León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO - Como instalar la cámara de parking en León Mk3
Notapor Nachozgz el 27 Jun 2020, 10:42
Bueno después de leerme nosecuantas páginas y de descargarme el tutorial
Creo que voy a comprar la que se instala en la luz de la matrícula para no tener que desmontar todo el paragolpes.
Mi pregunta es? Comprarla que lleve led para que también se vea por la noche o no es necesario ya que las otras también se ven por la noche? Entiendo que en cualquiera de ellas se verán las líneas para aparcar
Me podéis echar una mano y pasarme un enlace para comprarla en Amazon o AliExpress
Otra cosa más para desmontar el módulo de la guantera necesitaré también las palancas para soltarla
Estás me valdrán?
https://www.amazon.es/dp/B018GKO6OQ/ref ... 9EbJG4YDD0
Saludos y gracias por adelantado
Nachozgz
Notapor quikeramos1 el 29 Jun 2020, 08:29
Esas palancas deberían valer para extraer la unidad. Con respecto a la cámara, no es necesario que lleve led, aunque la calidad de la imagen va a depender de la calidad de la cámara.
quikeramos1
Agradecido: 27 veces
Notapor jasoriab el 29 Jun 2020, 08:43
Lo que ayuda algo @Nachozgz es cambiar la bombilla de la luz de marcha atrás por una bombilla led, así la cámara se verá algo mejor en condiciones de baja luminosidad.
Hay un hilo en el foro que trata del cambio de dicha bombilla en el Mk3, tienes que mirar que tipo llevas primero, porque las hay de dos casquillos distintos.
jasoriab
Agradecido: 2055 veces
Notapor yokin el 07 Jul 2020, 20:56
Nachozgz escribió:Bueno después de leerme nosecuantas páginas y de descargarme el tutorial
Estás me valdrán?
¿Esas te sirvieron al final?
yokin
Coche: Leon MK3 1.2 TSI 105cv
Notapor skrp1001 el 29 Jul 2020, 21:13
¿ Alguien más le pasa que no ve las líneas de referencia?
skrp1001
Notapor jasoriab el 30 Jul 2020, 08:22
skrp1001 escribió:¿ Alguien más le pasa que no ve las líneas de referencia?
¿Puedes dar algún detalle más? ¿Qué tipo de cámara tienes? ¿De serie, o comprada en aliexpress, por ejemplo?
Si te refieres a las líneas de trayectoria que se mueven al girar el volante, necesitas una cámara high, que no es la que monta de serie el León Mk3.
viewtopic.php?f=40&t=128811
jasoriab
Notapor cvillajos el 30 Jul 2020, 08:49
Y si no es OEM, que es aftermarket, algunas se venden con líneas de guiado y otras sin ellas.
cvillajos
Agradecido: 3613 veces
Notapor skrp1001 el 30 Jul 2020, 13:06
Es esta :
Luego de codificar, funciona todo perfectamente , excepto lo de las líneas de referencia(estáticas), pero claro ahora que dices eso , igual no las tiene ... ¿ Se podría aprovechar la instalación y solo sustituir la cámara?
https://ibb.co/W2PCSgJ
skrp1001
Notapor skrp1001 el 30 Jul 2020, 15:35
La cámara trae un cable , que se puede cortar según he leído , pero no sé si será para activar las líneas , o modo espejo u otra cosa...
skrp1001
Notapor jasoriab el 31 Jul 2020, 10:34
¿No viene ningún manual donde lo especifique? En la web http://www.audiolink.es/erv216.html arriba a la derecha aparece "Manual de producto" pero no se puede descargar. Tendrás que contactar con ellos, o con quien la instaló, para comprobar si dispone de esa función (tiene pinta de que sí por uno de los iconos que sale en esa pantalla).
jasoriab
Notapor skrp1001 el 31 Jul 2020, 10:53
Solucionado cortando el cable , aparece las líneas!!
skrp1001
Notapor Nachozgz el 13 Ago 2020, 17:10
Estás me valdrán?
Sí, con estas sale muy fácil, ten cuidado no se atasquen las palancas en la unidad
Última edición por jasoriab el 19 Ago 2020, 12:16, editado 1 vez en total
Razón: Editado para corregir la cita.
Nachozgz
Notapor Nachozgz el 13 Ago 2020, 17:25
Consulta
Mi león es el familiar
He leído que es mejor que saque el positivo y el negstivo del mechero del maletero?
De los fusibles del mechero? Donde está los fusibles del mechero?
Otra cosa por donde habéis pasado los cables desde el maletero hasta la luz de la matrícula?
Nachozgz
Notapor cvillajos el 15 Ago 2020, 00:02
Nachozgz escribió:Consulta
Los fusibles del mechero los tienes debajo del mando de luces, tras la trampilla. Busca el esquema de fusibles por el foro que está publicado, creo recordar que era el F40.
Para el ST tienes explicaciones y algunas fotos publicadas por este hilo. Usa el buscador interno con la palabra clave "pasacables".
cvillajos
Notapor Nachozgz el 16 Ago 2020, 18:16
No encuentro por dónde pasar los cables de la luz de la matrícula al interior del maletero. Es la versión st
He hecho unas fotos a ver si alguien me puede iluminar
Saludos y gracias
Nachozgz
