León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor ertate el 27 Mar 2019, 07:19
Dav2k6 escribió:yo sigo peleandome como hacer una instalacion oem....
mi camara oem tiene 2 conectores uno negro "tipico de vw" de 3 cables y uno blanco alargado...
Entonces:
Aqui una foto de los tres cables que lleva el conector,
Rojo -- Positivo +12v
Marron -- Masa
Negro -- ?????? alguna idea???
Nadie me puede arrojar algo de luz??? Tan facil es una instalar aftermarket y dificil la de origen???
saludos!!
No se si habrás conseguido montar ya la cámara, pero si no has podido ahí va mi granito de arena. Uno de los cables es el positivo, el otro señal de la luz de marcha atrás y el tercero pone GND.
me imagino que será positivo, positivo de la marcha atrás y masa y la cámara traerá el relé incorporado.
Sale muy cara la cámara oem?
ertate
Agradecido: 128 veces
Notapor Francisco Delgado el 28 Mar 2019, 20:27
Me podeis informar un taller mecánico que me pueda instalar 1 pantalla de doble ding en mi seat mk1 1.9 110 caballos, de momento no he comprado nada. Saludos y gracias.
Francisco Delgado
Notapor jasoriab el 29 Mar 2019, 13:27
Francisco Delgado escribió:Me podeis informar un taller mecánico que me pueda instalar 1 pantalla de doble ding en mi seat mk1 1.9 110 caballos, de momento no he comprado nada. Saludos y gracias.
Este no es el hilo adecuado para la petición que realizas. Hay un subforo de instaladores que participan en el foro, realiza la búsqueda que quieres en él.
viewforum.php?f=23
jasoriab
Agradecido: 2055 veces
Notapor bertoco el 31 Mar 2019, 11:43
fegavo escribió:Buenas noches. Ya hice la instalación junto con la codificación pero me sale la pantalla en negro. Entiendo que esta todo bien codificao, porque me sale para cambiar el brillo y esas cosas, pero no veo nada. Que puede ser?? La cámara está conectada a la toma de mechero del maletero.
EDITO: ya funciona!!, el problema era que los pines a la consola eran más grandes...los he cambiado y listo!!
Buenos días.
Aguien tiene enlace donde poder comprar la camara?, los que estoy viendo ya no existen.
Gracias!!!
bertoco
Notapor bertoco el 01 Abr 2019, 17:07
rojas escribió:Hola a todos , aqui os dejo otro manual para los que querais instalar la camara de parking en vuestro leon , es aplicable a otros vehiculos con las mismas caracteristicas como Audi y Volkswagen ; ademas no es necesario tener sensores de parking.
Buenas tardes.
@rojas estoy mirando los enlaces de la cámara y están caducados, sabes donde la puedo conseguir, como tu ya la probaste y va bien me gustaría que fuera la misma.
Última edición por jasoriab el 01 Abr 2019, 17:21, editado 1 vez en total
Razón: Editado para eliminar la cita innecesaria de todo el primer mensaje del hilo.
bertoco
Notapor bertoco el 01 Abr 2019, 22:08
Rubimania escribió:
miceor escribió:En la 5F, unicamente tienes que activar en Byte 19 el Bit 4 que es el de la camara.
El Byte 18 no tienes que tocar nada, no sé porque pones la imagen del mismo.
En el modulo 76, la codificación es la siguiente:
En modo Bytes:
Byte 0 Ningúno
Byte 1 Bit 0,4,5
Byte 2 Bit 0,2
Byte 3 Bit 4
Byte 4 Bit 0
En modo texto:
- Caja de cambios -- Opciones (Cambio manual - Sistema automático)
- Función arranque/parada codificación -- Opciones (No activa en UC- Activa en UC)
- Remolque -- Opciones (Sin dispositivo de remolque - Dispositivo de remolque - Remolque giratorio)
- Regulación de la distancia -- Opciones (No activado - Activado)
- Activación aparcamiento asistido -- Opciones (Automático - Manual)
- Asistente de acoplamiento con dirección asistida -- Opciones (Sin montar - Montado)
- Indicación optica para aparcamiento asistido -- Opciones (Indicación OPS - Sin montar)
- BAP -- Opciones (Activado - No activado)
- Tipo de camara -- Opciones (Camara de marcha atras)
- Supresión sonido (Mute) -- Opciones (Activado - No activado)
- Funcionamiento limitado -- Opciones (Disponible - No disponible)
- Indicación de carril -- Opciones (Con indicación de carril - Sin indicación)
- Sensores ruedas con detecc.sent.de giro -- Opciones (Sin montar - Montado)
- Información sobre la codificación -- Opciones (Codificado - Sin codificar)
- Hibrido/tracción electrica -- Opciones (Sin montar - Montado)
- Asistente de desaparcamiento -- Opciones (Sin montar - Montado)
En adaptación:
Volumen altavoces para aparcamiento asistido tras.: etapa 5
Frecuencia altavoces para aparcamiento asistido tras.: etapa 4
Volumen altavoces para aparcamiento asistido del.: etapa 6
Frecuencia altavoces para aparcamiento asistido del.: etapa 6
Requerimiento descenso de audio: on
Tono de activación p. aparcamiento asistido: off
Velocidad de desactivación p. ayuda de aparcamiento: 10 km/h
Modo de producción: desactivar
Desactivar modo de producción: desactivar
Me sige saliendo fallo y sin ver la camara pongo un video haber si me podeis ayudar
https://youtu.be/hZ4S6dMgjhs
Buenas tardes.
Quería hacer el brico de la cámara trasera, el mio es un st del 2015, no tiene ningun tipo de sensor, alguien me podría pasar la configuración para el obdeleven después de que la tenga montada.
Saludos y gracias
bertoco
Notapor cvillajos el 02 Abr 2019, 14:03
En modo Bytes:
Byte 0 Ningúno
Byte 1 Bit 0,4,5
Byte 2 Bit 0,2
Byte 3 Bit 4
Byte 4 Bit 0
En modo texto:
En adaptación:
Buenas tardes.
Saludos y gracias
Solo el primer punto del post que has citado.
cvillajos
Agradecido: 3613 veces
Notapor bertoco el 02 Abr 2019, 14:49
En modo Bytes:
Byte 0 Ningúno
Byte 1 Bit 0,4,5
Byte 2 Bit 0,2
Byte 3 Bit 4
Byte 4 Bit 0
En modo texto:
En adaptación:
Buenas tardes.
Saludos y gracias
solo esto?
saludos y gracias
bertoco
Notapor jesusti el 06 Abr 2019, 13:47
Buenas tardes.
Tengo la camara montada hace ya casi los cuatro años y sin problemas (esta montada en el mismo plafon de la luz de la matricula y se nota que hay algo hay, saldra unos 2 cm o asi. Tambien tiene luces al encenderse, tipo led). Es similar a esta https://www.aliexpress.com/item/Car-Rea ... 8ac6df27-4
Mi pregunta por si sabeis algo al respecto. Me toca la ITV el mes que viene. Suele haber problemas con ella. Tiran el coche para atras y habra que quitarla. Habia pensado llevarlo y me imagino que dependera el que me toca podra decir algo o no. Tambien le cambie el otro plafon, ya que la que traia la camara era de led y la otra no y se notaba muchisimo, ademas de quedar feo.
Que opinais.
Mercys.
jesusti
Coche: Leon MK3 1.5 TGI 130cv
Notapor Dav2k6 el 06 Abr 2019, 18:03
Entonces:
Marron -- Masa
saludos!!
No.. no me he peleado pirque no tengo mucho tiempo....
Estudiando y mirando por internet... son 3 cables... Rojo, positivo directo, negro positivo de la marcha atras y masa...
Seat leon ST FR 150cv
Dav2k6
Notapor Quim003 el 07 Abr 2019, 09:30
Buenas! Si solo quiero instalar un sensor de aparcamiento de estos baratejos (solo sonido e ya), puedo pillar la luz de marcha atrás de donde dices en el brico?
Tendría problemas con lo que dices a posterior de tener que instalar relé y condensador o eso es solo para la camara?
Gracias!
Última edición por jasoriab el 08 Abr 2019, 17:29, editado 1 vez en total
Razón: Editado para eliminar la cita innecesaria del primer mensaje del hilo.
Quim003
Notapor JABELES10 el 15 Abr 2019, 18:12
jesusti escribió:Buenas tardes.
Que opinais.
Mercys.
La mayoría de cámaras que llevan led, van con una alimentación independiente a la de la cámara (el negativo si suele ser común). En no dar corriente a los leds de la cámara sería suficiente. Y no me refiero a los leds del plafón de la cámara, sino a los leds que rodean la misma.
JABELES10
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 34 veces
Notapor JABELES10 el 16 Abr 2019, 15:39
Compañeros una pregunta: Alguien ha montado también la cámara delantera combinada con la trasera?. Me surge una duda en base a todo que leído en los post de esta línea. Se supone que la poner la marcha atrás, da corriente a la cámara trasera y ésta, da señal de vídeo que entra en el quadlook. La pregunta es: cuando quito la marcha atrás, se apaga la cámara trasera, y lógicamente se va la imagen, pero si le entra otra señal de vídeo, sin poner la marcha atrás, como por ejemplo la cámara delantera o procedente de una vídeo cámara, se vería la imagen en pantalla? Tengo la duda de que al quitar la marcha atrás corta la señal de vídeo conectada, aunque tenga corriente directa la cámara o fuente de vídeo.
A ver si alguien me aclara. Lo podría probar yo, pero aun no tengo el OBDLEVEN para codificar. Tengo una pantalla de 8" sin NAVI, ni Cámara trasera. Gracias.
JABELES10
Notapor Pedrost el 19 Abr 2019, 08:58
JABELES10 escribió:Compañeros una pregunta: Alguien ha montado también la cámara delantera combinada con la trasera?. Me surge una duda en base a todo que leído en los post de esta línea. Se supone que la poner la marcha atrás, da corriente a la cámara trasera y ésta, da señal de vídeo que entra en el quadlook. La pregunta es: cuando quito la marcha atrás, se apaga la cámara trasera, y lógicamente se va la imagen, pero si le entra otra señal de vídeo, sin poner la marcha atrás, como por ejemplo la cámara delantera o procedente de una vídeo cámara, se vería la imagen en pantalla? Tengo la duda de que al quitar la marcha atrás corta la señal de vídeo conectada, aunque tenga corriente directa la cámara o fuente de vídeo.
Eso depende de como esté configurada tu unidad, en mi caso cuando yo quito la reversa la pantalla me seguía mostrando la imagen de la cámara trasera durante varios segundos y por eso puede aprovechar y en esos segundos ponerle la delantera, tiene que haber algo que se programe y de esa opción, pero eso se habló en el hilo de cámara trasera y delantera para aparcar y no se dió con el parámetro que es. Así que de momento si tu pantalla le quitas la marcha atrás y se apaga al momento poco puedes hacer. Saludos
Aunque ahora con culo(st) desde 2003 enamorado de la fiera de seat :enamorado:
Se agradece dándole al :ok:
Pedrost
Agradecido: 281 veces
Notapor ivanti el 23 Abr 2019, 11:27
voy a comprar un León X-Perience de principios de 2018 que incluye sensores de aparcamiento y tengo unas dudas respecto a la instalación de cámara trasera:
- Si hago la instalación se pierde la garantía?
- Cuál es la mejor cámara actualmente? Cuál recomendáis?
- Algún compañero hace la instalación y/o activación
ivanti
