León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor cvillajos el 08 Jul 2017, 16:02
ONUBENSE escribió:Y en el portafusibles Le pongo el fusible del mechero y el nuevo para la cámara, no? De cuanto amperios pongo el de la cámara? Muchísimas gracias x ayudarme, mañana me quiero poner a instalarla
Sí, con un robacorrientes como este, por ejemplo:
http://www.clubseatleon.net/viewtopic.php?f=9&t=110684&p=1974146&hilit=Robacorrientes#p1974146
Yo lo puse del mismo ampedaje que el que tiene (uno amarillo, creo que es de 15).
cvillajos
Agradecido: 3613 veces
Notapor javigody el 08 Jul 2017, 21:09
aigort escribió:
angeljimenez escribió:
MORKAS escribió:
angeljimenez escribió:A alguien le pasa esto?
https://www.youtube.com/watch?v=pTxjHZrr_Ac
Ostras..que raro..no?..a ver si alguien sabe de ello...
Si que es raro, ademas he cambiado hasta la cámara por si era eso y sigue igual con la nueva, es tocar una vez las opciones y se pone bien, pero sin tocar nada se ve muy claro
Por probar algo, prueba a hacer ajustes de fábrica a la 5f
Enviado desde mi MI NOTE LTE mediante Tapatalk
Te confirmo que reseteando los ajuste de fabrica de la pantalla se soluciona. Lo acabo de arreglar en el coche del compi @seat leon fr 46
SEAT León MK3 FR 1.4 TSI 150CV ACT
Instalador en Málaga -> VIM, bricos MK3, tempomat MK1 y más
--- ¡Colabora con nosotros y con la comunidad con tus backups de OBDeleven/Vagcom/VCDS en el siguiente enlace!: viewtopic.php?f=8&t=120732 ¡Gracias!---
javigody
Agradecido: 274 veces
Notapor seat leon fr 46 el 09 Jul 2017, 11:24
Confirmado es así, antes se veía mal y cada vez que arrancaba el coche tenia que ajustar el brillo y contraste después de resetear funciona perfectamente
seat leon fr 46
Agradecido: 94 veces
Notapor angeljimenez el 09 Jul 2017, 17:05
Gracias!! Esta noche lo pruebo :D :D
angeljimenez
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 17 veces
Notapor ONUBENSE el 09 Jul 2017, 18:51
Cuando me puesto a codificar con el vag com me encuentro que me dice que no tengo instalado el modulo 10, a alguien os ha pasado?
Los cobardes mueren varias veces antes de expirar, el valiente solo una vez prueba la muerte.
ONUBENSE
Notapor cvillajos el 09 Jul 2017, 19:55
ONUBENSE escribió:Cuando me puesto a codificar con el vag com me encuentro que me dice que no tengo instalado el modulo 10, a alguien os ha pasado?
Nuevas versiones del VagCom 10=76 (que es el que debería haber sido desde el principio).
cvillajos
Notapor ONUBENSE el 09 Jul 2017, 20:12
Lo acabo de mirar y tampoco me sale en los instalados, mi cable es el 14.10.2 en español
ONUBENSE
Notapor cvillajos el 09 Jul 2017, 21:17
ONUBENSE escribió:Lo acabo de mirar y tampoco me sale en los instalados, mi cable es el 14.10.2 en español
Pero tienes sensores de aparcamiento? Y si es así, son OEM?
cvillajos
Notapor ONUBENSE el 09 Jul 2017, 22:39
No tengo sensores
ONUBENSE
Notapor cvillajos el 09 Jul 2017, 22:47
ONUBENSE escribió:No tengo sensores
Pues no tienes 10 (ni 76)
cvillajos
Notapor ONUBENSE el 10 Jul 2017, 00:06
Muchas gracias
ONUBENSE
Notapor angeljimenez el 11 Jul 2017, 23:56
@seat leon fr 46 @javigody confirmado que funciona, muchas gracias :D :D
angeljimenez
Notapor Dconnect el 12 Jul 2017, 17:59
Buenas!!
Ya lo he comentado en otro hilo pero no parece ser que demos con la respuesta correcta.
Tengo una duda sobre la instalación de la cámara delantera del mk3.
Tengo dudas sobre cómo conectar la cámara, la idea es instalarla en las rejillas delanteras y pasar los cables hasta la guantera(cosa que no se si se podría hacer desde el capó hasta dentro por algún recoveco que haya) y poder sacar del Mitsumi un RCA para conectarla, me faltaria en ese caso los 12V y la masa.
El tema está en que mi coche (Style Connect Plus) viene con cámara trasera de serie y toda la instalación de los diferentes bricos de @rojas no llego a entender como sacar los cables ya que al parecer las conexiones de la cámara de fabrica no tienen nada que ver con los que utilizamos aparte para instalarla a posteriori y me tiene muy perdido.
Por otra parte he visto que @miceor la instaló con un conmutador de 3 entradas pero igualmente no tengo ni idea de como puedo hacerlo.
¿Alguien puede iluminarme?
Muchas gracias!
Un saludo chicxs!
Dconnect
Coche: Leon MK3 1.2 TSI 105cv
Notapor sandrorey el 12 Jul 2017, 18:14
angelTDI escribió:Muchas gracias por este nuevo brico. :ok:
La cámara ya la tengo pedida, así que ahora a investigar todas las explicaciones que das en el brico. :yea: :aplauso:
hola, podrías pasarme el enlace de la cámara en la luz de matrícula?, es que no lo veo. Gracias.
sandrorey
Notapor P.carrizo.leonstfr el 14 Jul 2017, 10:53
Hola a todos os cuento mi problema tengo instalada la camara trasera a posteriori i me funciona bien pusimos el condensador porque si no no funcionaba pues el caso que hace una semana la camara cuando recién arrancó el coche i pongo la marcha atrás me pone park pilot no disponible después circuló un rato con el coche i funciona sabéis de que puede ser? Un saludo a todos i gracias de antemano.
P.carrizo.leonstfr
