León Mk3 - BRICO - Como instalar la cámara de parking
- Seguidores: 136
- Favoritos: 46
- Vistas: 604.913
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Buenas querría saber de qué color son los cables que entran en los pines 6 i 12 por que tengo 3 cables rojo amarillo i negro ai que poner 2 juntos o algo espero respuesta gracias
Franciscomarquez21 - Nuev@ por aqui
De qué colores son los cables k van en los pines mi cable tiene 3 colores rojo amarillo i negro me podéis ayudar un saludo gracias
miceor escribió:Yo no la llevo en los plafones.
Desmonté el paragolpes trasero y la puse en el centro haciendo un taladro que coincide con un hueco que hay en la tiranta metalica de la trasera.
La compré por ebay, muy similar a esta :
http://www.ebay.es/itm/170-Universal-Co ... Swq19XBjy3
Me costó 12 lereles.
Hola miceor,
Te comento y a todos que este es mi primer brico por completar; les agradezco por sus aportaciones, especialmente a @rojas.
Por lo que veo resulta sencillo hacer el taladro; pero no estoy seguro aun si la marca donde va el hueco es de la medida del cubo de la camara;
He conseguido el arnes en aliexpress; y la camara de un jetta; antes de instalarla me gustaria primero hacerle una prueba conectandola a la MIB; pues quiero aprovechar para montar los arneses del BRD+RCA y los sensores laterales para montarlos todo a la vez.
Maikermx - Nuev@ por aqui
- Agradecido: 4 veces
Alguien a conseguido poner la camara marcha atras en la pantalla a color de 5"??
Kilometrero - Nuev@ por aqui
Muy buenas, nuevo en el foro y haciendole a mi león varias cosas. He seguido a @rojas y he puesto la cámara trasera. Todo perfecto excepto al codificar. Tras dejarlo como en el briko, yo al poner marcha atras solo veo la cámara, al quitarla vuelvo a ver el OPS. Nose por que no se me pone en pequeño a la izquierda. Si me pudiéseis ayudar lo agradezco, un saludo.
ogpedriyog - Nuev@ por aqui
Una duda que me surge, se podría poner una cámara en la luz de freno?
estas que vienen sin angulo con el propio angulo de la forma donde va la luz del cristal del portón o dándoselo con soporte.
Estoy tentado, seria menos cables, mas practico y protegida de los choques ademas porque seria como los coches que traen las cámaras 360 panorámicas desde mas arriba viendo mas angulo si cabe no?
que os parece? juntad cabezas y decidme que se os ocurre pros y contras porque estoy decidido a probarlo...
Entiendo que las lineas no debería llevarlas porque guiaría desde una pos mas alta y no valdría?¿ o si?
Jolin que pena no tener una cam para hacer un test.
1.4 FR TSI REPRO STAGE 2 + 50 MODS y siempre trasteando...
+ Cupra leon JIBRIDADO 245, poder electrico.
LEONSELVATICO - Asidu@ en la selva
- Coche: Cupra Leon 1.4 e-HYBRID 245cv
- Agradecido: 21 veces
Pantalla 5,8 no compatible, nose que hacer
Hola a todos
Lo primero de todo dar las gracias a rojas por otro maravilloso brico.
En mi caso, tengo la pantalla de 5,8 5F0035871 B, y despues de dos dias dandole vueltas al brico de porque no me iba me doy cuenta que la propia radio no trae los pines 6 y 12 para la camara rca, imaginar mi cara..
Mi gozo en un pozo.. que consejo me dariais?? Muchas gracias chicos
Leoncity - Nuev@ por aqui
Buenas tardes,
Para hacer un pequeño resumen.......
Tengo un Leon ST MY18 con la pantalla de 8 y los sensores de aparcamiento con OPS. Después de leerme todo el hilo....a ver si es correcto por donde voy:
Voy a comprar esto:
https://es.aliexpress.com/item/Mini-Wat ... 63c0icwid7
https://es.aliexpress.com/item/Car-MIB- ... 63c0icwid7
Y lo haré con estas indicaciones que he recopilado:
Cable corriente directamente a la luz de marcha atrás:
-Azul/negro - positivo
-Marron - Masa
(o si veo que se me complica a la toma del mechero del maletero)
Cable video:
-pin 6 positivo
-pin 12 negativo
Y con la siguiente codificación (a traves de OBD11):
- 5F - Coding - 07
byte 18, seleccionar Bit 4
byte 19, seleccionar Bit 4
- 10 park assist - Coding 07
byte 2, seleccionar Bit 0 (ya estaría)
byte 2, seleccionar Bit 5
1. 09 - Cent. elect.
2. Código de acceso: 31347
3. 10-Adaptación
4. Seleccionar: Leuchte29RFL RA64 - Dimmwert AB 29
5. Cambiar valor a: 127
Es correcto??? @miceor, @rojas, @el_padrino, iluminadme!!
Saludos!!!!
Voy a comprar esto:
-Marron - Masa
Cable video:
-pin 6 positivo
-pin 12 negativo
- 5F - Coding - 07
3. 10-Adaptación
Saludos!!!!
fegavo - Asidu@ en la selva
- Agradecido: 42 veces
fegavo escribió:Buenas tardes,
Hola Fegavo. Te respondo desde aquí, ya que no puedo hacerlo desde el privado al tener poca actividad en el foro.
No conseguí activar el bit 0 del byte 2 del modulo 76, por lo que ni tengo representación de los sensores traseros ni conseguí que no me dé el mensaje de Park Pilot no disponible. Supongo que la versión de mi coche (Style plus) no lo permite.
AsturTgi - Nuev@ por aqui
- Agradecido: 6 veces
AsturTgi escribió:fegavo escribió:Buenas tardes,
Pero...antes de ponerla cámara te aparecían???? Que “MY” tienes?
Franciscomarquez21 escribió:Buenas querría saber de qué color son los cables que entran en los pines 6 i 12 por que tengo 3 cables rojo amarillo i negro ai que poner 2 juntos o algo espero respuesta gracias
Si lees bien el brico verás que el negro va a masa, el rojo a la luz de marcha atrás y el amarillo es la señal de la cámara que va a la unidad de guantera. Saludos
Aunque ahora con culo(st) desde 2003 enamorado de la fiera de seat
Se agradece dándole al
Pedrost - Aqui + que con la novi@
- Agradecido: 281 veces
Kilometrero escribió:Alguien a conseguido poner la camara marcha atras en la pantalla a color de 5"??
En la 5" no sé puede, solo de 5.8" en adelante, yo cambie a 6.5" por lo mismo. Saludos
Voy a comprar esto:
-Marron - Masa
Cable video:
-pin 6 positivo
-pin 12 negativo
- 5F - Coding - 07
3. 10-Adaptación
Saludos!!!!
Yo tengo esa cámara sin led y va bastante bien, el cable si quieres no hace falta, puedes conectarlo con su correspondiente pin que por el hilo dicen cual es directamente al conector que va a la unidad de guantera. Por lo demás está todo bien. Saludos
fegavo escribió:AsturTgi escribió:fegavo escribió:Buenas tardes,
No. De origen solo tengo el aviso sonoro de los sensores traseros (no tiene delanteros) y no los representa en pantalla. El MY creo que es el 18, el coche está fabricado de julio de 2017.
Hola buenas me he estado mirando para poner la cámara, en AliExpress he visto esto: http://s.aliexpress.com/EBRBzeqm?fromSns=Copy to Clipboard
¿Esto también hace la función del relé?
Igual os puede servir
Enviado desde mi Aquaris X Pro mediante Tapatalk
Linker89 - Nuev@ por aqui
Que aceite le pongo. Seat leon mk3 diesel 105cv Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: Fenix87 Respuestas: 0 |
Virtual Cockpit Leon mk4 Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: Yundas Respuestas: 398 |
Problema con aire acondicionado León fr mk1 Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Paranohia Respuestas: 12 |
No me funciona la luz ambiental!! Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Paranohia Respuestas: 11 |
Reequipar camara high Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: hanniballecter Respuestas: 437 |
Usuarios navegando por este Foro: Anthropic, Majestic-12 [Bot] y 0 invitados
