León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor aitor.boller el 13 Nov 2017, 07:47
Jarman escribió:Se puede coger La Luz de la cámara del aparato de la guantera?
Es que he llevado hasta allí el cable de corriente y el rca y estaría bien poder conectar por ahí
Esta es una prueba que he hecho cogiendo la corriente del mechero de la consola central (con una chapuza). En la imagen parece que se ve bien pero la verdad es que funciona bastante mal...
Buenas compañero,
Yo aún cogiendo la corriente del mechero del maletero, decidí ponerle el condensador, por las posibles interferencias. Y la verdad que lo hice todo como rojas lo puso y cero problemas.
La instalación tardé varios días en hacerla pero lo hacía paso por paso y comprobando que todo funcionaba y probándolo todo para no encontrarme todos los problemas que había leído en en el hilo del post.
A mi me sobraron dos condensadores por si alguien necesita. En aliexpress me venía el pack de 3 y no dudé en comprarlo para evitar sorpresas.
Este es el cable que me hice, soldando y poniéndole un poco de termo retráctil para que quedara mejor
Seat Leon Mk3 ST 1.6 105cv - Seat Leon Mk2 1.9 90cv CR
aitor.boller
Notapor aitor.boller el 13 Nov 2017, 07:50
Buenas compañero,
aitor.boller
Notapor rubo2 el 19 Nov 2017, 10:49
Buenas señores, yo tengo alguna duda con la instalacion que me estoy haciendo, vereis.
Compre una radio 2din china y para poner camara trasera perfecto porque la radio viene preparada con su toma de alimentacion a 12v que se activa unicamente cuando meto la marcha atras asi que esta chupado...
La duda es para una poner camara delantera, que me gustaría que solo estuviera activada, o con alimentación cuando esté el contacto dado, y para esto la radio no trae un cable exclusivo como para la trasera, asi que alguien sabria decirme con los esquemas y las fotos que pongo de donde puedo sacar la alimentación de la camara para que NO esté encendida siempre, y se apague cuando saque la llave?
He estado midiendo con tester los cables originales que le llegan a la radio y veo dos, uno amarillo que no lleva corriente ni con el motor arrancado (no se porque) y el rojo que lleva siempre 12 voltios, incluso cuando saco la llave (dudo si la llave tiene que estar mas tiempo quitada para que deje de llevar voltios el cable).
Por ciero mi coche es un leon 2 (de 2009) creo que lleva canbus, corregidme si me equivoco.
rubo2
Notapor Jarman el 22 Nov 2017, 07:47
Buenas compañero,
Pero supuestamente cogiendo la corriente de la toma del mechero no debería tener interferencias, no?
Es que se ve fatal... se parte como por la mitad la imagen...
Ese condensador donde lo has puesto exactamente, en que cable?
Jarman
Notapor aitor.boller el 22 Nov 2017, 08:25
Tonivn escribió:
aitor.boller escribió:Cámara funcionando!!!
:banana:
Cual has puesto?? Podrías subir un vídeo de cómo te va? Y el color de La Luz de matrícula?
Me interesa el tema.
Buenas compi!
Que no había visto el mensaje...perdona.. la camara es esta:
http://www.dx.com/es/p/eagleyes-ec-th10 ... hUl7VXibcs
Y el vídeo solo lo tengo grabado de noche aquí lo tenéis:
https://youtu.be/NFyTtHmq8pI
Última edición por aitor.boller el 22 Nov 2017, 08:32, editado 1 vez en total
aitor.boller
Notapor aitor.boller el 22 Nov 2017, 08:31
Buenas compañero,
Buenas Jarman,
Te dejo el esquema que seguí yo para mi instalación.
Cualquier cosa hablamos
aitor.boller
Notapor Jarman el 22 Nov 2017, 08:46
Buenas compañero,
Buenas Jarman,
Entiendo que el rele lo has puesto para que la cámara solo tenga corriente cuando metes la marcha atrás, verdad?
Si a mí el punto anterior me da lo mismo, entiendo que con poner el condensador sería suficiente, no?
Jarman
Notapor kuziaa el 22 Nov 2017, 08:52
Muy buenas.
Me encantaria poner la camara trasera.
Alguien por la zona de Barcelona, me la pondria y me lo configuraria.
Previo pago ehhhh :D :D
kuziaa
Agradecido: 33 veces
Notapor el_padrino el 22 Nov 2017, 09:12
kuziaa escribió:Muy buenas.
Hola, en Barcelona te la podemos instalar, concretamente en Gava.
Escribeme a lorenzo.roso@vag-retrofits.com y comentamos.
Enviado desde mi SM-N950F mediante Tapatalk
el_padrino
Agradecido: 65 veces
Notapor JaviMarquez el 22 Nov 2017, 09:36
Buenas! En Madrid dais servicio?
JaviMarquez
Agradecido: 46 veces
Notapor cvillajos el 22 Nov 2017, 12:18
@el_padrino , para no incumplir la normas de "Compra / Venta", te sugiero que la próxima vez redirijas al usuario a la zona donde os anunciais los profesionales y/o a la zona donde os anunciais los particulares para que el usuario mire los posibles instaladores por su zona y os contacte tras evaluar vuestros hilos.
cvillajos
Agradecido: 3613 veces
Notapor el_padrino el 22 Nov 2017, 12:35
Disculpa, gracias!!
el_padrino
Notapor el_padrino el 22 Nov 2017, 12:36
Si, podemos ayudarte, escribenos correo y concretamos.
el_padrino
Notapor juanacho21 el 03 Dic 2017, 21:00
Ante todo, mi agradecimiento a Rojas en especial por el brico y a los componentes del foro por hacer posible todo esto.
He instalado la cámara , comprada por EBay , por 8€ aprox y he conseguido echarla a andar :banana: . Yo tengo el León st 1.6 Stile plus con sensores traseros de septiembre del 2017 y he realizado la instalación desde mechero maletero con relé. La diferencia es que mi relé es de 5 posiciones , ya que tengo unos cuantos de cuando hacia bricos con el BMW, pero es lo mismo. No tengo interferencias en la cámara después de más de 3 semanas de uso. Gracias a todos y espero que los que no la llevan montada tengan suerte/maestría suficiente para hacer el brico.
Yo desmonté las cantoneras del maletero y me encontré un pasa muros bajo la de la derecha(acompañante) por la que baja el cableado de algo, no miré a lo que pertenecía. no me hizo falta ningún condensador. También desmonte las cantoneras del portón para pasar el cable directo desde el conector del plafón de marcha atrás, no me gustó la idea de sacarlo de donde se flexionan los cables al abrir y cerrar este. solo me falta el plafón led de la parte derecha, ya que la cámara está en el izquierdo y me da fallo en luz matricula y la temperatura color es escandalosa :plas: . Ya he resuelto lo del fallo led, solo me falta el color.
Querría preguntar, si alguien lo sabe, como se pueden activar, si es posible, las líneas guías amarillas que se ven en algunas fotos que hay en este Brico.
Repito que gracias a todos.
juanacho21
Notapor cvillajos el 03 Dic 2017, 23:52
juanacho21 escribió:Ante todo, mi agradecimiento a Rojas en especial por el brico y a los componentes del foro por hacer posible todo esto.
Para temperatura del color (es difícil acertar con una cámara al comprarla) te recomiendo lo que hice yo con la primera (la segunda tuve mas suerte) -> Vinilo para faros azul para disminuir la temperatura de la más cálida de ellas o vinilo para faros amarillo para elevarla en el otro. Luego ya depende de la diferencia​ tendrás que aplicar más o menos capas.
Sobre las guías (¿amarillas?). Las cámaras vienen o no con ellas (rojas, amarillas y verdes) según se describa en el artículo. Es decir, las incorporan ellas a la señal de vídeo que toman. Si te refieres a unas líneas amarillas como de "guiado" (giran conforme giras el volante) eso me parece que lo da la centralita propia de la cámara OEM o una cámara High (creo recordar).
cvillajos
