León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor jasoriab el 03 Oct 2019, 17:01
Cloud_ganora escribió:Alexa? Y que es lo que puede hacer?
Que es lo que se puede hacer con el wifi? Porque yo no lo acabo de entender...
Tienes que instalarte esta aplicación, https://play.google.com/store/apps/deta ... trol.alexa
Además de Alexa, se puede añadir destinos al navegador que trae el coche (en caso que lo tengas), cambiar canciones, volumen, etc, todo esto desde un móvil de un acompañante.
Pero esa no es la temática de este hilo. Puedes usar el buscador que seguro que habrá hilos al respecto en este subforo.
jasoriab
Agradecido: 2055 veces
Notapor cvillajos el 03 Oct 2019, 17:52
Sí, el tema de Alexa se trató aquí concretame: viewtopic.php?f=9&t=128345&hilit=Alexa#p2057804
cvillajos
Agradecido: 3613 veces
Notapor castell_lkpg el 03 Oct 2019, 19:49
Hola a todos!
Soy de Suecia, y he tratado de encontrar cómo cambio
241 a 346.
aparato 5QA035824
hardware H24
software 0241
¿Puedo usar el enlace en la página 41?
aunque sea de 245?
Perdón por el mal español...
(google translate)
/Daniel
castell_lkpg
Notapor juanjol2 el 05 Oct 2019, 13:13
javigody escribió:Bueno pues por fin el compi @stewei y yo hemos conseguido actualizar MIB2 high.
Yo partía de H50 y SW355, mientras que @stewei partía de H42 y SW319. La verdad que he podido notar una mejoría en la fluidez además de las mejoras ya conocidas como el menú mosaico o los diferentes relojes en el modo espera.
Empezamos actualizando a la 674, que ya traía como mejora el menú mosaico. Esta actualización duró en torno a 25 minutos con una sd class 10. Luego pasamos a la versión 818, esta tardó unos 15 minutos y por último actualizamos a la versión 897, tardando tan solo 10 minutos. Tras cada actualización hicimos la comprobación de montaje pertinente para eliminar el fallo, aunque no era necesario.
[ Imagen ][ Imagen ][ Imagen ][ Imagen ][ Imagen ][ Imagen ]
Enviado desde mi SM-G950F mediante Tapatalk
Recientemente he comprado un Seat leon st Fr 1.4 150cv y me gustaría actualizarle el infotainment. Mi hardware es el H50 y SW 355. Paso la foto de la info del sistema para que me confirmes si serviría esta actualización. De ser así, me la podrías pasar?
Gracias de antemano.
juanjol2
Notapor Ropelo el 09 Oct 2019, 18:13
Buenas tengo un infotainment h41 s 468, no tiene navegador. ¿podría actualizarlo y añadirle la opción de navegador?
Ropelo
Coche: Leon MK3 1.2 TSI 110cv
Notapor jasoriab el 09 Oct 2019, 19:11
Ropelo escribió:Buenas tengo un infotainment h41 s 468, no tiene navegador. ¿podría actualizarlo y añadirle la opción de navegador?
Actualizar la versión por el momento sólo en concesionarios (si es que quieren hacértelo, la última versión SW de la que tengamos noticia es la 0475)
Pero para añadir navegador, necesitas cambiar la unidad de guantera por otra que disponga de dicho hardware, además de instalar una antena de recepción de señal GPS. Por software no puedes convertir tu unidad para que tenga navegador.
jasoriab
Notapor Trosk el 10 Oct 2019, 04:07
Hace tiempo aztualice el infortaiment para poner la pantalla de 8, pero desde ese momento me desapareció el ajuste de la pantalla del subwoofer.
Sigue sonando pero no lo puedo regular.
También me da la impresión del q el seat sound system no está activado porque ahora noto q los tweters distorsionan porque intentan sonar como un altavoz normal.
Lo mejor es que fui al concesionario se lo explique y me dijeron que me lo activan sin problema, pero cuando volvo a por el coche me dijeron que no podían hacer nada porque su programa les decía que esa versión de infortaiment era de otro modelo de coche y daba error
Alguien sabe algo?
Trosk
Notapor Sampicoto el 15 Oct 2019, 19:19
Hola!!! Busco la actualización de Software infotainment con Hardware: H41 y Software: 0468.
Ayuda... porfavor!
Seat León 1.2 TSI 110CV (2017- 2018)
Sampicoto
Notapor jasoriab el 16 Oct 2019, 13:03
Sampicoto escribió:Hola!!! Busco la actualización de Software infotainment con Hardware: H41 y Software: 0468.
Ayuda... porfavor!
Dos o tres mensajes arriba en este mismo hilo tienes la respuesta a tu consulta.
jasoriab
Notapor Ropelo el 16 Oct 2019, 13:39
El LECTOR SD reconoce la tarjeta de mapas tengo q añadirle la antena eso es correcto. Pero por software tengo q hacer aparecer la opción
Ropelo
Notapor jasoriab el 16 Oct 2019, 13:58
Ropelo escribió:El LECTOR SD reconoce la tarjeta de mapas tengo q añadirle la antena eso es correcto. Pero por software tengo q hacer aparecer la opción
Hay unidades infotainment con el mismo hardware H41 que no tienen navegador y otras sí. La verdad es que dudo mucho que sólo por software puedas activar el navegador, si no hay ni hardware necesario para tal fin dentro de la unidad, ni licencia de uso, en tu unidad de guantera actual. Al menos, no he leído que alguien haya sido capaz de ello.
Si alguien sabe si es posible por favor que lo indique, pero sinceramente, dudo mucho que se pueda hacer lo que quieres...
jasoriab
Notapor juanbb el 16 Oct 2019, 14:06
Si no lleva entrada de antena gps no podrá, físicamente la unidad no tiene antena por lo que por mucho que reconozca la sd sin antena no irá bien.
juanbb
Agradecido: 355 veces
Notapor cvillajos el 16 Oct 2019, 15:08
Y sin SWAP/FEC tampoco.
cvillajos
Notapor cobrax3 el 23 Oct 2019, 10:29
Hi guys, sorry for posting in english, i can understand spanish, but i'm limited :)
I'm trying to update my navi system with the file that i've found a few pages before, and those instructions for v480.
The problem is that when i push the "update software" button it says that no update found on sd card.
i've put the 2 folders and the txt file to the root of the sd card, tried multiple times, no luck.
What am i doing wrong?
Isn't my unit a mib1 5.8"?
check out the picture
Thank you!
th23autolink_encode_start_140xdyd2W2ltZzoxNDB4ZHlkMl1odHRwcyYjNTg7Ly90aHVtYnMyJiM0NjtpbWFnZWJhbSYjNDY7Y29tL2QwL2IyL2M5L2ViZTljNzEzMjM2Nzk0NjAmIzQ2O2pwZ1svaW1nOjE0MHhkeWQyXQ==th23autolink_encode_end_140xdyd2
cobrax3
Notapor jramis el 23 Oct 2019, 11:19
Teniendo lo siguiente:
Número pieza dispositivo: 5QA035824
Hardware: H24
Software: 0241
Codec media 2101.0.0.8
En el taller me dicen que me han pasado la máquina, pero que no tiene actualización disponible...
Mi fiera: http://www.clubseatleon.net/viewtopic.php?f=43&t=113244
jramis
Agradecido: 16 veces
