León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor miguelorly el 22 Ago 2017, 01:02
cvillajos escribió:
miguelorly escribió:
hola,
yo tengo el leon 2.0 tdi 150 cv 2017 (restyling).
esta es la configuración que tendría que poner en mi caso???
Se puede hacer con obdeleven???
y otra cosa, un compañero del foro me podría dejar configurado lo del obdeleven este fin de semana pero la cámara la tengo que pedir y tardaría unas semanas en llegar. hay algún problema por cambiar la configuración y no dejar la cámara puesta??? o eso daría igual.???
estoy leyendo un montón en este hilo pero estoy un poco perdido.
Otra pregunta, he visto esta cámara en aliexpress. Alguien me puede decir si esta en concreto se podría montar o darme una opinión sobre ella???
http://s.aliexpress.com/nAzMvmIn
Yo la 76 no la tengo porque no llevo sensores, pero la 5F la dejé configurada un par de días antes de instalar la cámara, y sin problema... Pantalla negra al engranar marcha atrás y ya. Supongo que con la 76 tampoco habrá problema.
Lo que me tiene intrigado de esa cámara son las líneas de aparcamiento inteligentes... Supongo que se basará en algún sensor de movimiento propio de la cámara, porque no irá conectada al CanBus para "leer" la trayectoria de las ruedas (por lo que he visto en el anuncio). Habría que ver qué tal funciona, y quien sabe... Quizá cambie la mía si va bien...
coño pues si nadie ha probado esa cámara en concreto me da un poco de miedo por si luego algo no va. además veo que tiene ntsc y pal pero lo que viene activado por es ntsc. varios compañeros han escrito que las cámaras SOLO ntsc porque si no dan problemas
cuál es la que está metiendo la gente por aquí??? o me puedes dar alguna recomendación???
en mi coche tengo park assist y navi entonces teniendo eso en cuenta... la configuración de arriba me puede valer o si lo hago así puedo fastidiar alguna cosa??? estoy un poco acojonaete la verdad.
al final me pillé el vag com 17.1.3 porque resulta qeue un amigo lo tiene (versión antigua) y me convenció. me imagino que con este también puedo hacer estos cambios verdad??
Yo la que tengo es esta: http://www.ebay.es/itm/Coche-camara-de-vision-trasera-VW-LUPO-PASSAT-CC-GOLF-4-5-6-MK4-MK5-Seat-Altea-/252093128930?hash=item3ab1ebe0e2:g:nIYAAMXQPW5SDuGn
Es la segunda que monto (a la primera se le fundió el LED a los dos putos meses...) y de momento aguanta bien. Además su luz no es azul, es blanca (no como la primera) así que no tuve que estar jugando con vinilo azul para igualar tonalidades...
Sobre NTCS/PAL ya te han comentado... Mejor solo NTSC o una ya probada.
Sobre la configuración con VagCom y tu equipamiento sí, esa te valdría (es la misma que la indicada en el primer post del hilo).
Por último, el 17.1.3 te valdrá perfectamente... Pero ten en cuenta que a partir de esa versión la centralita 10 es la 76 (que es como siempre debería haber sido).
Muchas gracias por tu ayuda.
Al final he pillado la misma que tú y fuera paso de liarme a probar con cosas que no ha probado nadie y menos no siendo un especialista en montaje.
Ya os contaré
miguelorly
Notapor Leiva20 el 26 Ago 2017, 19:35
Hola a todos.
Acabo de hacer acopio de materiales para instalar la cámara y me surge una duda, el positivo de la luz del maletero es puro no? El positivo de la luz de marcha atras también es puro? Así me ahorro de sacarlo de la luz del maletero..
Leiva20
Coche: Leon MK3 1.5 TGI 130cv
Notapor cvillajos el 28 Ago 2017, 06:47
Leiva20 escribió:Hola a todos.
Que yo sepa la luz del maletero solo lleva corriente cuando abres el portón...
cvillajos
Agradecido: 3613 veces
Notapor Leiva20 el 28 Ago 2017, 09:37
Ya, pero mi intención es poner la cámara usando relé. Si ambas luces llevan positivo puro siempre, cogería + y - de la bombilla de marcha atrás para energizar el relé y ese mismo positivo usarlo para el contacto y encontrar una masa por el maletero y así no tener que utilizar el positivo de la luz de maletero.
Leiva20
Notapor cvillajos el 28 Ago 2017, 11:49
Ok. No es ST el tuyo verdad? Si no, lo más fácil es cogerlo de la toma de USB del maletero... Incluso si me apuras (así te olvidas de relés) en 5P o SC creo que sigue siendo más sencillo tirar cable hacia los fusibles y robarle la corriente al del mechero. Pero tú decides...
Yo la masa se la he puesto en la masa del plafón de la matrícula sustituido.
cvillajos
Notapor Iordee el 28 Ago 2017, 15:15
Un brico, laborioso y meticuloso! bravo! :ok:
Iordee
Notapor Leiva20 el 28 Ago 2017, 15:51
El mio es el león normal, voy a intentar hacerlo con el positivo de la luz de la marcha atrás y masa directa a ver si no da interferencias, todavía tengo tiempo para pensarlo..me tiene que llegar todo el material!
Leiva20
Notapor gesnazo el 01 Sep 2017, 17:51
Hola
Esta cámara valdrá no? Y así se utiliza la luz que lleva.
Es que el mio lleva halógenas en la matrícula y ponerle un led lo hace feo
Mira lo que he encontrado en AliExpress
http://s.aliexpress.com/zIz6NJfE
Eran compatibles con las del golf 6 no?
gesnazo
Notapor cvillajos el 01 Sep 2017, 22:04
La camara valer puede valer (aunque muchas que ponen NTCS PAL dan problemas de imagen porque luego resultan ser PAL), lo que no veo claro es cómo se reutiliza el plafón de serie ahí...
cvillajos
Notapor pirly el 02 Sep 2017, 20:32
cvillajos escribió:La camara valer puede valer (aunque muchas que ponen NTCS PAL dan problemas de imagen porque luego resultan ser PAL), lo que no veo claro es cómo se reutiliza el plafón de serie ahí...
Yo llevo una igual que esa, la bombilla va con una rosca. Simplemente la desenroscas del plafon original y la enroscas en el plafon de la cámara.
pirly
Agradecido: 304 veces
Notapor cvillajos el 02 Sep 2017, 21:02
Ok... No he visto ningún plafón halógeno de cerca, pero si es desenroscar y enroscar entonces será sencillo.
cvillajos
Notapor miguelorly el 11 Sep 2017, 18:33
[/quote]Yo la que tengo es esta: http://www.ebay.es/itm/Coche-camara-de-vision-trasera-VW-LUPO-PASSAT-CC-GOLF-4-5-6-MK4-MK5-Seat-Altea-/252093128930?hash=item3ab1ebe0e2:g:nIYAAMXQPW5SDuGn
Un saludo!![/quote]
@cvillajos en qué me afecta a mí esto?
"Por último, el 17.1.3 te valdrá perfectamente... Pero ten en cuenta que a partir de esa versión la centralita 10 es la 76 (que es como siempre debería haber sido)."
por otro lado como es la primera vez que me pongo a temas de cambiar programaciones estoy muuuuuy acojonaete la verdad. entonces tengo estas preguntas en base al tuto del hilo.
PRIMERA
entramos en stg 5F MMI 3G
yo solo veo el módulo 5F (sin el ªstgª y el MMI 3G) pero entiendo que es lo mismo verdad?
SEGUNDA
cuando accedo al CODING 07 me sale esto
teniendo en cuenta que en el tuto dice que "byte 19 , seleccionar Bit 4 se quedara el valor en 10.
byte 18 , seleccionar Bit 4 se quedara con valor 10"
me imagino que lo que tengo que hacer es pinchar/activar el número que está en la posición 19 que en mi caso es valor "00" y pinchar abajo donde pone bit 4.
luego hacer lo mismo con el 18.
cerrar y en la pantalla anterior darle a "aplicar" . correcto?
TERCERA
siguiendo también el tuto...."entramos en stg 10 park assist <> coding 07 <> y lo dejamos así.,"....
a mí me sale esto que es radicalmente diferente a los valores que salen el tuto.
también es cierto que en el apartado 3 me sale "BYTE 0 = 00000100" y en el tuto "BYTE 2 = 00100101"
a parte de que tiene una serie de opciones en el apartado 4 que a mí no me salen.
entiendo que aquí hay dos opciones,
A- que esos valores y el resto de opciones que ahora mismo no me salen por defecto (en el apartado 4), salgan automáticamente al cambiar los bits que aún no he cambiado (de los que hablo más arriba).
B- que no sea así y yo tenga que poner a mano los mismo valores.
a ver si me podéis indicar por favor porque ya es lo único que me queda por hacer porque ya he hecho toda la instalación de la cámara. Vamos, que sólo que me queda que se vea!!!!!!
Muuuchas gracias
miguelorly
Notapor cvillajos el 12 Sep 2017, 08:10
Primera -> sí, es lo mismo
Segunda -> byte 19 es la posición (cuadradito) 20 y byte 18 es la posición (cuadradito) 19. Empiezan por 0. Una vez en ellos tienes que activar el 'check' que pone bit4
Tercera -> Ese '05' tienes que dejarlo en '25'. Cuando pinches en el byte 2 (cuadradito 3) te aparecerán las opciones del BRICO.
cvillajos
Notapor juanmik el 12 Sep 2017, 12:51
Un saludo!![/quote]
Hola! Muy buen aporte, estoy intentando activar el bit para la cámara, pero me da problemas el Vagcom 17.1.3 "request out of range" en un ST tdi 2.0 150hp de 2014. la centralita 10 es la 76 se refiere al módulo que tengo que entrar?
juanmik
Notapor miguelorly el 12 Sep 2017, 16:36
cvillajos escribió:Primera -> sí, es lo mismo
Pues muchas gracias compi. Ahora sí que lo tengo superclaro.
Menos mal que no hice nada porque no sabía que los bytes se empezaban a contar desde cero.
No sé si la hubiese liado parda pero vamos que me voy a quedar con la duda.
En un ratito me pongo al lío.
miguelorly
