León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor cvillajos el 14 Jul 2017, 11:55
P.carrizo.leonstfr escribió:Hola a todos os cuento mi problema tengo instalada la camara trasera a posteriori i me funciona bien pusimos el condensador porque si no no funcionaba pues el caso que hace una semana la camara cuando recién arrancó el coche i pongo la marcha atrás me pone park pilot no disponible después circuló un rato con el coche i funciona sabéis de que puede ser? Un saludo a todos i gracias de antemano.
Revísalo a ver si lo hace más veces o "se le fué la pinza" puntualmente​.
Si pones contacto y arrancas muy rápido y luego metes marcha atrás inmediatamente quizá a los sistemas no les ha dado tiempo a inicializarse correctamente o a la 5F a recibir correctamente los mensajes del CAN BUS.
cvillajos
Agradecido: 3611 veces
Notapor P.carrizo.leonstfr el 14 Jul 2017, 13:22
Lo hace más veces incluso estando un rato en ralentí aveces va aveces no.. podría ser el condensador?
P.carrizo.leonstfr
Notapor ONUBENSE el 30 Jul 2017, 13:07
La acabo de poner y se ve en blanco y negro, sabéis el motivo?
Los cobardes mueren varias veces antes de expirar, el valiente solo una vez prueba la muerte.
ONUBENSE
Coche: Leon MK3 1.5 TGI 130cv
Notapor cvillajos el 30 Jul 2017, 13:51
ONUBENSE escribió:La acabo de poner y se ve en blanco y negro, sabéis el motivo?
Puede ser por formato NTSC vs PAL
cvillajos
Notapor ONUBENSE el 30 Jul 2017, 13:52
Que quiere decir eso?
ONUBENSE
Notapor MORKAS el 30 Jul 2017, 14:22
ONUBENSE escribió:Que quiere decir eso?
La norma de color..ntsc. o pal (europa)
MORKAS
Agradecido: 369 veces
Notapor ONUBENSE el 30 Jul 2017, 14:28
En las instrucciones pone:
TV SYSTEM PAL/NTSC
ONUBENSE
Notapor LuichiFR el 30 Jul 2017, 19:23
@Cvillajos se refiere a que sólo admite sistema NTSC. Es de suponer que tu cámara es PAL, y ese es el motivo de que se vea en blanco y negro.
Enviado desde mi MI 5s Plus mediante Tapatalk
LuichiFR
Notapor ONUBENSE el 30 Jul 2017, 19:53
Pero pone que es pal/ntsc
ONUBENSE
Notapor LuichiFR el 30 Jul 2017, 20:50
@ONUBENSE. Yo según me acuerdo, y no me gustaría engañarte. El sistema no tiene modo automático, como otras radios o chinas, que no tienen ningún problema para funcionar con los dos sistemas. En este caso tiene entrada NTSC. Y la cámara tiene que ser únicamente NTSC. Ya te digo que yo no tuve ningún problema, hace más de un año que la puse y hubo gente que puso incapie en ese tema.
LuichiFR
Notapor ONUBENSE el 30 Jul 2017, 22:06
Entonces si quiero verlo a color la única forma es comprar otra cámara que sea solo formato NTSC, no?
ONUBENSE
Notapor ONUBENSE el 30 Jul 2017, 22:16
genialsoft escribió:http://s.aliexpress.com/IvuUzi2u
(from AliExpress Android)
Está es la que llevo ahora y va bien.
Esa misma cámara es la que yo tengo, a ti se te ve a color?
ONUBENSE
Notapor sergiosroman el 08 Ago 2017, 11:30
Al fin conecte la cámara y he conseguido que no me salga el mensaje de park pilot no disponible, me falta comprobar que no se me quedan los sensores activos.
Los pasos que he seguido son los siguientes:
En 5F activar en el byte 19 el bit 4
En el modulo 76, codificación y activar en el byte 2 los bits 0,2 y 4 (el 0 lo tenia activo ya)
Luego fui a aplicaciones y "compré" el optical parking system
Pues con todo esto tengo la cámara activada y me aparece en pantalla el dibujo del coche y los sensores.
Gracias a todos vosotros lo he conseguido
sergiosroman
Notapor sergiosroman el 08 Ago 2017, 20:01
Así ha quedado
Que es el vrc?
sergiosroman
Notapor Route el 10 Ago 2017, 00:35
sergiosroman escribió:Al fin conecte la cámara y he conseguido que no me salga el mensaje de park pilot no disponible, me falta comprobar que no se me quedan los sensores activos.
Perdona mi ignorancia pero el módulo 76 cual es
A ver si es por eso por lo que a mi se me ve todo negro
Route
Usuarios navegando por este Foro: Anthropic, Semrush y 0 invitados
