León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor cvillajos el 10 Ago 2017, 00:54
Route escribió:
sergiosroman escribió:Al fin conecte la cámara y he conseguido que no me salga el mensaje de park pilot no disponible, me falta comprobar que no se me quedan los sensores activos.
Los pasos que he seguido son los siguientes:
En 5F activar en el byte 19 el bit 4
En el modulo 76, codificación y activar en el byte 2 los bits 0,2 y 4 (el 0 lo tenia activo ya)
Luego fui a aplicaciones y "compré" el optical parking system
Pues con todo esto tengo la cámara activada y me aparece en pantalla el dibujo del coche y los sensores.
Gracias a todos vosotros lo he conseguido
Perdona mi ignorancia pero el módulo 76 cual es
A ver si es por eso por lo que a mi se me ve todo negro
Es el del asistente de aparcamiento. Si tienes OBDeleven o VagCom 17.1 (o superior) su número es el 76 (el que debe ser), si tienes VagCom 16.8 o inferior será el número 10.
cvillajos
Agradecido: 3612 veces
Notapor Route el 10 Ago 2017, 08:32
Ok
Muchas gracias cvillajos
Route
Coche: Leon MK3 1.5 TGI 130cv
Notapor miguelorly el 12 Ago 2017, 05:25
miceor escribió:En la 5F, unicamente tienes que activar en Byte 19 el Bit 4 que es el de la camara.
El Byte 18 no tienes que tocar nada, no sé porque pones la imagen del mismo.
En el modulo 76, la codificación es la siguiente:
En modo Bytes:
Byte 0 Ningúno
Byte 1 Bit 0,4,5
Byte 2 Bit 0,2
Byte 3 Bit 4
Byte 4 Bit 0
En modo texto:
- Caja de cambios -- Opciones (Cambio manual - Sistema automático)
- Función arranque/parada codificación -- Opciones (No activa en UC- Activa en UC)
- Remolque -- Opciones (Sin dispositivo de remolque - Dispositivo de remolque - Remolque giratorio)
- Regulación de la distancia -- Opciones (No activado - Activado)
- Activación aparcamiento asistido -- Opciones (Automático - Manual)
- Asistente de acoplamiento con dirección asistida -- Opciones (Sin montar - Montado)
- Indicación optica para aparcamiento asistido -- Opciones (Indicación OPS - Sin montar)
- BAP -- Opciones (Activado - No activado)
- Tipo de camara -- Opciones (Camara de marcha atras)
- Supresión sonido (Mute) -- Opciones (Activado - No activado)
- Funcionamiento limitado -- Opciones (Disponible - No disponible)
- Indicación de carril -- Opciones (Con indicación de carril - Sin indicación)
- Sensores ruedas con detecc.sent.de giro -- Opciones (Sin montar - Montado)
- Información sobre la codificación -- Opciones (Codificado - Sin codificar)
- Hibrido/tracción electrica -- Opciones (Sin montar - Montado)
- Asistente de desaparcamiento -- Opciones (Sin montar - Montado)
En adaptación:
Volumen altavoces para aparcamiento asistido tras.: etapa 5
Frecuencia altavoces para aparcamiento asistido tras.: etapa 4
Volumen altavoces para aparcamiento asistido del.: etapa 6
Frecuencia altavoces para aparcamiento asistido del.: etapa 6
Requerimiento descenso de audio: on
Tono de activación p. aparcamiento asistido: off
Velocidad de desactivación p. ayuda de aparcamiento: 10 km/h
Modo de producción: desactivar
Desactivar modo de producción: desactivar
hola,
yo tengo el leon 2.0 tdi 150 cv 2017 (restyling).
esta es la configuración que tendría que poner en mi caso???
Se puede hacer con obdeleven???
y otra cosa, un compañero del foro me podría dejar configurado lo del obdeleven este fin de semana pero la cámara la tengo que pedir y tardaría unas semanas en llegar. hay algún problema por cambiar la configuración y no dejar la cámara puesta??? o eso daría igual.???
estoy leyendo un montón en este hilo pero estoy un poco perdido.
Otra pregunta, he visto esta cámara en aliexpress. Alguien me puede decir si esta en concreto se podría montar o darme una opinión sobre ella???
http://s.aliexpress.com/nAzMvmIn
miguelorly
Notapor Aker el 13 Ago 2017, 08:58
La cámara esa la veo bien. Supongo que si se activa sin la cámara aparezca en negro la pantalla al meter marcha atrás. Con el obd se puede hacer pero no se decirte si es igual o no en tu modelo de coche.
Gsi&Fr Power
Aker
Agradecido: 18 veces
Notapor cvillajos el 13 Ago 2017, 13:45
miguelorly escribió:
hola,
Yo la 76 no la tengo porque no llevo sensores, pero la 5F la dejé configurada un par de días antes de instalar la cámara, y sin problema... Pantalla negra al engranar marcha atrás y ya. Supongo que con la 76 tampoco habrá problema.
Lo que me tiene intrigado de esa cámara son las líneas de aparcamiento inteligentes... Supongo que se basará en algún sensor de movimiento propio de la cámara, porque no irá conectada al CanBus para "leer" la trayectoria de las ruedas (por lo que he visto en el anuncio). Habría que ver qué tal funciona, y quien sabe... Quizá cambie la mía si va bien...
cvillajos
Notapor Tarzan el 14 Ago 2017, 07:15
Buenos dias.
Tengo el Leon 2.0tdi DSG de 150cv. no tengo navi, ni park assist.
tengo instalada la camara de Alliexpress, he seguido los pasos:
entramos en stg 5F MMI 3G <> Coding - 07 <> byte 19 , seleccionar Bit 4 se quedara el valor en 10.
byte 18 , seleccionar Bit 4 se quedara con valor 10
Hasta a qui todo bien, pero luego no puedo entrar en el 10 (no tengo park assist).
que paso es el que tendría que hacer en mi caso. (yo utilizo en VAG CAN PRO. Es como el Vag-com)
Gracias de antemano por vuestra ayuda.
Tarzan
Notapor cvillajos el 14 Ago 2017, 08:33
Tarzan escribió:Buenos dias.
Sin sensores no hay centralita 10 (o 76 según interface usado). También te sobra la codificación del byte 18 en la 5F. En tu caso solo con modificar el byte 19 te basta.
cvillajos
Notapor Tarzan el 14 Ago 2017, 09:06
Gracias @cvillajos.
Que me quede claro:
Solo con eso vale? o tengo que ir al 76 y conectar algo?.
Perdona por todas las consultas que tengo?
Tarzan
Notapor cvillajos el 14 Ago 2017, 09:13
Gracias @cvillajos.
Que me quede claro:
Sólo el primer paso, nada más.
cvillajos
Notapor Tarzan el 14 Ago 2017, 10:14
Gracias @cvillajos.
Que me quede claro:
Muchas gracias por las solución.
Lo probare y ya os comentare si ha ido todo bien.
Tarzan
Notapor miguelorly el 15 Ago 2017, 13:30
hola,
coño pues si nadie ha probado esa cámara en concreto me da un poco de miedo por si luego algo no va. además veo que tiene ntsc y pal pero lo que viene activado por es ntsc. varios compañeros han escrito que las cámaras SOLO ntsc porque si no dan problemas
cuál es la que está metiendo la gente por aquí??? o me puedes dar alguna recomendación???
en mi coche tengo park assist y navi entonces teniendo eso en cuenta... la configuración de arriba me puede valer o si lo hago así puedo fastidiar alguna cosa??? estoy un poco acojonaete la verdad.
al final me pillé el vag com 17.1.3 porque resulta qeue un amigo lo tiene (versión antigua) y me convenció. me imagino que con este también puedo hacer estos cambios verdad??
miguelorly
Notapor LuichiFR el 15 Ago 2017, 14:59
Última edición por LuichiFR el 15 Ago 2017, 15:11, editado 1 vez en total
LuichiFR
Notapor LuichiFR el 15 Ago 2017, 15:06
@miguelorly. No te agobies compañero. Esa cámara tiene buena pinta. Yo el problema que le veo a las cámaras de tipo plafón, es que luego igual en la ITV te pueden decir que ilumina menos o da sombra. Depende del tío que te toque también. Aparte de eso, pídela que sea NTSC, aunque te venga por defecto. Ya que a veces te pueden colar una PAL y si no lo has anotado en el pedido ya la puedes dejar de adorno que no te valdrá. Del tema de configuración el colega cvillajos seguro que puede echar una mano, yo ya no me acuerdo y aparte era del 2014. Por último. Si vas a usar robacorrientes, te recomiendo que uses los de color rojo que son para cable más pequeño y te irá mejor, si no lo ves claro, empalmes trenzados de los de toda la vida y cinta. Un saludo
Enviado desde mi MI 5s Plus mediante Tapatalk
LuichiFR
Notapor Alleya el 15 Ago 2017, 16:09
Acabo de instalar la cámara de video y me da error
OBDeleven Log de datos
Fecha: 2017-08-15 15:20
Numero de bastidor: VSSZZZ5FZGR240459
Coche: Seat Leon
Año: 2016
Tipo de carrocería: Sports Tourer
Motor: CRLB 110 kW (150 HP) 2 l
Kilometraje: 13707 KM
5F Electrónica de información
Descripción del sistema: MU-S--ER
Número de software: 5QA035824A
Versión de software: 0359
Número de hardware: 5QA035824A
Versión de Hardware: H30
Número de serie: SEZAZ2S0183702
Nombre ODX: EV_MUStd6C1TSAT
Versión ODX: 001015
Codificación extendida: 04730200D70A00001111000100080A002F0201D40120010002
Sub sistemas:
Descripción del sistema: ABTm_Std2
Versión de software: 1031
Versión de Hardware: H44
Número de serie: SEZ8Z9SLL01V0U
Codigos de error:
B106113 - Altavoz de agudos delantero izquierdo Interrupción
Esporádica
B110231 - Cámara de marcha atrás no hay señal
Estática
Date: 2017-08-15 15:09:51
Mileage: 13707 km
Prioridad: 3
Contador de la frecuencia con que se producen las averías: 1
Borrador de averías sin confirmar: 152
Datos ambientales dinámicos: 02867A
Podéis echarme una mano?
Leon st fr 2.0 150cv
Alleya
Notapor Tarzan el 15 Ago 2017, 17:19
Ya lo tengo instalado pero no se ve bien, hay interferencias y me salta esto. ImagenImagen
Enviado desde mi SM-G920F mediante Tapatalk
Tarzan
