León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor cvillajos el 16 May 2018, 23:01
maximo1972 escribió:Alguien me puede ayudar?Mi ultima duda que tengo es como se mete los dos terminales del cable de la cámara al conector azul, he visto que el terminal tiene varias caras y cual seria la posición para empujar el terminal?
Tienes que crimpar con fakra ambos y luego a los pines 6 y 12 como se indica en el primer post del hilo.
cvillajos
Agradecido: 3613 veces
Notapor yak54 el 16 May 2018, 23:15
El terminal tiene posición, si lo miras de frente verás que tiene la parte cuadrada y un pequeño saliente, es decir, tiene forma de "d". Esa misma forma la verás por la parte trasera del conector azul. Además tiene una "rampa" que hará clic al encajar y que debe quedar hacia fuera del conector para poder presionarla en caso de querer extraer el pin del conector, espero haberte ayudado.
yak54
Agradecido: 116 veces
Notapor maximo1972 el 17 May 2018, 11:28
Gracias a los dos me habéis ayudado.
maximo1972
Notapor -antero- el 19 May 2018, 16:19
Hello to all!
Sorry for writing in English :)
Can anyone tell me what coding needs to be done with obdeleven to activate highline camera? I have everything connected but no video.
And maybe someone has picture of the CAN highlow connection also? I have two orange/brown wires in the gray quadlock and don't know which one is the correct one.
So far I have done:
Activate VPS
Changed VPS_0X0B_msg_bus to Fahrwerk
In gateway 19 activated rückfahrkamerasystem and einparkhilfe
Problem is that in obdeleven when I open the 6c menu it doesnt respond, says that check ignition. So I think that my cable connections are messed up.
My wire connections:
https://www.upload.ee/image/8455877/CONN.jpg
https://www.upload.ee/image/8455985/IMG_4955.JPG
Power comes from the big plug behind the mib, red/yellow and ground is connected in the boot with other ground connetions. The one that is on the wheelarch.
Please help me :)
-antero-
Notapor yoque el 25 May 2018, 15:50
-antero- escribió:Hello to all!
So far I have done:
Activate VPS
Please help me :)
I've no clue, sorry. But what I can do is translate your post into Spanish and hope there is someone willing to help
"Hola a todos!
puede alguien decirme qué codificación se necesita en el obdeleven para activar la cámara de aparcamiento? tengo todo conectado, pero sigue sin haber video.
teneis alguno foto de la conexion del CAN? tengo dos cables marron/naranja en el conector gris y no se cuál de ellos es el bueno.
hasta ahora he:
Activado VPS
Cambiado VPS_0X0B_msg_bus a Fahrwerk
En gateway 19 activado rückfahrkamerasystem and einparkhilfe
La movida es que cuando abro en el obdeleven el menú 6c, no responde y dice que compruebe el encendido... así que creo que las conexiones están hechas un puto desastre.
ahora mismo están así:
La luz la cojo del enchufe gordo que hay detrás del mib (npi de qué mierda es esto), los cables rojo/amarillo y tierra están enchufados al arranque junto a otras conexiones. La que está donde las aletas de las ruedas.
Me echais una manita porfis?"
Mi inglés no es muy allá, pero asi si alguien sabe a qué se puede estar refiriendo y tal... pues más posibilidades hay de poder echarle un cable
yoque
Coche: Leon MK3 1.4 TSI 122cv
Agradecido: 9 veces
Notapor pacoooooo el 28 May 2018, 20:21
Hola muy buenas tardes.
me estoy leyendo el post, pero me estoy haciendo un lio, quiero instalar solo la cámara delantera, yo tengo un MY18 con los sensores de aparcamiento y la cámara de serie trasera, también tengo el naviplus, por lo que leo, veo que el manual es para otros My , alguien me puede explicar lo que tengo que hacer?
Gracias por adelantado.
pacoooooo
Agradecido: 41 veces
Notapor Dav2k6 el 02 Jun 2018, 21:06
Hola, he conseguido una camara original...
Alguien sabe algo del conecxionado en estos casos??
Estoy mirando de comprar los cables aver si los puedo conseguir o comprar conectores y hacerlos yo...
Seat leon ST FR 150cv
Dav2k6
Notapor nenazojuanma el 04 Jun 2018, 02:51
pacoooooo escribió:Hola muy buenas tardes.
Buenas, tu que tienes la camara trasera de serie, te sale las lineas de la trayectoria?
Por que para adelante si que me sale la trayectoria pero marcha atras salen lineas pero no son de trayectoria.
nenazojuanma
Agradecido: 15 veces
Notapor pacoooooo el 04 Jun 2018, 10:32
A mi si me salen las rayas, pero la camara que yo tengo de serie, ya me viene instalada con el coche nuevo, no es que yo la haya instalado despues
pacoooooo
Notapor nenazojuanma el 04 Jun 2018, 23:10
pacoooooo escribió:A mi si me salen las rayas, pero la camara que yo tengo de serie, ya me viene instalada con el coche nuevo, no es que yo la haya instalado despues
Sé que tu tienes la camara de serie,yo tambien la tengo, pero ami cuando le doy marcha atras y se enciende la camara no me salen las lineas de la trayectoria
nenazojuanma
Notapor owlperformance el 19 Jun 2018, 00:39
Eres un maquina. Todo mi crédito para ti: https://youtu.be/5W1T9i5hLJc
owlperformance
Notapor Maikermx el 03 Jul 2018, 22:31
Excelente brico, muchas gracias rojas!!!, estoy por instalar la camara en mi coche, tengo ya casi todo lo necesario.
Por cierto alguien hizo el orificio en el paragolpes con una broca especial?
Maikermx
Notapor suanz el 06 Jul 2018, 11:27
Hola a todos,
Estoy poniendo la camara inalambrica a mi RNS315 y cual es mi sorpresa que cuando voy a comprar el convertidor de RCA a RGB todos los vendedores de alixpress indican que no valen para los modelos con el conector de 26pines de color negro, que tiene que ser amarillo:
Por otro lado, pone que tiene que tener la tecla "NAV" en el lado derecho arriba, el mio lo tiene
y por ultimo he visto en otros vendedores que es aplicable solo al modelo RCD510....
en cambio este otro vendedor no indica nada no hace distinción con lo del conector amarillo:
https://es.aliexpress.com/store/product/BODENLA-For-VW-RNS510-RCD510-RNS315-AV-decoder-video-Converter-Box-rear-view-camera-CVBS-to/3150026_32829010068.html?spm=a219c.search0204.3.40.12211594XvKZyQ&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_10547_10342_10343_10340_10548_10341_10696_10084_10083_10618_10307_10820_10821_10301_10303_10059_100031_524_10103_10624_10623_10622_10621_10620-normal#cfs,searchweb201603_1,ppcSwitch_2_ppcChannel&algo_expid=4048e9df-ab72-4b3e-87a4-5972358710fa-5&algo_pvid=4048e9df-ab72-4b3e-87a4-5972358710fa&transAbTest=ae803_2&priceBeautifyAB=0
En definitiva...que estoy hecho un lio....
suanz
Notapor suanz el 08 Jul 2018, 21:21
a ver si alguien me arroja algo de luz, que tengo medio coche desmontado a la mujer.
Gracias de antemano
suanz
Notapor Chimguy el 08 Jul 2018, 23:37
Si los chinos te advierten que no sirve para el conector negro, es por que lo saben con certeza. Alguna diferencia mas debe de haber entre los aparatos de conector negro y amarillo, aunque yo desconozco cual.
Chimguy
Agradecido: 76 veces
Usuarios navegando por este Foro: Anthropic, Google [Bot] y 0 invitados
