor Alex_13 el 08 Dic 2018, 14:43
Tengo la 15.7.4 también, pero el resultado es el mismo.
Y sobre el "Coding - 07" -> "LongCoding helper", una vez dado me sale la siguiente pantalla.. no veo nada sobre la opción que dice el compañero de "Car_derivate --- (Cambiar a 3)"
Saludos!!!!
Alex_13
Notapor cvillajos el 08 Dic 2018, 15:04
Saludos!!!!
Tienen que salirte más... El 15.7.4 es de julio 2017. Busca/prueba otras versiones. Mira la biblioteca de centralitas que te he enlazado y verás todos los canales que no te están saliendo.
Sobre "Car_derivate" eso es OBDeleven. VagCom no tiene labels para la 5F. Tienes que buscar (en el propio post de resolución de problemas se indican las combinaciones de bits/bytes) para cambiar las variantes del coche.
cvillajos
Notapor Alex_13 el 08 Dic 2018, 15:26
Saludos!!!!
Me recomiendas entonces instalar otra versión mas actual?? tengo ligeros recuerdos de que cuando compré el "chisme" este, me dijeron que como cambiara de version me lo cargaba.
saludos!!!
Alex_13
Notapor cvillajos el 08 Dic 2018, 16:04
Saludos!!!!
saludos!!!
Si tu VagCom no es original NO te recomiendo actualizar el VCDS. Cuando decía "busca/prueba" me referia a que busques y pruebes con otras versiones (bien compis en el censo de propietarios de interfaces por tu zona, bien que compres otra versión o interfaz).
cvillajos
Notapor miguel23and el 10 Dic 2018, 00:39
jasoriab escribió:
fegavo escribió:Buenas, el mío es un MY18 de Julio 2017. Adjunto imagen. No se si habrá alguna nueva. Es sin navegador.
Tenemos la misma (MY18 Agosto 2017). Al menos hay una versión posterior, la 0468. Puedes ver una foto de ella en unos mensajes más arriba...
El mío es MY18 Julio 2017 y tengo la versión 0462.
Llegasteis a conseguir actualización? Os aparece el "frenado en maniobra", es decir, si aparcando os vais a chocar el coche frena solo?
Gracias y un saludo!
miguel23and
Notapor jasoriab el 10 Dic 2018, 07:38
Hola @miguel23and
La semana pasada pasó por el concesionario para el cambio de aceite y pregunté al respecto. La respuesta fue que lo habían conectado pero no les salía ninguna actualización... :plas:
Por lo que se ha visto en el foro, para el HW041 he llegado a ver hasta la versión de SW0469 en alguna foto de un compañero.
A mi sí me aparece el frenado en maniobra desde el inicio, pero la verdad es que nunca me ha frenado al aparcar, únicamente un par de veces al iniciar la rampa de salida del garaje.
jasoriab
Agradecido: 2046 veces
Notapor JOTTA el 10 Dic 2018, 07:58
Hola @miguel23and
Si no me equivoco se refiere a eso , que mantiene el coche frenado en cuesta.
JOTTA
Agradecido: 55 veces
Notapor juanbb el 10 Dic 2018, 08:36
Hola @miguel23and
El frenado en maniobra es el de aparcamiento, te frena si cree que le vas a dar alguna columna, pared etc..
juanbb
Agradecido: 355 veces
Notapor miguel23and el 10 Dic 2018, 08:49
Hola @miguel23and
JOTTA escribió:Si no me equivoco se refiere a eso , que mantiene el coche frenado en cuesta.
Hola @jasoriab, @JOTTA, @fegavo
Creo que os referís al asistente en cuesta. Eso sí lo tengo.
Tal y como indica @juanbb, me refiero a una opción que aparece en el ordenador, en el apartado donde se configura si quieres que se baje hacia abajo el retrovisor izquierdo cuando pones marcha atrás, frenado en maniobra, etc... La sección se llama "Ajustes al aparcar y maniobrar".
Adjunto foto de la opción en concreto que a mí no me sale (la última de la imagen) y, obviamente, el coche no me frena solo si por ejemplo voy marcha atrás y voy a chocar contra una columna (comprobado lamentablemente :( )
¿Tenéis esa opción en vuestro coche?
Yo pensaba que era por faltarme alguna actualización, ya que en el mío llevo sensores atrás (delante no) y cámara trasera.
miguel23and
Notapor jasoriab el 10 Dic 2018, 09:52
Hola @miguel23and
Lo que te comentaba que me ha frenado un par de veces al subir la rampa no ha sido dentro de ella, sino al iniciarla, por lo que no tiene relación con el asistente de arranque en pendiente.
La verdad es que mi rampa del garaje tiene bastante inclinación, y al salir hacia la calle, imagino que la habrá detectado como un obstáculo, por eso lo del frenazo (clavó frenos ambas veces).
Yo sí tengo tengo el frenado en maniobra en esa pantalla del menú con la versión SW0462, venía así de fábrica. Lo que sí tengo es tanto sensores de aparcamiento delanteros y traseros, además del radar del control de velocidad adaptativo. Esto último no creo que tenga que ver, más bien pienso que es por tener sensores de aparcamiento tanto por delante como por detrás.
jasoriab
Notapor JOTTA el 10 Dic 2018, 22:28
Pues eso no lo tengo , si tengo sensores delanteros y traseros el mío es my16
JOTTA
