León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor cvillajos el 18 Dic 2018, 22:38
Franr50 escribió:Buenas. Sabeis si es posible instalar la camara en una pantalla de 5 pulgadas??
Enviado desde mi SM-G960F mediante Tapatalk
search.php?keywords=%225+pulgadas%22&t=106679&sf=msgonly
cvillajos
Agradecido: 3612 veces
Notapor lead el 18 Dic 2018, 22:58
lead escribió:Buenas, a ver si me podéis ayudar.
No consigo que funcione la cámara, la pantalla sale en negro, es la de 5’8, la tengo conectada con un robacorrientes a la caja de fusibles .
La codificación con obdeleven entiendo que esta bien ya que para descartar que fuera el cable que hay que hacerse y su conexión a la unidad de la guantera le he conectado una cámara de vídeo y al meter marcha atrás la imagen de la videocámara la veo en pantalla. Para descartar que fuera que la cámara no funciona la he conectado a la televisión y también funciona. He probado también con el cable de alimentación y cambiar los cables de alimentación (rojo-negro) de la cámara y nada todo sigue igual, se ve en negro la pantalla. He probado con dos robacorrientes que tengo y nada.
¿Alguien puede ayudarme? No se me ocurre que puede ser y ya he probado de todo. Gracias.
Buenas sigo sin que funcione, he comprado con un voltímetro si llega corriente desde el mechero y si que llegan los 12v. Me queda comprobar si es que no hace masa bien, ¿Donde pilláis ustedes para hacer masa en el maletero?
lead
Coche: Leon MK3 1.5 TGI 130cv
Notapor Dav2k6 el 22 Dic 2018, 13:10
yo sigo peleandome como hacer una instalacion oem....
mi camara oem tiene 2 conectores uno negro "tipico de vw" de 3 cables y uno blanco alargado...
Entonces:
Aqui una foto de los tres cables que lleva el conector,
Rojo -- Positivo +12v
Marron -- Masa
Negro -- ?????? alguna idea???
Nadie me puede arrojar algo de luz??? Tan facil es una instalar aftermarket y dificil la de origen???
saludos!!
Última edición por Dav2k6 el 24 Dic 2018, 07:47, editado 1 vez en total
Seat leon ST FR 150cv
Dav2k6
Notapor Dani2025 el 23 Dic 2018, 18:02
Seguramente este ya pero los pasos para codificarla con obd eleven?
Enviado desde mi SM-N950F mediante Tapatalk
Dani2025
Notapor cvillajos el 23 Dic 2018, 18:25
Dani2025 escribió:Seguramente este ya pero los pasos para codificarla con obd eleven?
Pues seguramente estén, sí. Pero si no las encuentras -> traducelas: viewtopic.php?f=8&t=128250
cvillajos
Notapor Dav2k6 el 24 Dic 2018, 07:50
Dav2k6 escribió:yo sigo peleandome como hacer una instalacion oem....
Entonces:
Marron -- Masa
saludos!!
Alguien aue me pueda arrojar algo de luz?? tan facil es instalar una aftermarket y tan dificil una de origen???
saludos!
Dav2k6
Notapor josemag el 24 Dic 2018, 21:08
Hola muy buenas, hoy he ido a hacer el brico pasando los cables como indica rojas y me he encontrado con dos cables marrones iguales, cómo sé cuál es el que tengo que utilizar? Gracias.Imagen
Enviado desde mi Mi Note 2 mediante Tapatalk
josemag
Agradecido: 16 veces
Notapor Nenubuds el 26 Dic 2018, 16:10
Hola, tengo un st 1.2 tsi style del 2017 con la pantalla pequeña, como dicen x ahí no valdría la Brico?
Nenubuds
Coche: Leon MK3 1.2 TSI 110cv
Notapor josemag el 02 Ene 2019, 21:50
josemag escribió:Hola muy buenas, hoy he ido a hacer el brico pasando los cables como indica rojas y me he encontrado con dos cables marrones iguales, cómo sé cuál es el que tengo que utilizar? Gracias.[ Imagen ]
Ok, solucionado, gracias
josemag
Notapor Gendos22 el 15 Ene 2019, 14:45
Hola a todos. Soy nuevo aquí. Os cuento. Me gustaría poner la cámara marcha atrás OEM high con lineas dinamicas para leon f5 my18, peeeero no se las referencia de misma. Alguien me puede hechar la mano con referencia? Un saludo a todos
Надіслано від мого SM-N960F, використовуючи Tapatalk
Gendos22
Agradecido: 82 veces
Notapor Leon pucelano el 20 Feb 2019, 13:01
Hecson.27 escribió:La instalacion no la terminamos, porque falta el fusible y los pines que sigo sin ellos.
Si pudieramos quedar un dia en algun lado me pasaba a por ellos para ir haciendo el cable.
Y si consigo el fusible a ver si esta lista el finde que viene.
Nuestro leon tambien es de tres puertas y conseguimos pasar el cable de video sin que se viera nada, que eso es lo mas importante.
Sobre las camaras que pones no se las diferencia, así que en ese tema no puedo ayudarte.
Estoy esperando todo lo necesario para montar la camara. Mi coche también es de 3 puertas, por donde pasaste el cable de video? Un saludo.
Leon pucelano
Agradecido: 15 veces
Notapor sergio1319 el 05 Mar 2019, 12:53
Buenas!
Me he animado a instalar la cámara trasera y he optado por esta:
https://s.click.aliexpress.com/e/cGpKN65i
He realizado la instalación eléctrica en los cables del tubo pasacables de goma tanto con el cable azul negro para positivo como con el marrón para masa.
He llevado el cable de vídeo hasta la unidad y lo he conectado al quadlock atraves de este cable desmontándolo y quedándome con el cable y los pines:
https://s.click.aliexpress.com/e/bEaSqNSY
Después he puesto esto con el obdeleven:
- 5F - Coding - 07
byte 18, seleccionar Bit 4
byte 19, seleccionar Bit 4
- 10 park assist - Coding 07
byte 2, seleccionar Bit 0 (ya estaría)
byte 2, seleccionar Bit 5
1. 09 - Cent. elect.
2. Código de acceso: 31347
3. 10-Adaptación
4. Seleccionar: Leuchte29RFL RA64 - Dimmwert AB 29
5. Cambiar valor a: 127
Y cuando pongo marcha atrás se ven todas las características de la cámara pero se ve en negro.
Aparte me sale el mensaje de parkpilot no disponible teniendo los sensores delanteros y traseros con la información en pantalla.
Alguna solución?
sergio1319
Notapor hiervas el 05 Mar 2019, 18:09
Muchas gracias por esta aportación tan interesante, ya la he puesto y funciona perfectamente.
hiervas
Notapor sergio1319 el 11 Mar 2019, 13:47
sergio1319 escribió:Buenas!
- 5F - Coding - 07
3. 10-Adaptación
Alguna solución?
Solucionado!!!
El problema que tenía eran los robacorrientes “cocodrilos”, no estaban haciendo su función.
sergio1319
Notapor Oregon el 21 Mar 2019, 00:13
alguien de Madrid que la haya instalado que me eche una mano? o que me la instale y le pago ?
Oregon
Agradecido: 29 veces
