León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor JABELES10 el 18 Jul 2019, 00:17
JABELES10 escribió:
cvillajos escribió:
Mesk-one escribió:Muy buenas a todos, en primer lugar gracias por el brico, ya tengo la cámara funcionando.
Tengo un pequeño problema, no tengo sensor de aparcamiento, lo que para activar la cámara no me supone un problema, pero al quitar la marcha atrás y seguir funcionando con el coche, la pantalla se quedan en negro 4 segundos y a veces sale el mensaje de error "Parkline assistance no disponible en estos momentos."
Sabéis si se puede desactivar el sensor de aparcamiento por OBD y evitar que salga este mensaje y los 4 segundos de pantalla en negro? A ver si hay suerte y tirando de OBD se puede modificar esto.
Muchas gracias!
En la primera página del BRICO se indica. Si no tienes Park Assist solo tienes que codificar un byte en la 5F, el 19 (y nada en la 10/76 que lógicamente no tendrás).
Clavijos. Yo acabo de instalar la cámara y todo perfecto, salvo el dichoso aviso al quitar la marcha atrás. Tengo pantalla de 8" y solo sensores traseros. La configuración que he hecho en el OBDII, es la de un vídeo que circula, que es en el 5F, Activar el Byte 19 (Rear View Jow) y en el Byte 18, pasar de "0" a "16". Quizá, este último no debería, o si? Saludos
Perdón, te he rdicho Clavijos, pero quería decir cvillajos. Perdón.
JABELES10
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 34 veces
Notapor cvillajos el 18 Jul 2019, 07:49
Muchas gracias!
Hola @JABELES10 ,
No sé qué video está circulando de la 5F (no lo he visto) pero el bit 4 del byte 18 es para que se sobreponga el OPS a la imagen de la cámara de marcha atrás. Puedes tener sensores traseros pero no tener OPS en la pantalla, por tanto, tendrás el error.
No recuerdo si algún compi de los que ha instalado la cámara por este hilo lo ha hecho solo con sensores traseros, pero tienes dos opciones:
1.- dejar el byte 18 como estaba.
2.- activar la representación OPS sólo con sensores traseros (es un MOD que está descrito en los hilos de VagCom y OBDeleven).
cvillajos
Agradecido: 3613 veces
Notapor JABELES10 el 18 Jul 2019, 09:03
cvillajos escribió:
Muchas gracias!
Hola @JABELES10 ,
Me pongo con ello y ya te cuento. Gracias
JABELES10
Notapor JABELES10 el 18 Jul 2019, 22:21
JABELES10 escribió:
cvillajos escribió:
Muchas gracias!
Hola @JABELES10 ,
Bueno cvillajos , pues he deshecho la configuración, y todo correcto como al principio, no se ve la cámara ni sale mensaje, que es lo lógico. He vuelto a configurar, modificando solo el Byte 19 por OBD, activando la Rear View Low, y me sigue saliendo el mensaje de Park Pilot. Todo lo demás bien. Estoy perdido, no encuentro la configuración que me indicas como segunda opción (La de configurar la OPS, solo con los sensores traseros. El Vídeo al que me refería, que está en varios hilos al respecto, es el siguiente: https://www.youtube.com/watch?v=5W1T9i5hLJc.
A ver, si me echáis una mano. Un abrazo
JABELES10
Notapor JABELES10 el 18 Jul 2019, 22:52
lead escribió:Buenas,
Tengo una duda que me ha surgido, tengo sensores de aparcamiento sólo los traseros, active con el OBD el ops en pantalla, ¿alguien sabria decirme si cuando instale la cámara ya no me va a salir el gráfico de los sensores?
He visto que a otros compañeros les aparece en pantalla pero veo que tienen sensores tanto delante cómo detrás.
Mi pantalla es de 5´8.
Y otra duda ¿ qué cámara recomendais la que se coloca en la luz de la matrícula, la mia es halógena, o la de hacer el agujero, es que al principio iba a pillar la de luz de matrícula pero me parece que es mejor la de hacer el agujero en el parachoques.
Gracias.
Hola, me podrías decir la configuración con el OBD, para que me represente el OPS, solo con los sensores traseros. Gracias
JABELES10
Notapor JABELES10 el 18 Jul 2019, 23:07
Gracias.
Yo tengo la misma duda que tú, a ver si algún compañero con OPS solo trasero que la haya montado nos dice algo!
Buenas, te puedo contestar ya que la tengo instalada aunque todavia no me sale la imagen de la cámara, pero cuando meto marcha atrás me sale la pantalla en negro y la imagen del coche con los sensores traseros.
Eso si cuando la instales reinicia la radio para que te aparezcan las dos cosas, sino solo te aparecerá la imagen de la cámara.
Hola. A que le llamas reiniciar la radio y como se hace? Gracias
JABELES10
Notapor Josep20 el 19 Jul 2019, 00:28
Gracias.
Tienes que dejar el botón de encendido pulsado hasta que se reinicia, normalmente tienes que dejarlo pulsado entre unos 10 o 15 y cuando se enciende te sale la pantalla con el símbolo de Seat
Enviado desde mi Mi A2 Lite mediante Tapatalk
Seat León Mk3 ST 1.4 TSI FR Advanced 150cv Rojo Desire
Josep20
Agradecido: 83 veces
Notapor cvillajos el 19 Jul 2019, 06:46
JABELES10 escribió:
JABELES10 escribió:
cvillajos escribió:
Muchas gracias!
Hola @JABELES10 ,
Éste es el hilo:
viewtopic.php?f=40&t=118998&hilit=Brico+sensores+traseros+ops#p1912830
En el primer post tienes la codificación para OPS solo con sensores traseros.
cvillajos
Notapor Trosk el 21 Jul 2019, 21:31
Alguien tiene una foto o me puede explicar más o menos por donde pasar el cable de la camara al maletero
Tengo un león st y el problema es q lo insonorice y ahora no se donde esta........
Trosk
Notapor cvillajos el 25 Jul 2019, 23:43
Trosk escribió:Alguien tiene una foto o me puede explicar más o menos por donde pasar el cable de la camara al maletero
Buscando "pasacables" en el buscador propio del hilo tienes alguna foto creo. Desde el plafón (mirando a la trasera del coche) abajo a la derecha y luego hacia arriba tienes que ver el agujero.
cvillajos
Notapor Josetsi110 el 01 Ago 2019, 02:06
Buenas, alguien ha conseguido hacerla funcionar en la pantalla de 5"? Si es así me podríais decir que tipo de Cámara y como la tenéis conectada?
Tengo un style de 2017,110 1.2 tsi con pantalla de 5"
Josetsi110
Notapor rapon el 03 Ago 2019, 18:55
Hola buenas tarde,tengo un Seat Leon 2017 con pantalla de 8 pulgadas le he instalado una camara trasera y no consigo ver imagen en la pantalla,he seguido el tutorial de Rojas y lo he instaldo todo .Mi duda es que el cable de video lleva un cable positivo y no se cual es su pocion en el conector quadlock del la unidad de cd .He seguido todos los pasos pero no encuentro la solucion.Espero que alguien me dueda hechar una mano.Gracias :ayuda: :ayuda: :ayuda:
rapon
Notapor euskfr el 16 Ago 2019, 02:32
rapon escribió:Hola buenas tarde,tengo un Seat Leon 2017 con pantalla de 8 pulgadas le he instalado una camara trasera y no consigo ver imagen en la pantalla,he seguido el tutorial de Rojas y lo he instaldo todo .Mi duda es que el cable de video lleva un cable positivo y no se cual es su pocion en el conector quadlock del la unidad de cd .He seguido todos los pasos pero no encuentro la solucion.Espero que alguien me dueda hechar una mano.Gracias :ayuda: :ayuda: :ayuda:
Buenas compi, ese cable es porque algunas pantallas (no las de serie) tienen una cable que cuando metes marcha atrás le da corriente entonces en ese caso empalmarías ese cable y te evitarías pasar mas cables pero como no es tu caso olvídate de ese cable y no lo conectes en ningún lado. Un saludo!
euskfr
Agradecido: 25 veces
Notapor rapon el 18 Ago 2019, 16:48
Hola euskfr,lo que no entiedo es porque tengo la pantalla negra y las luces led de la camara que lleva se iluminan cuando pongo la marcha atras en principio le llega alimentacion pero en la pantalla no veo imagen.Gracias compi :ayuda: :ayuda: :ayuda:
rapon
Notapor Noue el 21 Ago 2019, 16:45
rapon escribió:Hola euskfr,lo que no entiedo es porque tengo la pantalla negra y las luces led de la camara que lleva se iluminan cuando pongo la marcha atras en principio le llega alimentacion pero en la pantalla no veo imagen.Gracias compi :ayuda: :ayuda: :ayuda:
Has llagado a solucionarlo
Última edición por Noue el 22 Ago 2019, 11:48, editado 1 vez en total
Noue
Usuarios navegando por este Foro: AmazonBot, Anthropic, ByteDance (Bytespider) y 16 invitados
