León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor gesnazo el 27 Sep 2017, 07:46
aitor.boller escribió:
gesnazo escribió:Me puede alguien indicar como se quita el plástico negro y la moqueta en un ST?
Las fotos del Brico no sirven para este modelo
El plástico negro tiene como tres tornillos torx
Y la moqueta lateral no se despega y parece pillada por los soportes negros laterales.
Así no se puede llegar al pasacables. Y tampoco sé si hay a los dos lados como en el Brico del 5 puertas.
Buenas compi,
Yo eso lo tuve que desmontar para colocar las luces adicionales al maletero, si quitas los torx llegas a ver los cables de los sensores y alguna cosa mas, y lo de los laterales no recuerdo tanto pero se pueden desmontar, lo miraré yo también porque tengo un ST y estoy preparando la instalación para el brico.
¿De donde eres?
Mañana por la tarde si tengo un rato me lo miro!
De Cartagena. Recuerdas la medida del torx para que me compre un destornillador adecuado?
gesnazo
Notapor gesnazo el 27 Sep 2017, 07:49
Ese plástico negro yo creo que no lo llegué a quitar. Lo que sí quité son todos lo rieles grises de la bandeja del maletero, el portaobjetos de la foto y todo el lateral de la moqueta para acceder al pasacables.
Los rieles te refieres al lateral por donde va la cortinilla del maletero?
Como se quitan?
Yo mirando he pensado que quizás quitando las piezas negras (portaobjetos) de la foto en el lateral y otras adentro que sirven para levantar el suelo valdría para separar la moqueta.
Llevan como una funda negra que tapa un tornillo, pero se la quito y aún así no sale la pieza de plástico
gesnazo
Notapor cvillajos el 27 Sep 2017, 08:03
Como se quitan?
Me refiero a los rieles del falso suelo que lo guían en la doble altura, no los plásticos que guían la cortinilla​. Yo quité los capuchones y tornillos y salieron, luego el portaobjetos y después quité la moqueta lateral.
cvillajos
Agradecido: 3612 veces
Notapor aitor.boller el 27 Sep 2017, 08:28
Esta tarde si puedo yo empezaré algo del brico, te miro la medida del torx y te digo ;)
Seat Leon Mk3 ST 1.6 105cv - Seat Leon Mk2 1.9 90cv CR
aitor.boller
Notapor aitor.boller el 27 Sep 2017, 22:29
Buenas compi! Esta tarde empezado a desmontar maletero jajaja los tornillos torx que preguntabas es T20.
Si necesitas alguna foto mas tengo el coche medio desmontando
Por cierto yo he pasado los cables por otro lado ya pasaré fotos.
Mañana seguiré conectando cableado.
aitor.boller
Notapor gesnazo el 28 Sep 2017, 11:14
Estupendo gracias,
Pues claro, me interesa todo lo que hagas :)
Sobre todo por donde pasas los cables y como quitas la moqueta lateras con esas piezas de plástico que tenemos en el ST
gesnazo
Notapor miguelorly el 30 Sep 2017, 21:14
Al poner la marcha atrás unas veces me sale la imagen (aún con muchísima interferencia, eso sí) y otras veces no me sale imagen. Simplemente negro.
Alguien sabe por donde pueden ir los tiros???
miguelorly
Notapor aitor.boller el 30 Sep 2017, 21:59
gesnazo escribió:Estupendo gracias,
Si cuando continúe ya te pasaré fotos. He hecho agujeros nuevos, más rápido y fácil.
aitor.boller
Notapor aitor.boller el 30 Sep 2017, 22:00
miguelorly escribió:Al poner la marcha atrás unas veces me sale la imagen (aún con muchísima interferencia, eso sí) y otras veces no me sale imagen. Simplemente negro.
¿Has hecho la instalación tal cual pone el brico con el rele y condensador?
aitor.boller
BRICO como instalar la Camara de parking en Seat leon MK3
Notapor gesnazo el 30 Sep 2017, 22:50
Hoy he pasado el cable desde el maletero. Me he dado cuenta al desmontar que los pasacables no son igual que en el 5 puertas.
Al quitar la moqueta de los dos lados se ven pasacables que dan al fondo y en el de la derecha están pasando, supongo que los de los sensores y en el de la izquierda está sin usar.
Ya contaré más cuando continúe.
gesnazo
Notapor miguelorly el 01 Oct 2017, 01:10
He cogido la luz del mechero porque el mio es 5f cinco puertas, le he puesto relé pero condensador no. Hice una prueba con condensador y no me mejoraba la imagen con lo cual no lo dejé puesto. Pero lo de que se empiece a ir la imagen me pasa de 3/4 días para acá.
No obstante en el tuto no he visto yo nada de relé y condensador, eso se le ocurrió a mi suegro que se ha dedicado a mi suegro que se ha dedicado a rollos de estos toda la vida.
miguelorly
Notapor miguelorly el 01 Oct 2017, 01:11
No obstante en el tuto no he visto yo nada de relé y condensador, eso se le ocurrió a mi suegro que se ha dedicado a rollos de estos toda la vida.
miguelorly
Notapor gesnazo el 01 Oct 2017, 10:26
aitor.boller escribió:[ Imagen ]
Por cierto, que son esos dos cables que tienes bajo el embellecedor del maletero?
Yo no tengo ninguno de ellos.
gesnazo
Notapor gesnazo el 01 Oct 2017, 10:42
¿El GND de la camara se puede poner junto al GND de la luz led de la matrícula?
Sería alimentación desde la unidad y gnd en la luz led de matrícula
gesnazo
Notapor Leiva20 el 01 Oct 2017, 13:12
Aun no he instalado la cámara pero esta mañana he codificado con el obd, llevo sensores de aparcamiento y he marcado en el byte 18 el bit 4, en el 19 el bit 4, estando ya marcados 2,6,7. Y en el 76 la opcion con camara marcha atras y me sale el mensaje parkpilot no disponible, los sensores de aparcamiento funcionan perfectamente y se pone la pantalla en negro al meter la marcha atras...alguien me ilumina? Un saludo
Leiva20
Coche: Leon MK3 1.5 TGI 130cv
