León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Notapor jasoriab el 06 Dic 2020, 11:51
lucky_38 escribió:
jasoriab escribió:Hola @lucky_38
Si buscas mis mensajes en este hilo, de finales de julio de 2019 verás que yo estaba en tu misma situación. Unidad H41, con SW 0462 y con el mismo problema con las agujas de la pantalla del SportHMI.
Sí conseguí que me actualizaran (en garantía) el firmware a la última versión disponible en dicho momento, en un concesionario oficial SEAT de mi ciudad (hay dos y en el primero, donde lo compré se desentendieron del tema), la 0475 y te puedo confirmar que quedó solucionado el problema con las agujas. Por lo que supongo que en la versión superior 0479 seguirá funcionando bien esa pantalla.
Y sí, no pierdes ningún código SWAP ya que no tienes la unidad hackeada, e instalas un firmware de la rama 4xx que es la correspondiente a tu modelo. El error 1555 sí te va a aparecer, y necesitas hacer la operación XOR de la que ya se ha hablado en el hilo e introducir el valor resultante, a través de OBDEleven u otra herremienta OBD similar.
Muchas gracias !! :) al final he acabado actualizando yo esta mañana con el archivo, de 462 a 479 sin ningún problema y manteniendo todo lo que tenía. Ya quitaré el error 1555 cuando me llegue el Obdeleven a casa ;)
He subido a mi MEGA la 0515 también para quien la quiera, e iré subiendo cuando pueda el resto de firmwares que encuentre.
Hola @lucky_38 me alegro que ya la tengas actualizada :ok:
Respecto al firmware 0515, supongo que será el válido para las unidades H50, sin ninguna modificación, ¿no?
Si quieres actualizar tu H41 a la versión 0515, ese no te valdrá. Tendrías que usar uno modificado, como hizo @Lito69 haces unos días atrás (y explicó el procedimiento en este mismo hilo).
jasoriab
Agradecido: 2055 veces
Notapor lucky_38 el 06 Dic 2020, 12:47
jasoriab escribió:Hola @lucky_38 me alegro que ya la tengas actualizada :ok:
¡Gracias!
Efectivamente, el 0515 tengo subido al MEGA es el "oficial" sin tocar, es decir que es directamente compatible con H50, las H41 necesitan modificar vía SWDL para ser compatibles y poder actualizar.
Creo que en la carpeta de MEGA del foro alemán (que si no te han pasado ya el enlace te lo puedo mandar por privado rápidamente si quieres) hay también unas versiones de SW modificadas que te permiten pasar directamente de 0475 a 0515 sin hacer nada mas (en lugar de usar el método que se ha dicho en el foro); pero eso no lo he probado aún (y no se si lo voy a hacer).
Hombre, sería interesante meter la 0515 en mi H41 (para tener los colores de los menús a juego con el color de la iluminación interior y esas "pijadas" que molan), pero necesito conocer bien bien el proceso.
lucky_38
Notapor jasoriab el 06 Dic 2020, 13:09
Ese enlace @lucky_38 no se puede compartirse aquí por las posibles consecuencias legales que puedan acarrearse al foro por ello.
jasoriab
Notapor Lito69 el 06 Dic 2020, 13:34
¡Gracias!
Prueba, no van porque el id de la cpu del metainfo no está bien
Lito69
Agradecido: 240 veces
Notapor jasoriab el 06 Dic 2020, 13:53
Os comparto los ficheros que me ha pasado @Lito69 para actualizar su H41 a la versión 515. Gracias por compartirlos con el foro :ok:
https://mega.nz/folder/209x3IQJ#lBMtI1Bb6HGWIIjtOSFcHg
Ha incluido un fichero de texto detallando los pasos a realizar. Cualquier duda al respecto realizársela a @Lito69
jasoriab
Notapor Warelio el 06 Dic 2020, 13:55
Gracias a ambos por compartirlos. Ayudará a muchos que quieran actualizar las unidades.
Enviado desde mi Pixel 4 XL mediante Tapatalk
Warelio
Moderador de Racing
Agradecido: 1183 veces
Notapor lucky_38 el 06 Dic 2020, 14:00
jasoriab escribió:Ese enlace @lucky_38 no se puede compartirse aquí por las posibles consecuencias legales que puedan acarrearse al foro por ello.
Claro, es perfectamente comprensible. yo decía vía mensaje privado por si no has visto aún la carpeta esa. De todas formas como ya he dicho me limitaré a bajarme todos los firmwares "oficiales" y subirlos a mi MEGA para que todos los que estéis aquí podáis bajarlos fácilmente cuando sea necesario :)
gracias.
lucky_38
Notapor lucky_38 el 06 Dic 2020, 14:03
Lito69 escribió:Prueba, no van porque el id de la cpu del metainfo no está bien
De ahí que quiera conocer bien el proceso, que no estoy familiarizado aún con ello.
Ya si me animo intentaré el método SWDL para subir a 0515 como tu has hecho
lucky_38
Notapor jasoriab el 06 Dic 2020, 14:04
gracias.
Muy buena idea la de replicar en tu mega todos los firmwares oficiales para las unidades de guantera y compartirlos en el foro, y así no perderlos si eliminan esa cuenta :ok:
jasoriab
Notapor D83 el 06 Dic 2020, 15:10
jasoriab escribió:
D83 escribió:Señores, alguna actualización para esto? O sabeis donde mirar y descargarla?
Gracias[ Imagen ]
Hola @D83
La última disponible para la unidad H30 es el SW 0363, lo que ocurre es que hay dos versiones disponibles, en función del SW_train (o Driver_train) que son SEAT_PQ o SEAT_ZR
Esa información la puedes ver si no recuerdo mal, dejando pulsado el botón menú unos segundos, como si fueras a actualizar el firmware, y ahí aparece (te hablo de memoria).
Mi coche es un MY17, los primeros en montar pantalla de 8... No dispone del botón menú.... Alguna otra forma de saber la versión del Driver_train? Tiene full link y no dispone de GPS... No se si eso influye... Gracias
:shock:
D83
Agradecido: 68 veces
Notapor jasoriab el 06 Dic 2020, 15:47
D83 escribió:
Gracias[ Imagen ]
Hola @D83
Me refiero a este botón, que muestra el menú en el infotainment @D83
jasoriab
Notapor D83 el 06 Dic 2020, 16:35
jasoriab escribió:
D83 escribió:
Gracias[ Imagen ]
Hola @D83
Mea culpa... A ese botón lo llamo inicio....
entiendo que la versión es "ZR".
Donde se puede conseguir los archivos para actualizar?
1000 graciasImagenImagen
:shock:
D83
Notapor Octacon el 06 Dic 2020, 16:49
D83 escribió:
jasoriab escribió:
D83 escribió:
Gracias[ Imagen ]
Hola @D83
Yo tengo este 363 pero nose si sirve para tu infotaiment
Editado por e moderador: Eliminado el enlace de la versión 363 porque es beta, y puede acarrear problemas.
Última edición por jasoriab el 06 Dic 2020, 17:19, editado 1 vez en total
Razón: Editado por e moderador: Eliminado el enlace de la versión 363 porque es beta, y puede acarrear problemas.
Octacon
Agradecido: 95 veces
Notapor Octacon el 06 Dic 2020, 16:50
Yo estoy subiendo los archivos en mi drive, tambien pondre los links.
Octacon
Notapor jasoriab el 06 Dic 2020, 17:09
@D83 para tu H30, la última versión que aparece en el repositorio de mega es la 0363.
Pero Atención, me comentan que esa versión es beta, y puede acarrearte problemas. La última estable para SEAT es la 0368 pero por desgracia no está en dicho repositorio.
Por lo que mi consejo es que no actualices a la 0363, y si quieres la 0368, pasa por un concesionario SEAT a ver si te lo hacen.
jasoriab
Usuarios navegando por este Foro: Anthropic, Drs, SentiBot y 11 invitados
