León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: León Mk3 - BRICO - Como instalar la cámara de parking
Notapor jasoriab el 10 Mar 2021, 09:53
PegaxusJavier escribió:Estupendo brico, la pena es que no se ven las imágenes que seguro ayudaría mucho. Sería interesante arraigar los enlaces para tener más claro los pasos a seguir. Un saludo
Por desgracia, las fotos se han perdido al estar alojadas en otro servidor distinto al foro, pero al final del primer mensaje del hilo, tienes un enlace para descargar el brico en formato PDF.
jasoriab
Agradecido: 2055 veces
Notapor PegaxusJavier el 10 Mar 2021, 21:56
Hola en primer lugar agradecerte el Briko que has hecho en el foro, perdona que te moleste pero tengo una duda sobre las líneas de guiado que salen en la pantalla, las proporciona el coche ? o se reciben desde la cámara? Lo comento porque es que hay cámaras que tienen la opción de poner las guías cortando un cable y otras que vienen ya directamente me imagino y no sé qué tipo de cámara comprar para que no se me dupliquen en el caso de que las tiene software del coche . Muy agradecido por tu ayuda
PegaxusJavier
Coche: Leon MK3 1.2 TSI 105cv
Notapor jasoriab el 11 Mar 2021, 10:10
Si te refieres a las líneas de trayectoria que se mueven al girar el volante, necesitas una cámara high, que no es la que monta de serie el León Mk3.
viewtopic.php?f=40&t=128811
Este hilo trata del montaje de la cámara low (similar a la que monta el León de serie) donde las líneas de trayectoria son fijas (y se activan en las cámaras chinas como indicas, cortando un cable).
jasoriab
Notapor gesnazo el 19 Mar 2021, 14:18
He terminado la instalación de una cámara china, usando el 12v de un fusible que yo he añadido.
Tengo una duda, mientras maniobras solo se ve la imagen con la marcha atrás puesta, una vez que cambias a D, se ve l imagen del parkpilot. Me pareció leer que debería tener como un retraso y seguir viéndose la cámara unos segundos.
Además, la imagen del parkpilot a pantalla completa que sale tiene arriba a la izq un botón que pone RVC pero está desactivado, entiendo que para alternar de imagen a parkpilot.
Sabéis como configurar esto?
Añado adjunto con foto
Última edición por gesnazo el 20 Mar 2021, 15:26, editado 1 vez en total
gesnazo
Notapor jasoriab el 19 Mar 2021, 14:33
A tu primera pregunta, esas cámaras se alimentan con la electricidad que le llega a la luz de marcha atrás. Es normal que cuando quites esa marcha, se apague la cámara, ya que deja de recibir fluido eléctrico.
Las que mantienen la imagen hasta que se alcanzan los 10/15 km/h hacia adelante son las cámaras high.
Respecto a tu segunda pregunta, a ver si algún compañero puede resolvértela.
jasoriab
Notapor Nanorodi el 19 Mar 2021, 16:11
Buenas tardes. He instalado la cámara a mi seat leon pero para el tercer paso (la codificacion), que es lo que necesito? Eso nose como hacerlo. He instalado varias cámaras a varios modelos distintos de coches pero es la primera vez que lo veo. Si me pudieras ayudar. Muchas gracias.
Nanorodi
Notapor gesnazo el 19 Mar 2021, 16:16
jasoriab escribió:A tu primera pregunta, esas cámaras se alimentan con la electricidad que le llega a la luz de marcha atrás. Es normal que cuando quites esa marcha, se apague la cámara, ya que deja de recibir fluido eléctrico.
La tengo puesta a 12v bajo llave, siempre tiene alimentación, lo que cambia es que al poner D el infotainment cambia a parkpilot
gesnazo
Notapor mgrondona el 23 Mar 2021, 19:49
Según tengo entendido la cámara low funciona solo cuando se tiene puesta la marcha atrás, aunque la cámara reciba corriente constante (que no sé si es muy bueno) es la misma radio la que desconecta la vista de cámara y muestra el park pilot. Y el botón RVC lo ves desactivado por eso mismo, por qué la radio entiende que solo se puede usar con la marcha atrás puesta.
Si quieres comprobarlo... Mete la marcha atrás y verás la cámara, dale al icono del coche con los sensores en la pantalla manteniendo la marcha atrás engranada y cuando veas el park pilot en pantalla completa con la R engranada ahi si te dejará seleccionarla.
Cómo te comentan, para poder tenerla siempre visible debes instalar una cámara high.
Enviado desde mi Mi A3 mediante Tapatalk
mgrondona
Agradecido: 112 veces
Notapor gesnazo el 25 Mar 2021, 19:34
Comprobado, tienes razón en todo, se activa al pulsar sobre la silueta del coche teniendo la marcha atrás.
gesnazo
Notapor Odonell el 25 Mar 2021, 23:49
Nanorodi escribió:Buenas tardes. He instalado la cámara a mi seat leon pero para el tercer paso (la codificacion), que es lo que necesito? Eso nose como hacerlo. He instalado varias cámaras a varios modelos distintos de coches pero es la primera vez que lo veo. Si me pudieras ayudar. Muchas gracias.
Tienes que codificarlo con obdeleven o con vagcom compañero!
Odonell
Coche: Leon MK3 1.5 TGI 130cv
Notapor pacoooooo el 06 Abr 2021, 16:16
Hola
He encotrado este video que explica muy bien como instalar la camara trasera, por donde pasar cables y la codificaion.
Última edición por jasoriab el 08 Abr 2021, 11:45, editado 1 vez en total
Razón: Editado para añadir vídeo youtube embebido.
pacoooooo
Agradecido: 41 veces
Notapor YeSL el 14 Abr 2021, 18:42
Acabo de instalar una cámara en mi pantalla de 5,8. Funciona perfecto pero me sale así el botón de configuración del brillo. Decir que a los segundos desaparece. Lo que no desaparece es el fondo negro donde aparece el coche, he estado toqueteando los diversos valores que habéis puesto en todo el hilo y nada, ni se hace transparente el cuadro ni se me pone bien el icono del brillo. A alguien le ha pasado algo así o tiene idea de cómo solucionarlo? Muchas gracias.
YeSL
Notapor javichuchacho el 14 Abr 2021, 19:13
pacoooooo escribió:Hola
[ Video ]
El que siga los pasos para meter los cables desde fuera del coche hacia dentro por donde dice el video... se merece una colleja
Enviado desde mi SM-N986B mediante Tapatalk
javichuchacho
Agradecido: 168 veces
Notapor Adrixof el 20 May 2021, 14:27
Hola buenas tardes quería saber un poco de información sobre el tema de la camara trasera, he pillado una en aliexpress me viene con todo lista para cablear y codificar. He puesto en la guantera en el conector azul los pines 6 y 12 los cables del rca a la radio, he conectado la camara al plafon de la luz de matricula y luego he pasado el cable de alimentación a la camara hasta los cables del portón, negro azul positivo y marrón negativo. Tengo el byte 19 activo en obd pero resulta que cuando entrado marcha atrás no me sale en pantalla nada solo error park pilot y en obd me sale error señal en la camara... me podéis ayudar un poco?? Gracias amigos. Decir que es un león 5f fr del 2016
Adrixof
Notapor Blackfire el 21 May 2021, 10:26
rojas escribió:
nos queda la tercera y ultima parte , la codificacion
entramos en stg 5F MMI 3G <> Coding - 07 <> byte 19 , seleccionar Bit 4 se quedara el valor en 10.
byte 18 , seleccionar Bit 4 se quedara con valor 10
entramos en stg 10 park assist <> coding 07 <> y lo dejamos asi :
ya lo tenemos listo !! nos quedara algo asi al engranar la marcha atras !! :comediante:
para contestar las preguntas que se han hecho de la luz de la camara , si seria distinta a la de serie , en mi opinion apenas se nota , quizas sea un pelin mas brillante y azulada , pero os aseguro que no se nota , una imagen de noche vale mas que mil palabras !! :mrgreen:
espero que os haya gustado el brico y os animeis! , es muy facil en un ratito está hecho , si necesitais ayuda no dudeis en preguntar :ok: :ok:
PD. para ahorrarnos el incordio del rele y condensador ... se puede conectar la corriente al fusible del mechero , la cual no va mandada por la BCM y no nos creará interferencias en la imagen .
Otro método es coger corriente directamente de la luz de marcha atras y modificar el valor de este :
1. 09 - Cent. elect.
2. Código de acceso: 31347
3. 10-Adaptación
4. Seleccionar: Leuchte29RFL RA64 - Dimmwert AB 29
5. Cambiar valor a: 127
Añadido por el moderador - Enlace de descarga del brico en PDF
Instalación de cámara de video de parking en Seat leon MK3
Buenas, he instalado la cámara trasera y lo primero decir que no tengo ni idea de codificación ni se que se usa para ello. He hablado con un compañero que si hace codificación y me dice que no tiene claro que ruta hay que seguir por si me la podías aclarar.
Pero mi mayor duda es que la cámara (que he probado con un monitor externo), que he hecho que se encienda con la luz de marcha atrás, funciona a coche parado pero si lo arranco me dice que no hay entrada de video. ¿¿?? ¿le falta alimentación?¿vastará con codificar la ultima parte que puso @rojas ?
Ya he tenido que devolver la radio de Jusun bastante decepcionado porque no me pillaba las emisoras de radio la cámara ya me la tengo que quedar porque entre otras cualquiera quita los cables... pero lo principal es que ya que me he currado el instalarla quisiera verla funcionar...
Ayuda plis.
Edito:
Un OBD para poder hacerlo yo mismo ¿es muy caro?¿es dificil de hacer?
Última edición por Blackfire el 24 May 2021, 10:09, editado 1 vez en total
Blackfire
Usuarios navegando por este Foro: Anthropic, ByteDance (Bytespider) y 2 invitados
