León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor cvillajos el 10 Jun 2017, 23:04
Route escribió:Cvillajos
La tapita que mencionas es la del paragolpes?
La que se ve en el exterior
No, la que digo está debajo del paragolpes a la derecha, en los bajos del coche. Hay que tumbarse para verla y desatornillar 3 o 4 tornillos (no recuerdo cuantos eran exáctamente) para soltarla. Desde ahí a la izquierda guía al plafón, y desde ahí hacia arriba entras en el maletero.
cvillajos
Agradecido: 3613 veces
Notapor Route el 12 Jun 2017, 22:41
Muchas gracias cvillajos ya esta metido con tus indicaciones
Gracias de nuevo
Route
Coche: Leon MK3 1.5 TGI 130cv
Notapor midlink el 14 Jun 2017, 11:51
midlink escribió:Buenas,
Tengo la camara instalada en un León sin problemas.
Le instalé de igual forma a mi hermano la camara en su Ibiza, y el problema es que necesita poner la marcha atrás 2 veces para activar la camara.
Es decir, pones marcha atrás y se activa, vuelves a ponerla y no, vuelves a ponerla y si, vuelves a ponerla y no, así hasta el infinito. No importa el tiempo que tardes entre intento e intento.
Alguien se ha encontrado en esa situación? Si cuanto menos es curiosa.
Me cito... no he encontrado la solución...
vuelvo a aclarar, la cámara va genial, pero:
Introduces marcha atrás: funciona.
Primera, bla bla bla.
Introduces marcha atrás de nuevo: no funciona.
Introduces marca atrás de nuevo: funciona.
Así infinito... ES MUY RARO. Tengo mismo condensador y la misma instalación hecha... además el condensador es para la alimentación... no para la activación...
midlink
Notapor vdupv2 el 16 Jun 2017, 21:57
Que cámara tienes? De logo con el motorcillo o solo la cámara de matricula?
Yo tengo una de cada y haciendo pruebas con la de vw motorizada me hacia exactamente lo mismo, y era xq estaban los positivos cambiados.
Hoy estoy con una normal de defensa y conectando positivo, negativo y la señal de marcha atrás al cable de la bombilla directamente y funciona perfecta.
Enviado desde mi HTC One_M8 mediante Tapatalk
vdupv2
Agradecido: 31 veces
Notapor JAL el 20 Jun 2017, 17:37
Hola Buenas,
Alguien sabría decirme como se saca el bolton negro que adjunto en la imagen, en mi caso me cuesta una barbaridad sacarlo!!!!
JAL
Notapor hamnk el 28 Jun 2017, 22:56
Buenas, yo tengo una duda, mi camara es de un Renault Scenic Ranchera de los nuevos, me la ha traido un coleguita que trabaja en la Renault Palencia. Y trae 4 cables
BLANCO
AMARILLO
ROJO
NEGRO
Mi duda es, cual es cual?
Blanco y Amarillo (video)
Rojo (Corriente, el que va a la luz de marcha atrás)
Negro (Masa)
???? Estoy en lo cierto???
Gracias de antemano
hamnk
Notapor angeljimenez el 28 Jun 2017, 23:59
angeljimenez
Agradecido: 17 veces
Notapor MORKAS el 29 Jun 2017, 00:09
angeljimenez escribió:A alguien le pasa esto?
https://www.youtube.com/watch?v=pTxjHZrr_Ac
Ostras..que raro..no?..a ver si alguien sabe de ello...
MORKAS
Agradecido: 369 veces
Notapor angeljimenez el 29 Jun 2017, 10:49
Si que es raro, ademas he cambiado hasta la cámara por si era eso y sigue igual con la nueva, es tocar una vez las opciones y se pone bien, pero sin tocar nada se ve muy claro
angeljimenez
Notapor aigort el 29 Jun 2017, 10:56
Por probar algo, prueba a hacer ajustes de fábrica a la 5f
Enviado desde mi MI NOTE LTE mediante Tapatalk
aigort
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 52 veces
Notapor ONUBENSE el 07 Jul 2017, 22:56
Una pregunta, estoy harto de repasar pero me queda una duda, si cojo la corriente directa del mechero tengo que poner relé o condensador o no hace falta?
Los cobardes mueren varias veces antes de expirar, el valiente solo una vez prueba la muerte.
ONUBENSE
Notapor cvillajos el 08 Jul 2017, 00:53
ONUBENSE escribió:Una pregunta, estoy harto de repasar pero me queda una duda, si cojo la corriente directa del mechero tengo que poner relé o condensador o no hace falta?
No hace falta. Yo la tengo así sin relé ni nada robando la corriente del fusible del mechero.
cvillajos
Notapor ONUBENSE el 08 Jul 2017, 10:32
Y el negativo de alguna chapa?
ONUBENSE
Notapor cvillajos el 08 Jul 2017, 10:50
ONUBENSE escribió:Y el negativo de alguna chapa?
Sí, a un tornillo del lateral derecho... Pero no recuerdo exáctamente cuál :avergonzado:
cvillajos
Notapor ONUBENSE el 08 Jul 2017, 15:44
Y en el portafusibles Le pongo el fusible del mechero y el nuevo para la cámara, no? De cuanto amperios pongo el de la cámara? Muchísimas gracias x ayudarme, mañana me quiero poner a instalarla
ONUBENSE
