León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO - Como instalar la cámara de parking en León Mk3
Notapor cvillajos el 09 Ene 2020, 21:16
snowpluralism escribió:long coding 10 - steer/park assist
0031051001
5F - Central Elec.
04730001D70A000021111101000800002F0101040100010046
muchas gracias
Tienes un 05 en el Byte 2 de la "10 - steer/park assist" mínimo deberías tener un 25
Tienes un 01 04 en los Bytes 18 y 19 de la "5F - Central Elec." mínimo deberías tener un 11 14
O no estás haciendo correctamente los pasos o no te está guardando los cambios.
cvillajos
Agradecido: 3613 veces
Notapor snowpluralism el 10 Ene 2020, 11:05
0031051001
5F - Central Elec.
muchas gracias
Me puedes a dar tu exata configuración ?
Enviado do meu ONEPLUS A6003 através do Tapatalk
snowpluralism
Notapor cvillajos el 10 Ene 2020, 12:13
0031051001
5F - Central Elec.
muchas gracias
No, yo no tengo sensores ni OPS, por tanto, no tengo centralita 10/76 y en mi 5F tengo 01 14 en bytes 18 y 19.
Pero hasta que no consigas la codificación que te he indicado no tendrás el OPS en pantalla para marcha atrás.
Mira a ver en la biblioteca de centralitas si hay alguien con OPS y haya instalado la cámara: viewtopic.php?f=8&t=120732
cvillajos
Notapor Gendos22 el 10 Ene 2020, 12:16
0031051001
5F - Central Elec.
muchas gracias
Modulo 76 (ayuda al aparcamiento)
Codificación extendida
0471151001
Отправлено с моего SM-N960F через Tapatalk
Gendos22
Agradecido: 82 veces
Notapor snowpluralism el 10 Ene 2020, 12:56
0031051001
5F - Central Elec.
muchas gracias
0471151001
Muchas gracias!
snowpluralism
Notapor snowpluralism el 12 Ene 2020, 14:38
Se quedó muy bienImagen
snowpluralism
Notapor Keke25 el 16 Ene 2020, 08:33
Buenas, a ver si alguien puede hecharme un cable, tengo un leon st 1.5 tgi de agosto y he activado algún mods, el problema es que despues de activar la alarma y el menu offroad, no me aparece el ops ni los ajustes de brillo, color , contraste cuando pongo la macha atras, solo aparece la vision trasera y pitar si pita el ops os dejo las codificaciones que tengo en las unidades:
Unidad 5F:
04738201D70A00001111000100080A00AF0111D401200500CE
Unidad 76:
0471151001
Unidad 9:
000000000000000000000000410000000000000000000000000000000000
Unidad 17:
07A514106F84000800886A031001000080000000
Son las que he tocado al activar mods
Keke25
Coche: Leon MK3 1.5 TGI 130cv
Notapor jasoriab el 16 Ene 2020, 09:00
Keke25 escribió:Buenas, a ver si alguien puede hecharme un cable, tengo un leon st 1.5 tgi de agosto y he activado algún mods, el problema es que despues de activar la alarma y el menu offroad, no me aparece el ops ni los ajustes de brillo, color , contraste cuando pongo la macha atras, solo aparece la vision trasera y pitar si pita el ops os dejo las codificaciones que tengo en las unidades:
Unidad 5F:
Unidad 76:
0471151001
Unidad 9:
Unidad 17:
Comprueba el historial de modificaciones de tu aplicación OBD, y deshaces los cambios, para volver al estado original.
¿Qué programa estás usando para las modificaciones? Algunos cables antiguos VAG-Com no funcionan correctamente con los Leones actuales, y pueden llegar a desconfigurarte opciones.
jasoriab
Agradecido: 2055 veces
Notapor Keke25 el 16 Ene 2020, 09:35
Unidad 5F:
Unidad 76:
0471151001
Unidad 9:
Unidad 17:
Utilizo obdeleven, ya deshice todo y nada, el problema es q en el historial no me aparece la codificación extendida y no recuerdo bien, pero en algun byte cambié el hex pq el tutorial q vi estaba con otro número y yo también lo cambié, pero no lo recuerdo bien y no sé q hice....
Al activar esos mods tambien me desapareció el bluetooth y el icono de telefono en el infotainment, pero eso lo pude solucionar
Keke25
Notapor Gendos22 el 16 Ene 2020, 09:42
Keke25 escribió:
Unidad 5F:
Unidad 76:
0471151001
Unidad 9:
Unidad 17:
Intenta hacer estoImagen
Gendos22
Notapor Keke25 el 16 Ene 2020, 09:58
Gendos22 escribió:
Keke25 escribió:
Unidad 5F:
Unidad 76:
0471151001
Unidad 9:
Unidad 17:
El ops aparece, el problema es cuando doy marcha atrás que solo sale la imagen de la camara, no aparece la silueta del coche con los sensores ni las opciones de cambiar color y brillo, no se que he liado :zoquete:
Keke25
Notapor Gendos22 el 16 Ene 2020, 10:09
Keke25 escribió:
Gendos22 escribió:
Keke25 escribió:
Unidad 5F:
Unidad 76:
0471151001
Unidad 9:
Unidad 17:
Osea aplicacion no te ayudó? Tengo acceso a odis service online se puede codificar a valores de fabrica
Gendos22
Notapor jasoriab el 16 Ene 2020, 10:53
Keke25 escribió:
Unidad 5F:
Unidad 76:
0471151001
Unidad 9:
Unidad 17:
¿Tienes un backup previo de dichas unidades antes de hacer los cambios? Si así fuera, puedes comparar los cambios entre ese backup y la configuración actual, con algún programa que muestre diferencias entre dos ficheros de texto, como pueda ser winmerge, por ejemlo.
jasoriab
Notapor Keke25 el 16 Ene 2020, 12:05
Gendos22 escribió:
Keke25 escribió:
Gendos22 escribió:
Keke25 escribió:
Unidad 5F:
Unidad 76:
0471151001
Unidad 9:
Unidad 17:
Nada, no a funcionado :(
Keke25
Notapor Keke25 el 16 Ene 2020, 12:07
jasoriab escribió:
Keke25 escribió:
Q va, no tengo backup :zoquete:
Unidad 5F:
Unidad 76:
0471151001
Unidad 9:
Unidad 17:
Keke25
Usuarios navegando por este Foro: AhrefsBot, Anthropic y 1 invitado
