León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor cvillajos el 26 Dic 2017, 07:42
Chema Álvarez escribió:Hola a todos. Me presento. Desde hace un mes y pico tengo un Leon FR MK3 con navegador, y quise instalar una cámara trasera. Para mi, no es complicado hacerlo, puesto que me encanta "fozar" en los coches, instalar radios, etapas, etc. No soy muy negado que digamos sacando y metiendo plçasticos, techos y demás. Bueno, que me lío. La cosa es que he seguido este brico, y he instalado ya el cableado, conectado los pines en el conector azul y demás. Mi problema viene en el momento en el que intento configurar con el vagcom (esto si que es nuevo para mi) hago el primer paso bien (O eso creo). Esta parte:
stg 5F MMI 3G <> Coding - 07 <> byte 19 , seleccionar Bit 4 se quedara el valor en 10.
byte 18 , seleccionar Bit 4 se quedara con valor 10
Esta parte como digo, creo que la hago bien, puesto que no me da ningún error, pero si meto marcha atrás, no cambia nada, la radio sigue siendo radio, ni se ve negro, ni se ve la cámara ni nada.
Ahora, intento hacer el siguiente paso (stg 10 park assist <> coding 07 <>) y me pone como que no lo encuentra. Yo sinceramente creo que estoy entrando donde no debo, pero he intentado encontrar datos mas exactos y nada...
Cabe decir que mi coche no tiene sensores de aparcamiento, y mi cable (chino) es el 12.12.0
Por favor a ver si alguien puede hacer un video o algo así que se entienda bien de los pasos a seguir con el vagcom. Gracias
1.- ¿Tienes sensores de aparcamiento? En caso negativo ni la segunda codificación (byte 18 5F) ni la segunda parte (modulo 10) tienes que hacerla.
2.- Esa versión del VagCom es muy antigua para tu coche y puede darte problemas de codificación. Prueba una más moderna u otro tipo de interface para codificar.
cvillajos
Agradecido: 3613 veces
Notapor Chimguy el 26 Dic 2017, 13:37
jose.jjg307 escribió:
kijute escribió:Bueno pues después de 3 semanas, ya funciona perfectamente.
Enviado desde mi EVA-L09 mediante Tapatalk
Pues a mi me va aveces. Y puse el relex y sigue igual me tiene hasta las narices
Enviado desde mi SM-J320FN mediante Tapatalk
A mi me ocurre exactamente lo mismo,es una loteria, a veces va dos dias otras solo consigo la pantalla en negro y otras aguanta unos segundos y pantalla en negro.
Tras varias pruebas en las que llevaba la instalacion al aire en el maletero, me di cuenta de que en determinada posicion aguantaba mucho mas hasta que se movia , asi que yo intuyo que el problema esta en el cableado de la camara, que era muy pobre y debil y posiblemente venga con algun corte por dentro de la funda.
A ver si saco un rato y lo desmonto y sustituyo.
Chimguy
Agradecido: 76 veces
Notapor kijute el 26 Dic 2017, 15:28
Por si le vale a alguien la información de como lo he puesto en mi x-perience, lo he puesto como dijo @rojas en su posdata.
El cable positivo y negativo de la cámara directo a la luz de marcha atrás.
Y ya que hay que modificar parámetros con vagcom pues modifique este"
1. 09 - Cent. elect.
2. Código de acceso: 31347
3. 10-Adaptación
4. Seleccionar: Leuchte29RFL RA64 - Dimmwert AB 29
5. Cambiar valor a: 127
Y TODO PERFECTO.
nada de pasar más cables, nada de relés, nada de condensadores........ Solo que había que leer bien el brico.
Por si a alguien Le vale la información va perfecto.
Prueba a quitarle el relé y condensador si lo has puesto.
Y pon el positivo y el negativo de la camara, directo al positivo y negativo de la luz de marcha atrás. Sin relés ni nada.
Entra en vagcom y modifica lo siguiente :
3. 10-Adaptación
Y listo.
A mi me va de maravilla
kijute
Agradecido: 9 veces
Notapor sic58 el 01 Ene 2018, 12:08
3. 10-Adaptación
Y TODO PERFECTO.
3. 10-Adaptación
Y listo.
Es decir que con esto así la luz de marcha atrás va normal no por impulsos. Pero para pilotos led igual o hay otra manera?
Por cierto alguien por Valladolid con el cable para hecharme una manita. Gracias
sic58
Agradecido: 9 veces
Notapor yak54 el 01 Ene 2018, 13:14
A mi me tiene también hasta las narices, la tengo conectada al positivo del mechero. Pero Ojo, con el motor parado funciona perfectamente, pero es arrancar el motor y le entran como interferencias y me sale Error del Park Pilot, a ver si alguien me puede decir algo.
Enviado desde mi Redmi 4 mediante Tapatalk
yak54
Agradecido: 116 veces
Notapor sic58 el 03 Ene 2018, 19:36
Pregunta tonta pero los pines para conectar en la radio donde les comprasteis
sic58
Agradecido: 9 veces
Notapor Chema_Alvarez el 03 Ene 2018, 19:39
sic58 escribió:Pregunta tonta pero los pines para conectar en la radio donde les comprasteis
Yo usé pines de Arduino
Enviado desde mi K10000 Max mediante Tapatalk
Chema_Alvarez
Notapor yak54 el 03 Ene 2018, 21:43
20X ecu pequeño Seat terminal engarzado alfileres para reparación de cables N 907 647 01 000 979 009 E Terminal de terminal de cruceros del ECU para VW Skoda VW
http://s.aliexpress.com/YFZJ3QnI?fromSns=Tapatalk
(from AliExpress Android)
Yo los pedí aquí, saludos
yak54
Notapor Vallecas23 el 04 Ene 2018, 21:19
Hola feliz año a todos aver si me podeis contestar e instalado la camara pero me falta cambiar los codigos pero no se donde esta esa pantalla que sale en el brico gracias un saludo
Vallecas23
Notapor cvillajos el 05 Ene 2018, 08:47
Vallecas23 escribió:Hola feliz año a todos aver si me podeis contestar e instalado la camara pero me falta cambiar los codigos pero no se donde esta esa pantalla que sale en el brico gracias un saludo
Esa pantalla es de la centralita del park assist. ¿Tienes sensores de aparcamiento? Si la respuesta es NO, no tienes que hacer este paso (tampoco byte 18 bit 4 de la 5F). Si la respuesta es SÍ, búscala no como stg 10 sino como stg 76.
cvillajos
Notapor Vallecas23 el 05 Ene 2018, 09:31
Hola buenos dias pero como saco esa pantalla centralita del park assist. si tiene sensores
Vallecas23
Notapor Dav2k6 el 05 Ene 2018, 19:35
Hola buenas... Para instalar la camara original?? alguien lo ha echo?
Seat leon ST FR 150cv
Dav2k6
Notapor el_padrino el 05 Ene 2018, 19:45
Dav2k6 escribió:Hola buenas... Para instalar la camara original?? alguien lo ha echo?
Yo las he instalado muchas veces, que necesitas saber?
el_padrino
Agradecido: 65 veces
Notapor Dav2k6 el 05 Ene 2018, 20:34
A parte de la Camara y cableado... lleva centralita aparte?
Mira por etka pero no me sale nada!!!
Dav2k6
Notapor Vallecas23 el 05 Ene 2018, 20:34
Perdonarme soy un poquito torpe como saco la pantalla para poder canbiar y que me salga la camara tiene sensores gracias
Vallecas23
