León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Notapor matiaso el 13 Dic 2020, 12:06
Lito69 escribió:Mi duda es si cuando sale ese aviso coges y conectas odis... Lo calculará solo?
Si quieres probar tengo el vas5054 y vivo en Barcelona, pero lamentablemente para mi MIB no hay actualizaciones sino probaria.
matiaso
Agradecido: 16 veces
Notapor cenkkaya el 13 Dic 2020, 14:51
which version is required ?
cenkkaya
Notapor jasoriab el 14 Dic 2020, 08:33
PandaKiller escribió:Hola, alguien puede ayudarme a comprender si hay una actualización para mi MIB2 hardware H54?
Hola @PandaKiller,
Para las H54 no hay nada disponible, que sepamos. Para las MIB2 hay un par de actualizaciones, las 14xx pero son para las H55.
Recuerdo haber leído (en este hilo probablemente) que se puede pasar de la H54 a la H55 a través de actualización, pero desconozco que versión intermedia necesaria, y además no está disponible en los repositorios recientes. Usa el buscador en este hilo a ver si encuentras algo al respecto.
jasoriab
Agradecido: 2055 veces
Notapor jasoriab el 14 Dic 2020, 08:34
cenkkaya escribió:which version is required ?
Hi @cenkkaya
Do you have a H30? Please read this message, viewtopic.php?f=9&t=118140&start=2625#p2138704 (you can translate with Google Translator).
It is not recommended to install version 363 as it is a beta version.
Regards,
jasoriab
Notapor Warelio el 14 Dic 2020, 08:35
cenkkaya escribió:current version is 0346 but does not accept 0363. information on the screen.
can't use update container. Writes the current softrware donwnload aplication is to old
I think 0363 is a beta version and could have problems If upgrade to this version. Better version 0364 but there is not available here. You need to go to an official Seat seller.
Enviado desde mi Pixel 4 XL mediante Tapatalk
Warelio
Moderador de Racing
Agradecido: 1182 veces
Notapor Lito69 el 14 Dic 2020, 13:01
No, si yo también, pero caí en eso después de hacerlo jajaja
Lito69
Agradecido: 240 veces
Notapor Lito69 el 14 Dic 2020, 13:08
Yo creo que la 1447 te funcionará, a ver si alguien te la puede subir a mega, yo la pondría, si quiere actualizar es que quiere actualizar, además si actualizas creo que te cambiaran los colores de las puertas al mismo tiempo que en la radio.
Lito69
Notapor Octacon el 14 Dic 2020, 13:57
Última edición por Octacon el 24 Dic 2020, 09:46, editado 1 vez en total
Octacon
Agradecido: 95 veces
Notapor jasoriab el 14 Dic 2020, 17:34
Una cuestión importante, para las MIB2 High hackeadas Si actualizas el firmware a uno superior original (no modificado) pierdes el hackeo y habrá características que dejarán de funcionar (no sé si incluso la unidad completa)...
Luego hay que hackearlas de nuevo, y necesitarás el hack específico para esa nueva versión.
Así que tened en cuenta este hecho al actualizar MIB2 Highs.
jasoriab
Notapor PandaKiller el 15 Dic 2020, 10:53
jasoriab escribió:Una cuestión importante, para las MIB2 High hackeadas Si actualizas el firmware a uno superior original (no modificado) pierdes el hackeo y habrá características que dejarán de funcionar (no sé si incluso la unidad completa)...
Lo único que he hackeado es lo "Video On Motion". Qué otros hackeos hay?
Muchas gracias a todos por su ayuda.
PandaKiller
Notapor jasoriab el 15 Dic 2020, 11:03
No, esa es una simple modificación de OBDEleven (que quizás puedas perder al actualizar, no te lo puedo confirmar).
Lo que me refería con unidades hackeadas es el caso de instalar una nueva unidad que no traía tu coche de serie, y hay que modificarla para que el coche la acepte. Ejemplo típico, pasar de una MIB2 estándar a una MIB2 High.
jasoriab
Notapor PandaKiller el 15 Dic 2020, 11:28
jasoriab escribió:No, esa es una simple modificación de OBDEleven (que quizás puedas perder al actualizar, no te lo puedo confirmar).
No es mi caso. Tengo la consola original.
Nota - Editado por el moderador: No se permite en el foro el enlace a repositorios con herramientas para hackeos.
Última edición por jasoriab el 15 Dic 2020, 11:52, editado 1 vez en total
Razón: Editado para eliminar URL con programas de hackeo de unidades infotainment para el Mk3
PandaKiller
Notapor ojoxapa el 15 Dic 2020, 18:46
Tengo problemas con Android Auto, he probado mil cables y al poco se desconecta, y luego vuelve y se va... así todo el rato... (no se si alguien tiene solución a esto)
El caso que he ido a mirar mi version para actualizar por si solucionaba el problema y veo que segun el hilo tengo la mas alta para la H30, la 0368
Ya que hay compañeros por aqui que la esta buscando, hay forma de sacarla de mi unidad a una SD y poder compartirla :D
ojoxapa
Notapor jasoriab el 16 Dic 2020, 09:09
ojoxapa escribió:Buenas,
Gracias por el ofrecimiento @ojoxapa pero por desgracia no es posible extraer una imagen del firmware de una unidad para instalársela a otra, hace falta los archivos propios de la instalación.
Y sí, tienes la última 3xx para tu H30. Respecto a los problemas con Android Auto ¿Has probado con otro móvil? Algunos terminales dan más guerra que otros al usar AA. ¿Cuál tienes?
Mira en este hilo por si se haya hablado previamente de tu modelo de móvil, viewtopic.php?f=9&t=116470
jasoriab
Notapor dwaynecupra el 17 Dic 2020, 15:20
Can anyone help how to update? i keep getting this message, no one can help on the english forums
dwaynecupra
Usuarios navegando por este Foro: Anthropic, ROBERTO206, Semrush y 1 invitado
