León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO - Como instalar la cámara de parking en León Mk3
Notapor cvillajos el 17 Ago 2020, 07:34
Nachozgz escribió:No encuentro por dónde pasar los cables de la luz de la matrícula al interior del maletero. Es la versión st
He hecho unas fotos a ver si alguien me puede iluminar
Saludos y gracias
Te dije que usaras el buscador interno del hilo con la palabra clave "pasacables":
viewtopic.php?f=9&t=106679&p=1996781&hilit=Pasacables#p1996781
Todavía te queda quitar el tapizado lateral para llegar a él.
De ahí con una guía baja hacia una trampilla que encontrarás cerca de la rueda trasera derecha, la desmontas coges la guía y la subes arriba a la izquierda para llegar a los plafones de matrícula.
cvillajos
Agradecido: 3613 veces
Notapor estudiante2003 el 05 Sep 2020, 19:43
Buenas tardes, las fotografías que ilustran este hilo no están disponibles, alguien guardó copia?
Gracias y saludos.
estudiante2003
Notapor leonfrrojito el 06 Sep 2020, 16:06
estudiante2003 escribió:Buenas tardes, las fotografías que ilustran este hilo no están disponibles, alguien guardó copia?
Gracias y saludos.
Hola si mal no recuerdo en la sección de descargas del foro estaba en formato PDF .
leonfrrojito
Agradecido: 178 veces
Notapor Tizon2020 el 08 Sep 2020, 12:50
Excelente brico, he instalado la camara siguiendo este fantastico manual, y la camara funciona perfectamente, pero no se porque ahora si pongo el navegador me dice que la base de datos de los mapas no esta instalada o algo asi. tendra que ver con la codificacion para la camara ? a alguien le ha pasado. Gracias de antemano.
Tizon2020
Notapor jasoriab el 08 Sep 2020, 20:50
Tizon2020 escribió:Excelente brico, he instalado la camara siguiendo este fantastico manual, y la camara funciona perfectamente, pero no se porque ahora si pongo el navegador me dice que la base de datos de los mapas no esta instalada o algo asi. tendra que ver con la codificacion para la camara ? a alguien le ha pasado. Gracias de antemano.
¿Qué dispositivo y versión has usado para realizar la codificación? Te lo pregunto porque hay versiones antiguas del VAG-com que desconfiguran la unidad 5F, que es lo que puede que te esté pasando a ti.
jasoriab
Agradecido: 2055 veces
Notapor Tizon2020 el 08 Sep 2020, 22:33
Con un Vagcom 19.6. si ha sido lo puedo solucionar de alguna forma ?
Tizon2020
Notapor jasoriab el 09 Sep 2020, 07:39
Tizon2020 escribió:Con un Vagcom 19.6. si ha sido lo puedo solucionar de alguna forma ?
Las versiones que suelen dar problemas son las 12.x y creo (aunque de esta última no estoy seguro) las 15.x
Puede que hayas cambiado algún valor que no correspondía, y le ha afectado al navegador. Comprueba de nuevo los cambios realizados que aparecen en el mod a ver si has tocado un parámetro que no correspondía. También puedes comprobar el registro de cambios (Vagcom te los guarda en un fichero) a ver si se ha cambiado algo que no tocaba.
¿Tenías una copia de seguridad previa a los cambios de tu unidad 5F?
jasoriab
Notapor Tizon2020 el 11 Sep 2020, 08:13
Mil Gracias ya lo solucione, efectivamente tenia un digito cambiado, menos mal que tenia salvados los valores iniciales, le puse los de origen para recuperar el navegador, y luego volvi a codificar la camara y perfecto.
Tizon2020
Notapor jasoriab el 11 Sep 2020, 09:01
Ok, me alegro que lo hayas podido solucionar, y compartido la solución, que puede venir bien a otros compañeros a los que le pueda suceder lo mismo. Ahora a disfrutarla :ok: :ok:
jasoriab
Notapor Agonza86 el 02 Oct 2020, 10:08
Hola chicos, alguno ha instalado una cámara pero delas que van entrelos plafones? No me convencen las cámaras que van incluidas en el plafón.
¿Algún modelo que se vea bien y no sea caro??
Agonza86
Agradecido: 409 veces
Notapor jasoriab el 02 Oct 2020, 11:57
Agonza86 escribió:Hola chicos, alguno ha instalado una cámara pero delas que van entrelos plafones? No me convencen las cámaras que van incluidas en el plafón.
Si quieres una cámara de este tipo, yo te recomendaría que ya puestos, le pongas una high. Incluye más funciones que la cámara que trae de serie el Mk3, por poner un ejemplo, las líneas de guiado dinámicas.
Te paso el hilo de dicho brico: viewtopic.php?f=40&t=128811
jasoriab
Notapor Agonza86 el 02 Oct 2020, 12:03
He estado bicheando antes ese hilo pero no tengo VCP... Por eso ando mirando de conformarme con la normal
Agonza86
Notapor jasoriab el 02 Oct 2020, 12:23
Para la normal, juraría que ayer o anteayer había una original a la venta. Mira en los subforos de compra/venta de accesorios...
jasoriab
Notapor marlop el 02 Oct 2020, 19:49
Ya se ha comentado que hay cámaras chinas de 8€ que tienen mejor calidad que la original del León.
Yo puse una por ese precio entre los plafones y muy contento. Cámara económica, con una instalación muy sencilla.
marlop
Agradecido: 1080 veces
Notapor Agonza86 el 02 Oct 2020, 21:57
Pedí una @marlop este mediodía pero de las de plafón para no taladrar nada primero y ver si me hago a usarla con vistas a si me convence como se ve y no da mucho cante como queda iluminada la matrícula poner una en medio más adelante, la tuya qué tal se ve?
Conservas el enlace aún?
Me preocupa sobretodo su duración a la larga por tema de humedades, fríos y calores etc...
Agonza86
