León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor Caanpulo el 11 Abr 2017, 15:01
¿Hay posibilidad de conectar la camara en otro fusible que no sea el del mechero y que tenga 12v bajo contacto?
Es que quiero hacer el brico de toma de 12v en maletero y necesito ese fusible libre
Caanpulo
Agradecido: 42 veces
Notapor cvillajos el 11 Abr 2017, 16:50
Caanpulo escribió:¿Hay posibilidad de conectar la camara en otro fusible que no sea el del mechero y que tenga 12v bajo contacto?
Mira aquí a ver si esto te ayuda:
http://www.clubseatleon.net/downloads.php?view=detail&df_id=266
cvillajos
Agradecido: 3612 veces
Notapor Caanpulo el 11 Abr 2017, 17:16
Gracias compañero, pero ahi no sale el voltaje ni si tiene corriente solo bajo contacto
Caanpulo
Notapor cvillajos el 11 Abr 2017, 18:40
Ni idea, solo sabía de su existencia no de su contenido :cuñao:
cvillajos
Notapor Rubimania el 15 Abr 2017, 20:14
miceor escribió:En la 5F, unicamente tienes que activar en Byte 19 el Bit 4 que es el de la camara.
El Byte 18 no tienes que tocar nada, no sé porque pones la imagen del mismo.
En el modulo 76, la codificación es la siguiente:
En modo Bytes:
Byte 0 Ningúno
Byte 1 Bit 0,4,5
Byte 2 Bit 0,2
Byte 3 Bit 4
Byte 4 Bit 0
En modo texto:
- Caja de cambios -- Opciones (Cambio manual - Sistema automático)
- Función arranque/parada codificación -- Opciones (No activa en UC- Activa en UC)
- Remolque -- Opciones (Sin dispositivo de remolque - Dispositivo de remolque - Remolque giratorio)
- Regulación de la distancia -- Opciones (No activado - Activado)
- Activación aparcamiento asistido -- Opciones (Automático - Manual)
- Asistente de acoplamiento con dirección asistida -- Opciones (Sin montar - Montado)
- Indicación optica para aparcamiento asistido -- Opciones (Indicación OPS - Sin montar)
- BAP -- Opciones (Activado - No activado)
- Tipo de camara -- Opciones (Camara de marcha atras)
- Supresión sonido (Mute) -- Opciones (Activado - No activado)
- Funcionamiento limitado -- Opciones (Disponible - No disponible)
- Indicación de carril -- Opciones (Con indicación de carril - Sin indicación)
- Sensores ruedas con detecc.sent.de giro -- Opciones (Sin montar - Montado)
- Información sobre la codificación -- Opciones (Codificado - Sin codificar)
- Hibrido/tracción electrica -- Opciones (Sin montar - Montado)
- Asistente de desaparcamiento -- Opciones (Sin montar - Montado)
En adaptación:
Volumen altavoces para aparcamiento asistido tras.: etapa 5
Frecuencia altavoces para aparcamiento asistido tras.: etapa 4
Volumen altavoces para aparcamiento asistido del.: etapa 6
Frecuencia altavoces para aparcamiento asistido del.: etapa 6
Requerimiento descenso de audio: on
Tono de activación p. aparcamiento asistido: off
Velocidad de desactivación p. ayuda de aparcamiento: 10 km/h
Modo de producción: desactivar
Desactivar modo de producción: desactivar
Me sige saliendo fallo y sin ver la camara pongo un video haber si me podeis ayudar
https://youtu.be/hZ4S6dMgjhs
Rubimania
Notapor MilleMiglia el 04 May 2017, 11:12
Hola, ¿alguien sabe dónde podría instalar la cámara de visión trasera en Madrid o alrededores, por favor?
Mil gracias!
Exprimir las marchas cortas es un placer, exprimir las largas, un delito.
MilleMiglia
Notapor angeljimenez el 08 May 2017, 12:06
stewei escribió:@genialsoft Gracias por la molestia del video. Seguramente me pille una camara de esas:
https://es.aliexpress.com/item/2016-New ... 3.6.yivbbq
Bueno, sera una igual que esa pero que en la app de ali sale por menos de 7€ jajjajajajajja
Buenas, tenia una camara de plafon y le he puesto hoy la de aliexpress que viene con la broca creo que como la tuya pero con la misma instalacion se me ve en blanco y negro :S a alguien le ha psado?
angeljimenez
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 17 veces
Notapor angeljimenez el 08 May 2017, 12:52
Ilustro con unas fotos, asi se ve la camara de plafon: (en color y correctamente)
Y asi la nueva, usando la misma instalacion, camara sin plafon de aliexpress recomendada en el hilo
Alguien que la haya pasado? Gracias
angeljimenez
Notapor cvillajos el 08 May 2017, 13:51
No recuerdo bien, pero puede ser algún tema NTCS vs PAL?
Probaste la cámara antes en algún televisor?
cvillajos
Notapor angeljimenez el 08 May 2017, 15:01
cvillajos escribió:No recuerdo bien, pero puede ser algún tema NTCS vs PAL?
Si, la he probado en una autocaravana y funciona perfecta, es raro la verdad, tengo entendido que nuestro coche admite NTCS pero esta camara la compre por que salio por este hilo y otros compis de por aqui la tienen, alomejor me ha tocado ami una PAL :neutral:
angeljimenez
Notapor LuichiFR el 08 May 2017, 22:50
Tiene pinta de ser Pal compañero. Con una NTCS no tendrás ningún problema. Todo sea eso. Un saludo
Enviado desde mi Redmi Note 3 mediante Tapatalk
LuichiFR
Notapor midlink el 10 May 2017, 12:05
Tengo la camara instalada en un León sin problemas.
Le instalé de igual forma a mi hermano la camara en su Ibiza, y el problema es que necesita poner la marcha atrás 2 veces para activar la camara.
Es decir, pones marcha atrás y se activa, vuelves a ponerla y no, vuelves a ponerla y si, vuelves a ponerla y no, así hasta el infinito. No importa el tiempo que tardes entre intento e intento.
Alguien se ha encontrado en esa situación? Si cuanto menos es curiosa.
midlink
Notapor Alleya el 14 May 2017, 17:25
Este es un briko que me apunto y ya tengo pedida la camara
Leon st fr 2.0 150cv
Alleya
Notapor Carlos Chea el 15 May 2017, 19:39
Por fin he instalado la cámara trasera con un amiguete, funciona pero al iniciar la marcha a veces se quita la imagen y salen unas rallas. He hecho la instalación como el post de rojas. Tengo el vagcom versión 16.8:mi modelo es un Seat León xperience. Podría ser interferencias entre imagen y corriente
Carlos Chea
Notapor aigort el 16 May 2017, 13:48
Carlos Chea escribió:Por fin he instalado la cámara trasera con un amiguete, funciona pero al iniciar la marcha a veces se quita la imagen y salen unas rallas. He hecho la instalación como el post de rojas. Tengo el vagcom versión 16.8:mi modelo es un Seat León xperience. Podría ser interferencias entre imagen y corriente
De donde has cogido los 12v?
Enviado desde mi MI NOTE LTE mediante Tapatalk
aigort
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 52 veces
