León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO - Como instalar la cámara de parking en León Mk3
Notapor Gendos22 el 16 Ene 2020, 12:08
Keke25 escribió:
Gendos22 escribió:
Keke25 escribió:
Gendos22 escribió:
Keke25 escribió:
jasoriab escribió:
Keke25 escribió:Buenas, a ver si alguien puede hecharme un cable, tengo un leon st 1.5 tgi de agosto y he activado algún mods, el problema es que despues de activar la alarma y el menu offroad, no me aparece el ops ni los ajustes de brillo, color , contraste cuando pongo la macha atras, solo aparece la vision trasera y pitar si pita el ops os dejo las codificaciones que tengo en las unidades:
Unidad 5F:
04738201D70A00001111000100080A00AF0111D401200500CE
Unidad 76:
0471151001
Unidad 9:
000000000000000000000000410000000000000000000000000000000000
Unidad 17:
07A514106F84000800886A031001000080000000
Son las que he tocado al activar mods
Comprueba el historial de modificaciones de tu aplicación OBD, y deshaces los cambios, para volver al estado original.
¿Qué programa estás usando para las modificaciones? Algunos cables antiguos VAG-Com no funcionan correctamente con los Leones actuales, y pueden llegar a desconfigurarte opciones.
Utilizo obdeleven, ya deshice todo y nada, el problema es q en el historial no me aparece la codificación extendida y no recuerdo bien, pero en algun byte cambié el hex pq el tutorial q vi estaba con otro número y yo también lo cambié, pero no lo recuerdo bien y no sé q hice....
Al activar esos mods tambien me desapareció el bluetooth y el icono de telefono en el infotainment, pero eso lo pude solucionar
Intenta hacer estoImagen
Отправлено с моего SM-N960F через Tapatalk
El ops aparece, el problema es cuando doy marcha atrás que solo sale la imagen de la camara, no aparece la silueta del coche con los sensores ni las opciones de cambiar color y brillo, no se que he liado :zoquete:
Osea aplicacion no te ayudó? Tengo acceso a odis service online se puede codificar a valores de fabrica
Nada, no a funcionado :(
Pues sera mirar lo que has modificado
Deberías tener backup de las unidades
Sino encuentras solución,pues a lo mejor parametrización o odis online
Tengo las dos cosas
Gendos22
Agradecido: 82 veces
Notapor Alex Hdez el 18 Ene 2020, 09:53
Buenas a todos, a ver si podéis ayudarme...
Resulta que he recibido la cámara, según especificaciones es/era NTSC y calidad de imagen alta... la pruebo en la TV y se me ve en B/N ademas de que la calidad es bastante baja/mala... :mosqueao: (Decir que la TV no es que sea aintigua, pero dudo que solo admitiese sistema PAL, me falta probarlo en otra TV para terminar de confirmar que he errado en la compra)
¿Alguien seria tan amable de pasarme algún enlace de cámara que sepa que es 100% ok, que sea NTSC y se vea medianamente bien (dentro de lo que es)? Mi intención es ponerla de las de perforar el parachoques (adjunto imagen)
(Me interesara en principio sin lineas de guiado o posibilidad de que se quiten cortando un cable, pero no es importante si las lleva)
Gracias :rezar: :rezar:
Alex Hdez
Agradecido: 23 veces
Notapor Alex Hdez el 20 Ene 2020, 19:24
Alex Hdez escribió:Buenas a todos, a ver si podéis ayudarme...
Me autocito...el problema de la imagen en B/N era de la TV donde la comprobé, en otra me ha ido perfectamente.
Lo que seguramente haga es comprar otra cámara, porque la calidad (soy consciente de que al precio que están, mucho no se puede pedir...) no es mala, pero me gustaría "algo un poco mejor"
Alex Hdez
Notapor autobusero el 01 Feb 2020, 11:10
Hola!!ya tengo todos los materiales en casa para la instalación,lo único que tengo una duda, no se si los pin que he recibido son los correctos.os pongo foto a ver si son estos.gracias de antemano
autobusero
Notapor Gendos22 el 01 Feb 2020, 11:11
autobusero escribió:Hola!!ya tengo todos los materiales en casa para la instalación,lo único que tengo una duda, no se si los pin que he recibido son los correctos.os pongo foto a ver si son estos.gracias de antemano
Correctos
Gendos22
Notapor jonnye el 10 Feb 2020, 18:40
Estoy mirando de comprar una cámara en amazon
Para poner en el hueco de luz de matrícula.
Alguna recomendación ?
Hay pre instalacion o algo para no tener que pasar cable hasta la radio ?
La radio es la básica de 3 botones a cada lado,
Imagino que servirá
Leon 1P restyling 2010 BKD DSG
Leon 5F 2.0 tdi 150 CKFC DSG
jonnye
Notapor Gendos22 el 10 Feb 2020, 18:42
jonnye escribió:Estoy mirando de comprar una cámara en amazon
Imagino que servirá
De 5 pulgadas, 5,8 pulgadas o de 6.5 pulgadas. Para que te ayudan tienes que aclarar cosas. Sin pasar cables hasta la radio no es posible
Gendos22
Notapor victor_leon_FR el 25 Feb 2020, 20:58
Hola, a ver os expongo un problema que me a salido.
Hoy instale la cámara con todos los procesos indicados y cuando acabo engrano marcha atrás y todo perfecto pero mi sorpresa llega al arrancar que la imagen se va como si hubiese alguna interferencia
Me resulta raro que arrancando se vaya la imagen y parado este perfecto
Alguien sabe que puedo comprobar o si e hecho algo mal
Muchas gracias!!!
victor_leon_FR
Coche: Leon MK3 1.4 TSI 122cv
Notapor marlop el 25 Feb 2020, 21:42
Hay gente a la que le ha pasado algo parecido, que al arrancar se le queda la pantalla en negro. Y la mayoría lo ha solucionado, apretando bien a fondo los pines del conector azul de la unidad de la guantera.
Por otro lado, si has cogido el positivo de la luz de marcha atrás, asegúrate de haber subido la intensidad de ésta a 127 con vagcom/obdeleven.
Justamente estoy aprovechando estos días de fiesta que tengo para instalar la cámara. Ya tengo el cable de vídeo en la guantera y el positivo en marcha atrás. Mañana toca quitar paragolpes y terminar.
Suerte ;)
marlop
Agradecido: 1080 veces
Notapor Gendos22 el 25 Feb 2020, 23:36
Os recomiendo a todos instalar camaras high. Mas caro pero mas funciones etc
Gendos22
Notapor victor_leon_FR el 26 Feb 2020, 01:03
Mañana probaré a subir la intensidad de la luz por que si lo cogí de hay, ya que si fuese el pin azul pasaría siempre no? Aunque lo probaré también
Ya os cuento a ver si lo soluciono
Muchas gracias
victor_leon_FR
Notapor victor_leon_FR el 26 Feb 2020, 22:07
Bueno pues solucionado, hoy le subí la intensidad a la luz de marcha atrás y ya funciona perfectamente.
Mañana lo probaré bien por que solo e podido en el garaje
Muchas gracias marlop por la solución
victor_leon_FR
Notapor marlop el 27 Feb 2020, 00:34
Me alegro de que lo tengas solucionado.
A disfrutar del Leoncete ;)
Otro por aquí con la cámara instalada que, por cierto, me distrae en la maniobra más que otra cosa jajaja, pero está chulo!
Gracias a todos por las aportaciones! :love:
marlop
Notapor donhec el 28 Feb 2020, 13:00
Buenas!!!
He estado leyendo durante un tiempo el brico y dandole vueltas pero no me atrevo del todo a montarlo... el tema de empalmar cables nunca ha sido lo mío... ¿Alguien por la zona de leganés estaría dispuesto a echarme una mano?? me han llegado a pedir 500 euros por montar la cámara en un taller :lol:
donhec
Notapor Fleicar el 29 Mar 2020, 18:50
Buenas, yo ando igual estoy pensando en cambiar la Radio por una Xtrons y de paso quiero comprar todo para montar camara trasera, soy de Carabanchel, si te animas lo hacemos un finde cuando tenga todo.
Fleicar
