León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor cvillajos el 03 Abr 2018, 18:15
AsturTgi escribió:Hola.
A ver si alguien me puede ayudar. Tengo un León de julio del 2017 y le instalé una de las cámaras de plafón que comentabais en este hilo. Lo hice aumentando la intensidad de la luz de marcha atrás con el obd11, y la cámara se ve bien, pero al estar instalada descentrada, no es del todo fiable en las maniobras. Pero bueno, ese no es el mayor problema. Lo mas molesto es que me sale el mensaje de Park Pilot no disponible en pantalla y hasta que no lo acepto no se va. Ya ví que hay mas gente que le pasa, pero a mi no me deja hacer los pasos que recomendáis.
Mi coche trae de serie los sensores traseros de aparcamiento, pero no me los representa en pantalla (OPS). Lo codifiqué solo entrando en la 5F y activando el bit 4 del byte 19 y la cámara se ve bien, pero dando el famoso mensaje.
Activé también el bit4 del byte 18, pero como no cambiaba nada, revertí el cambio.
También intenté activar el bit 0 del byte 2 del modulo 76, a ver si activando la representación en pantalla de los sensores se corregía el fallo, pero me da un mensaje de "función no disponible" y no me deja activarlo.
Pero en la 76 también tendrías que tener el byte2 bit5 activado (no solo el bit0) y esto tiene que ser simultaneo al 5F byte18 bit4 (creo, vamos... Yo no tengo OPS así que solo codifiqué 5F byte19 bit4)
cvillajos
Agradecido: 3612 veces
Notapor AsturTgi el 04 Abr 2018, 10:00
Hola cvillajos. Gracias por la respuesta.
Mi coche, aunque trae los sensores traseros no los representa en pantalla, por lo que tampoco tengo OPS. Mi codificación extendida de la 76 es: 06 00 04 00 01. Cuando intento activar en esta los dos bits del byte 2 dejándolo con valor 25 en lugar del 04 que tengo, es cuando me da error. Realmente no me admite activar el bit 0. Como mucho (no probé a hacerlo solo) me dejará activar el bit 5 sin tocar el bit 0, quedando así el byte con valor 24. El bit 0 creo que es para la representación en pantalla por que intenté hacerlo desde Adaptación y tampoco me deja. ¿Para que es realmente el bit 5?. No recuerdo ahora si llegué a probar a hacer todo lo posible (5F bits 4 de bytes 18 y 19 y en la 76 bit 5 de byte 2 y sin bit 0), a ver si cuando tenga tiempo lo pruebo.
AsturTgi
Coche: Leon MK3 1.5 TGI 130cv
Notapor pixole el 06 Abr 2018, 16:00
Hola @rojas, yo tengo de serie la cámara marcha atrás, si le pongo la cámara delantera también lo puedo conectar a la clavija donde as conectado tu la cámara de marcha atrás?? Y con obdeleven como se codificarla.
Gracias.
pixole
Notapor littleleon13 el 06 Abr 2018, 17:58
Hola todos,
Quiero instalar una camara de parking en mi Leon 5F pero no sé qué llevar (no oficial), me puedes aconsejar ?
littleleon13
Notapor aigort el 10 Abr 2018, 00:03
littleleon13 escribió:Hola todos,
Qué necesitas saber?
Enviado desde mi Mi Note 3 mediante Tapatalk
aigort
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 52 veces
Notapor littleleon13 el 10 Abr 2018, 11:10
Que camera poner ? una referencia ? Gracias
littleleon13
Notapor Edu1589 el 11 Abr 2018, 02:59
Yo también voy a instalarme aunque no se muy bien donde la cámara delantera, digo esto xq todavía no me ha llegado y no se si entrará en la calandra de abajo que tiene forma de panal, mas o menos, voy a darle los 12v desde el quadlock con un interruptor a mano y la señal de vídeo voy directamente a montarle un conector de RCA doble para que se vea al gusto del conductor jejejejeje.
Enviado desde mi SM-G900F mediante Tapatalk
Edu1589
Agradecido: 9 veces
Notapor AsturTgi el 12 Abr 2018, 11:15
Un saludo!![/quote]
Ayer activé también el bit 4 del bit 18 de la 5F y el bit 5 del byte 2 de la 76 y como os decía, no me deja activar el bi 0 del byte 2 de la 76. Sigue funcionando todo igual, osea, no tengo OPS en pantalla y la camara funciona pero me sale el mensaje de park pilot no disponible.
¿Alguna idea/sugerencia?
Gracias.
AsturTgi
Notapor autobusero el 12 Abr 2018, 15:44
Buenas sabeis de algun sitio en madrid o alrededores que monten la camara de marcha atras?
autobusero
Notapor pixole el 13 Abr 2018, 20:25
Hola, alguien me puede explicar cómo conectar el conmutador para poner la cámara delantera si ya tengo la cámara trasera de serie en los pines azules.
pixole
Notapor yak54 el 13 Abr 2018, 22:04
Edu1589 escribió:Yo también voy a instalarme aunque no se muy bien donde la cámara delantera, digo esto xq todavía no me ha llegado y no se si entrará en la calandra de abajo que tiene forma de panal, mas o menos, voy a darle los 12v desde el quadlock con un interruptor a mano y la señal de vídeo voy directamente a montarle un conector de RCA doble para que se vea al gusto del conductor jejejejeje.
Creo que te estás liando demasiado con la instalación, dale un vistazo a este tema :
viewtopic.php?t=120630
yak54
Agradecido: 116 veces
Notapor Edu1589 el 14 Abr 2018, 03:40
Muchas gracias
Edu1589
Agradecido: 9 veces
Notapor Daruma el 20 Abr 2018, 18:54
Hola buenas tardes.
Estoy con la cosa de animarme a poner la cámara trasera a mi St cupra 290, llevo to la tarde leyendo el post empapándome como conectarla y esa parte parece la tengo más o menos claro, pero tengo la duda siguiente:
Podrían poner algún enlace de la cámara que se esta montando últimamente o que os valla bien.
La conexión la hago a través de la marcha atrás o del mechero del maletero?
Dejo aquí algunos datos de lo que llevo por si son referentes para en algún caso
Pantalla de 6.5 con navegador y full link.
Full Led
ObdEleven
Muchas gracias por el curro del tutorial.
Un saludo y gracias.
Daruma
Notapor SalvaDamian el 23 Abr 2018, 20:46
Excelente y muy currado brico. gracias. Saludos.
SalvaDamian
Notapor JoSeLuXIV el 23 Abr 2018, 23:38
Me podéis decir codificación para OBDeleven con OPS que bits tengo q cambiar o activar. Gracias
Enviado desde mi LG-H815 mediante Tapatalk
JoSeLuXIV
