León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO - Como instalar la cámara de parking en León Mk3
Notapor Pedrost el 29 Dic 2019, 00:04
Erick_g escribió:Hola @rojas primero buen post , quería decirte que no me deja ver las imágenes... Quiero coger también los cables de + - de la luz de marcha atrás y he probado los cables que has dicho y no van ... Yo he cogido viendo el coche desde detrás la goma que uno el techo con el maletero por donde pasan los cables del lado izquierdo viéndolo desde atrás y los cables que has dicho pero no tengo tensión de la luz de la marcha atrás ...
Un aporte tonto. En algunos casos con el portón abierto las luces del portón no funcionan. A ver si es tu caso y tienes ahí el problema. Saludos
Aunque ahora con culo(st) desde 2003 enamorado de la fiera de seat :enamorado:
Se agradece dándole al :ok:
Pedrost
Agradecido: 281 veces
Notapor Sebifa el 29 Dic 2019, 21:05
Hola buenas alguien de sevilla para instalar la camara
Sebifa
Notapor Cuprone el 02 Ene 2020, 06:52
Buenos días chicos
En breve me llegará un paragolpes original que dispone de la cámara original,que cableria necesito para la instalación?
He visto una cableria para reequipar pero no sé si en AliExpress hay algo,solo he encontrado para Golf
https://www.vag-navisystems.com/novedad ... -leon/2401
https://m.es.aliexpress.com/item/328223 ... 822321059&
Para la señal de la marcha atrás es obligatorio tirar cable hasta el portón?
Muchas gracias chicos
Cuprone
Notapor Alex Hdez el 06 Ene 2020, 17:42
Hola todos,
Me leido el tema al completo, tengo un Seat León MK3 de 2018, tengo dos cuestiones:
1- Este brico sigue siendo válido para este modelo (que desde que se empezó este tema han pasado 4 años, con versiones, actualizaciones, etc) en cuento realización, conexiones y resolución de problemas?
2- Mi coche dispone de sensores de aparcamiento delanteros y traseros con representación en pantalla OPS, con OBD eleven exactamente que tendría que modificar para que apareciese la imagen de la cámara ademas de la
representación OPS? (He visto referencias por el foro pero no me ha quedado claro del todo)
Alex Hdez
Agradecido: 23 veces
Notapor Gendos22 el 06 Ene 2020, 17:44
Alex Hdez escribió:Hola todos,
Modulo 5f codificación extendida byte 15 camara low
Отправлено с моего SM-N960F через Tapatalk
Gendos22
Agradecido: 82 veces
Notapor Alex Hdez el 06 Ene 2020, 19:47
Me podrías explicar que es exactamente lo que debo hacer? :rezar:
Alex Hdez
Notapor Gendos22 el 06 Ene 2020, 19:50
Entras con obd11 o vagcom al modulo 5f. Codificación extendida buscas byte19 rear view low y le das activado.
En mi post anterior dije byte 15. No es correcto. Correcto es bite 19
Gendos22
Notapor snowpluralism el 07 Ene 2020, 11:00
Buenas a todos
Que tengo un problema
Hay echo la instalación de la cámara pero tengo park system e lo mismo no aparece, solo la câmera.
Alguien sabe qual es la opción para que siga mostrando la camera e lo park system como en la foto?? (Tengo MIB1)
Gracias a todos!
Enviado do meu ONEPLUS A6003 através do Tapatalk
snowpluralism
Notapor cvillajos el 07 Ene 2020, 11:59
snowpluralism escribió:Buenas a todos
Gracias a todos!
En el primer post del hilo (donde habla de codificación) se indican las configuraciones a realizar. Concretamente el BRICO está realizado sobre una MIB gen1 con Park Assist (si fuese sin Park Assist sobra el bit 4 del byte 19 y todo lo relativo a la ECU 10 o 76)
¿Cuáles has hecho y cuales no?
cvillajos
Agradecido: 3613 veces
Notapor snowpluralism el 07 Ene 2020, 12:06
Gracias a todos!
Muchas gracias!
Las codificaciónes que tengo echo es
5F - Central Elect.
Byte 18 - Bit 4
Byte 19 - Bit 4
10 - Park/Steer Assist
Environmental Camera
snowpluralism
Notapor cvillajos el 07 Ene 2020, 14:44
Gracias a todos!
Muchas gracias!
5F - Central Elect.
Byte 18 - Bit 4
Byte 19 - Bit 4
Qué LongCoding (completo) tienes en la "10 - Park/Steer Assist"? Antes de que activaras la cámara te salía la representación OPS correctamente en la pantalla?
cvillajos
Notapor snowpluralism el 08 Ene 2020, 16:01
long coding 10 - steer/park assist
0031051001
5F - Central Elec.
04730001D70A000021111101000800002F0101040100010046
muchas gracias
snowpluralism
Notapor snowpluralism el 09 Ene 2020, 17:53
Gracias a todos!
Muchas gracias!
5F - Central Elect.
Byte 18 - Bit 4
Byte 19 - Bit 4
Puedo esto ser culpable por mi vcds ser lo 17 ?
Porque se nota que quando ló haco modificaciones en lo módulo 10 nada se cambiaImagenImagen
snowpluralism
Notapor Alex Hdez el 09 Ene 2020, 19:17
Buenas, esta "tapa" de los extremos del salpicadero, ¿Me podéis explicar como se quita?
(He tomado la foto prestada del brico)
Alex Hdez
Notapor Gendos22 el 09 Ene 2020, 19:42
Alex Hdez escribió:Buenas, esta "tapa" de los extremos del salpicadero, ¿Me podéis explicar como se quita?
Hacerle palanca con herramienta para quitar plasticos y tirar hacia ti. Pero con amor y cuidado
Gendos22
