León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor aprietatuercas1974 el 17 Ene 2020, 07:36
Porruso escribió:
aprietatuercas1974 escribió:
corderazo escribió:Y no se puede instalar el software o firmware desde un pendrive ni nada??
se instala desde una tarjeta sd desde el mismo equipo
Aprieta tuercas podrias darme algun contacto para hablar contigo para unas dudillas que tengo?? Gracias de ante mano!!
Enviado mensaje privado
aprietatuercas1974
Agradecido: 358 veces
Notapor jasoriab el 17 Ene 2020, 08:41
jasoriab escribió:@F1sergi como último recurso, siempre pruedes ir a un concesionario SEAT, y que te apliquen la configuración original que llevase tu unidad 5F de fábrica, ya que en función del nº de bastidor, se conectan a la central, se la bajan y aplican.
Lo que ya no sé es cuanto te pueden cobrar por ello.
Por desgracia esto no es asi,si se ha actualizado y muy en especial estas versiones que ya dije en varias ocasiones que la 0346 no es oficial es una beta con bug,al conectarse al servidor te compara la version que tiene guardada con la que lleva el coche y al no ser la misma te da un error y no continua.
Es un problema,pero como no se ha hecho el proceso en Seat y ha quedado actualizado el cambio no es valido,(ademas que en la version mencionada 0346 no se podria hacer puesto que en concesionario no existe tal version).Se debe de hacer manualmente y buscar el problema
Entiendo entonces, que para aquellos compañeros que hayan instalado manualmente la versión de SW 0346 en sus H24, la única opción de actualizar es contactar con alguien que tenga acceso a los archivos de versiones superiores que estén en el servidor de actualización de SEAT, y actualizarlo a mano a través de la SD, ¿No?
jasoriab
Agradecido: 2053 veces
Notapor Niccok el 18 Ene 2020, 11:04
Buenos días.
Sabe alguno si hay actualización para esta versión .
Número de pieza: 5QA035824A
Hardware h30
Software 0531
Niccok
Notapor Gendos22 el 18 Ene 2020, 11:37
Niccok escribió:Buenos días.
Hardware h30
Software 0531
Parece que no. He mirado y no me sale nada
Отправлено с моего SM-N960F через Tapatalk
Gendos22
Agradecido: 82 veces
Notapor F1sergi el 18 Ene 2020, 12:29
Anto2 escribió:
F1sergi escribió:
Anto2 escribió:
F1sergi escribió:Si lo he hecho, hasta poner offroad con techo panorámico, pero haga lo que haga sale un Seat León 5 puertas y no varía ni de versión, ni Ibiza ni Toledo, siempre un Seat León 5p y no varía, ni cambiando lo del logo que también hace que varíe la equipación de modelo....
Hola, yo he tenido un Toledo y me pasó lo mismo, tardé bastante en conseguir que me volviera a salir combinando las opciones, tengo una captura de pantalla de la 5F de como quedó para que saliera, ponlo igual que seguro que te vuelve el Toledo.
Imagino que el tuyo es con GPS integrado no? El mío full link Solo, cuando metí la primera actualización si salía el toledo, con la segunda sale el león y no cambia.. puedes decirme porfavor el byte 17 y 18 como lo tienes? Y luego en el apartado del climatizador si tienes puesto como berlina?
Gracias ;)
si, el mio tiene el GPS y el climatizador lo tengo en Berlina.
te paso mas capturas de la 5F, si necesitas comprobar algo más solo tienes que pedirlo.
Sería mucho pedirte que me pasarás completo el 5f de cómo lo tienes y el 9(centralita electrónica) jej
F1sergi
Notapor Nelson Pirez el 23 Ene 2020, 08:51
Buenos dias, necesito información, tengo un seat leon 5f FR 2013/08 con radio gps 5.8 con seat sound, así que vi que el software es de 2013 y tengo algunas dudas:
1- No puedo poner carbono (CUPRA) en la pantalla o en el cuadrante
2- Instalé una cámara trasera del seat leon 5f original y el marco negro cubre la mitad de la pantalla y no es transparente
Qué puedo hacer para resolver estos problemas?
Nelson Pirez
Agradecido: 109 veces
Notapor cvillajos el 23 Ene 2020, 09:20
Nelson Pirez escribió:Buenos dias, necesito información, tengo un seat leon 5f FR 2013/08 con radio gps 5.8 con seat sound, así que vi que el software es de 2013 y tengo algunas dudas:
Creo que los mejores hilos donde puedes buscar, leer, revisar y (en caso de no encontrar solución a tus problemas) comentar, son éstos:
- MOD fondo carbono: viewtopic.php?f=8&t=103527#p1693444 (o también en los genéricos de VagCom u OBDeleven se habla bastante de problemas en la activación del MOD).
- Cámara de marcha atrás: viewtopic.php?f=9&t=106679 (una foto del problema ayudaría a poner en contexto).
Porque entiendo que lo que describes no son problemas derivados de una actualización del software.
cvillajos
Agradecido: 3612 veces
Notapor Nelson Pirez el 23 Ene 2020, 12:19
Gracias por la ayuda, ya hice todo lo relacionado con la codificación, reinicio como está en el Foro pero sigue sin fondo de carbono,hoy tomaré algunas fotos para ver el marco negro de la cámara en reversa!
No sé si será porque el software es antiguo (2013)?
Nelson Pirez
Notapor jasoriab el 23 Ene 2020, 13:11
Nelson Pirez escribió:Gracias por la ayuda, ya hice todo lo relacionado con la codificación, reinicio como está en el Foro pero sigue sin fondo de carbono,hoy tomaré algunas fotos para ver el marco negro de la cámara en reversa!
En la primera página de este hilo, viewtopic.php?f=8&t=103527#p1693444 informan que lo han podido activar con coches del 2013.
Lee todo el hilo, y comprueba las modificaciones que has realizado.
jasoriab
Notapor Nelson Pirez el 23 Ene 2020, 14:33
Gracias amigo, hoy lo intentaré a final de la tarde.
Saludos cordiales
Nelson Pirez
Notapor carlo13 el 23 Ene 2020, 17:38
pues hoy he recogido mi leon del taller ya que cuando conectaba mi movil se apagaba la pantalla y se volvia loca y lo que me han hecho ha sido actualizacion de software.
aqui os dejo una fotillo de cual es.
https://subefotos.com/ver/?a03b68435dc0 ... ba1eao.jpg
carlo13
Agradecido: 10 veces
Notapor jasoriab el 23 Ene 2020, 18:34
carlo13 escribió:pues hoy he recogido mi leon del taller ya que cuando conectaba mi movil se apagaba la pantalla y se volvia loca y lo que me han hecho ha sido actualizacion de software.
Gracias @carlo13 :ok:
Lo pongo por escrito, para que pueda aparecer la información si se usa el buscador.
Referencia: 5F0035824C
Hardware: H50
Software: 0515
jasoriab
Notapor carlo13 el 23 Ene 2020, 19:08
Hardware: H50
Software: 0515
Ya veo que no se ve la foto a traves de tapatalk ahora cuando pueda la vuelvo a subir
carlo13
Notapor carlo13 el 23 Ene 2020, 19:09
Esta es la buenaImagen
carlo13
Notapor hector37 el 26 Ene 2020, 09:02
Ayax_Cupra escribió:Confirmado, si se puede actualizar la versión MIB2 high con Gps, full link y disco duro con pantalla de 8” con H50 y SW355, En todo el hilo solo podréis encontrar información al respecto sobre esta versión en la página 101, me leí todo el hilo y no hay nada para esta versión, hasta que encontré en la página 101 el comentario de un compañero el cual me hizo ver algo de luz, a un módico precio, muchas gracias. :reverencia:
Podriais poner en el indice que ya se puede actualizar esta versión, para que los futuros compañeros no se tengan que leer hasta la página 101 para encontrar algo de información.
Boton full Link en 8” ya operativo y como no los iconos en formato mosaico :banana:
Salu2!
No tendrás la versión para actualizar la de 8" sin navegador???
lytry40
hector37
Usuarios navegando por este Foro: Anthropic, Majestic-12 [Bot], Semrush y 8 invitados
