León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor Peuero el 18 Ene 2015, 13:30
rojas escribió:vale , el rojo no se utiliza , a no ser que tengas un equipo / pantalla china . solo usa el amarillo y el negro , el rojo es para mandar corriente a la camara y hacer el cambio de pantalla al engranar la marcha atras , pero si lo estas haciendo en el equipo de serie no te vale para nada .
Pues entonces no se que debe de ser... :( :(
Peuero
Coche: Leon MK3 1.5 TGI 130cv
Notapor rojas el 18 Ene 2015, 14:01
haz lo siguiente :
vuelve a comprobar el funcionamiento de la camara en el tv de casa , usando el negro como masa y el amarillo como positivo , con 12v.
si sigue funcionando correctamente ve al coche , vamos a comprobar el rca del quadlock , para ver que esta bien conectado y se visualiza el video en la pantalla : para ello revisa que has conectado correctamente el rca en el quadlock , usa cualquier fuente de video , una camara de fotos/video , movil ,lo que tengas a mano , si esta bien hecha la conexion del positivo del rca al pin 6 y masa del rca al pin 12 deberias ver la fuente de video en la pantalla al engranar la marcha atras.
ya tendriamos comprobado el buen funcionamiento del rca del quadlock y el de la camara , si quieres seguir probando usa ya la camara en la parte delantera directamente en el rca del quadlock , alimentala con 12v del mechero y pruebala al engranar la marcha atras .
si funciona , ya no hay mas pruebas que hacer ...
la colocamosatras en su sitio , hacemos las conexiones y trabajo concluido !
si en todo el proceso de comprobaciones hay algun punto donde falle ,subsanalo , si no te seguira sin funcionar cuando la pongas atras .
suerte !! ya nos cuentas ...
rojas
Agradecido: 1889 veces
Notapor Peuero el 18 Ene 2015, 16:01
Los problemas crecen...
La cámara probada en tv ok, las conexiones de los pines ok, ya que he puesto una tv dentro del coche y y funciona, pero no a la pantalla de seat... He probado otra camara y en la tv funciona y en la pantalla seat no, la continuidad de los cables ok... Solo podria ser la configuracion del vag-com, pero no se que mas hacerle...
Peuero
Notapor rojas el 18 Ene 2015, 16:29
A ver ... no me ha quedado muy claro lo de los pines ... se ve la imagen de video en la pantalla del coche conectando otra fuente de video? ... recuerda positivo pin 6 masa pin 12
rojas
Notapor rojas el 18 Ene 2015, 16:35
En la codiniciación bite 18 activas el bit 4
Y en el bite 19 activas el bit 4 también.
rojas
Notapor Peuero el 18 Ene 2015, 16:38
Problema casi resuelto, he cambiado el cable rca de punta a punta con conector y pines incluidos y funciona pero con interferencias gravísimas, con el contacto se ve rallado, y si piso el freno o arranco se pone negro.
Peuero
Notapor rojas el 18 Ene 2015, 16:43
Pues ya lo tienes listo ! ... cogemos corriente del mechero o compra un filitro en una tienda de elecrónica. Hay uno perfecto en ebay que han posteado en este hilo
rojas
Notapor Peuero el 18 Ene 2015, 18:21
rojas escribió:
galaxis escribió:Hola Rojas
¿Me podrías confirmar si la luz del maletero es un positivo puro? y en caso de no lo fuera, ¿hay algún positivo puro en el maletero o hay que cogerlo necesariamente de la caja de fusibles?
Muchas gracias
no , en el maletero no hay ... solo los ST , que llevan toma de mechero en el maletero
ese de 20A amarillo marcado con un circulo es el de mechero ... si pones este adaptador :
le pones un fusible independiente para la camara
Me podriais indicar donde se encuentran estos fusibles? O solo son los ST?
Peuero
Notapor rojas el 18 Ene 2015, 21:01
la primera imagen es del panel de fusibles , todos los tenemos en el mismo sitio , el fusible del mechero es el que esta rodeado con un circulo , es de 20A ... la 2ª imagen es un adaptador para sacar otro circuito bajo fusible aprovechando el zocalo del mismo ... la imagen habla por si sola , de esta forma no tienes ni que retirar todo el modulo de fusibles para utilizar la instalacion existente . puse incluso un link de compra ... es baratito .
rojas
Notapor piuset el 19 Ene 2015, 08:58
Tremendo trabajo rojas.
Para quien pueda interesar, aparte de todo lo anterior para la instalación, he cogido esto para evitar el fallo del led de la camara al desmontar el plafon original. http://m.ebay.es/itm/261529504414?nav=SEARCH
Un salydo!
piuset
Notapor Hecson.27 el 19 Ene 2015, 18:02
A mi no me da error de luz fundida.
Hecson.27
Notapor Martín st el 19 Ene 2015, 20:09
Buenas, mi gozo en un pozo al final no encuentro a nadie que me realice la intalacion de la cámara xd, alguien de Barcelona que me heche una mano si conoce un taller de confianza que me lo pueda hacer. Gracias anticipadas
Martín st
Coche: Leon MK3 1.4 TSI 122cv
Agradecido: 26 veces
Notapor galaxis el 19 Ene 2015, 20:47
Hola Rojas
Quería preguntarte si alimentando la cámara directamente del positivo de la caja de fusibles y el negativo de la luz de marcha atrás se podría prescindir del relé.
galaxis
Notapor rojas el 19 Ene 2015, 21:35
no he hecho la prueba , pero ... tendrias la camara con tension en todo momento , quizas te casque antes.
el rele es barato y se pone en 2 minutos , no se , allá cada uno ; pero lo veo mejor con el rele
rojas
Notapor galaxis el 19 Ene 2015, 21:45
La idea era que al coger el negativo de la luz de marcha atrás, y como en el Leon se corta el negativo, la cámara sólo estaría alimentada al meter la marcha atrás.
De esta forma, al coger el positivo directo y cerrar el circuito con el negativo al poner la marcha atrás nos evitaríamos el filtro y el relé.
No se si sería posible.
galaxis
