León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor jasoriab el 07 Oct 2017, 13:32
t.vazquez escribió:
el_padrino escribió:Con todo el respeto, os vale la pena complicaros la vida de esa manera cuando tirando el positivo a la caja de fusibles queda solucionado y os evitais parasitos?
He instalado 20 camaras, originales eso si, y 0 problemas nunca.
Buenas, yo quiero montar la camara original en mi ST, mas o menos en que precio andan las camaras originales???
A parte de la camara hace falta algun interface o centralita adicional?? con las de Ali veo que no hace falta,pero con la original no lo se.
Según ETKA, sólo la cámara con su cable, son algo más de 158€, una pasta... :cry:
jasoriab
Agradecido: 2053 veces
Notapor el_padrino el 07 Oct 2017, 13:42
No necesitas interface. Tan solo deberas tener un equipo de 5'8" o superior.
La camara sola cuesta esos 160 que dice el compañero, suma el soporte, otros 50, suma el cableado hasta infotainment ( no se vende suelto en Seat)
el_padrino
Agradecido: 65 veces
Notapor igoitia el 07 Oct 2017, 19:52
Buenas tardes;
a ver si me puedes ayudar, monte hace una semana en mi Octavia 2, una cámara de marcha atrás;
el negativo lo cogí de la masa del coche, y el positivo de la luz de marcha atrás, con el motor parado el resultado era excelente, con el motor en marcha la imagen no se veía.
después de leer en varios foros comentaban lo del relé de 4 puntas.me compre uno y lo monte, cogiendo corriente limpia del propio navegador, y ocurría algo parecido, cuando engranaba la marcha atrás el propio relé empezaba a hacer un ruido de parpadeo, esta claro que la corriente que llega a las bobillas de marcha atrás no es nada limpia (canbus) y tampoco conseguí hacer funcionar el tema, lo que no recuerdo las especificaciones del relé,
si utilizo el rele que veo en este foro y el famoso condensador, funcionaria? se ve nítida la imagen?, gracias por la respuesta, imagino que habrá preguntado alguien lo mismo, gracias anticipadas!
igoitia
Notapor el_padrino el 09 Oct 2017, 00:47
En mi anterior respuesta tienes la solucion
positivo a caja fusibles, asi de facil.
saludos.
el_padrino
Notapor Marcos34 el 11 Oct 2017, 11:59
el_padrino escribió:En mi anterior respuesta tienes la solucion
saludos.
Muy buenas, pregunta de novato.
Si cohesión el positivo de la caja de fusibles evitas parásitos y cablear el portón, correcto?
Pero entonces como se enciende la pantalla al meter marcha atrás? No soy capaz de pillarlo.
Muchas gracias de antemano crack.
Marcos34
Notapor cvillajos el 11 Oct 2017, 17:22
saludos.
Tienes que coger positivo de un fusible que lleve siempre corriente de 12v (por ejemplo el mechero).
- Pros: corriente limpia e instalación más sencilla.
- Contras: la cámara va siempre encendida (en función del fusible).
La pantalla se "cambia" (no se enciende, porque va siempre encendida) para mostrar la imagen de la cámara cuando por el can-bus le llega la señal a la 5F de que se ha engranado la marcha atrás.
cvillajos
Agradecido: 3612 veces
Notapor t.vazquez el 12 Oct 2017, 18:49
saludos.
Entonces lo suyo es conectarla a algun positivo que solo se active con la marcha atras?? Cual es la manera mas adecuada de conectarla??
t.vazquez
BRICO como instalar la Camara de parking en Seat leon MK3
Notapor gesnazo el 12 Oct 2017, 21:29
Bueno ya está instalada y dos cosas:
Una que funciona sin el gnd de la cámara conectada !!???
No lo entiendo. El positivo lo saco de la radio android.
Y dos, la luz es muy débil y canta mucho con el otro plafón led que parece una farola.
Como le quito intensidad al otro plafón para igualar?
Le he tenido que poner una resistencia en paralelo al led de la cámara para que no de fallo led. Entiendo que eso en paralelo no quita intensidad a la luz.
gesnazo
Notapor Marcos34 el 14 Oct 2017, 09:16
cvillajos escribió:Tienes que coger positivo de un fusible que lleve siempre corriente de 12v (por ejemplo el mechero).
Ahhh, me parece que ya lo veo. Te estás refiriendo a los pins 6 y 12 de la conexión al quadlock?. Serán los encargados de activar la entrada de la señal de vídeo en la pantalla. Es así, no?
Marcos34
Notapor Dav2k6 el 15 Oct 2017, 11:32
Yo he conseguido la camara original por un modico precio de 40€... Ahora me falta el cableado que intentare fabricarmelo ya que muchos conectores se venden sueltos... Aver que sale de todo esto...
Yo como algun forero prefiero instalar la original a una china...
Seat leon ST FR 150cv
Dav2k6
Notapor cvillajos el 15 Oct 2017, 14:17
Más o menos, sí...
Por los pines 6 y 12 le llega siempre la señal de video al Infotaiment, y cuando por el CAN-BUS se informa que la marcha atrás está engranada el infotainment cambia la pantalla y traspasa el video a la pantalla.
cvillajos
Notapor Marcos34 el 15 Oct 2017, 23:08
[quote="cvillajos"
Más o menos, sí...
Un saludo!![/quote]
Ya está entendido por fin. Muchas gracias por la aclaración.
De verdad, aquí hay mucho curro para llegar a todo lo que sois capaces de hacer. Me quito el sombrero.
Marcos34
Notapor Marcos34 el 16 Oct 2017, 18:01
Dav2k6 escribió:Yo he conseguido la camara original por un modico precio de 40€... Ahora me falta el cableado que intentare fabricarmelo ya que muchos conectores se venden sueltos... Aver que sale de todo esto...
Estoy de acuerdo contigo, mejor (siempre que sea posible) OEM, que los chinorris...
Me interesa mucho el tema. Sigue informando a ver como va saliendo la cosa. :palomitas:
Un saludo...
Marcos34
Notapor Pequenio el 16 Oct 2017, 18:27
Me auto contesto...
Me han contestado desde Audioledcar que no tienen kit de cámara trasera para nuestro Mk3
Pequenio
Agradecido: 41 veces
Notapor aitor.boller el 16 Oct 2017, 22:31
Buenas!!
Hoy ya me a llegado por fin la cámara!!
Estoy a la espera de las llaves para sacar el módulo de la guantera y ya puedo terminar!
Que ganitasss :aplauso:
Seat Leon Mk3 ST 1.6 105cv - Seat Leon Mk2 1.9 90cv CR
aitor.boller
Perdida de potencia motor y Limp Mode!!!
Foro: Leon I - Mecánica / Electricidad / Electrónica
Autor: Paranohia
Respuestas: 2
Encuesta - Que tipo de Gasoil utilizais
Foro: General
Autor: pirly
Respuestas: 299
Manual de taller
Foro: General
Autor: JesusEli
Respuestas: 100
Mejor escape para León cupra
Foro: Tuning
Autor: karmelete300
Respuestas: 100
León Mk3 - Autorradios Android
Foro: AudioCar y MultimediaCar
Autor: ipardoma
Respuestas: 1794
Usuarios navegando por este Foro: Anthropic, Google [Bot], Semrush y 7 invitados
