León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: León Mk3 - BRICO - Como instalar la cámara de parking
Notapor Lito69 el 24 Jun 2021, 12:30
ertate escribió:Buenas.
quiero montar la camara original de un leon a un golf 7 pero antes de perforar el paragolpes y cortar cables de la instalacion original he intentado probarla metiendole voltaje directo desde la bateria a los dos positivos pero solo me aparece una panntalla negra con el mensaje de comprobar trallectoria y los ajustes de brillo contraste...
Alguna idea de que estoy haciendo mal?
Que no has enchufado el cable de video? Supongo que has codificado la cámara low
Lito69
Agradecido: 240 veces
Notapor ertate el 26 Jun 2021, 16:37
Si el cable de video lo he conectado y la codificacion que he hecho es activar el bit 4 del byte 19. el byte 18 no lo he tocado y como no tiene sensores de aparcamiento no tiene modulo de park assist.
ertate
Agradecido: 128 veces
Notapor Lito69 el 28 Jun 2021, 21:16
En la gw hay que poner que tienes la low y en la 5f también creo, no me acuerdo bien.
Lito69
Notapor ertate el 29 Jun 2021, 11:59
y como se activa en la gw?
ertate
Notapor Gendos22 el 29 Jun 2021, 12:08
Si usas obd11 y quieres poner camara high pues obd11 la detecta solo y le da de alta en la gw. Si es camara low no hay que dar de alta en gw, solo en la 5f activar bit de la camara low. Con la high bit en la 5f debe ser desactivado y en adaptaciónes de la 5f( bap funciones) VPS_0x0B activado y VPS_0X0B_MSG_BUS a traves de can infotenimiento
Отправлено с моего SM-N986B через Tapatalk
Gendos22
Agradecido: 82 veces
Notapor ertate el 29 Jun 2021, 12:40
Yo en mi coche monte la high y si me la dio de alta obdeleven automaticamente pero me esta dando mas guerra la low en el golf.
conecte la masa y le di corriente a los dos positivos desde la bateria pero no me recive imagen de video. la camara la he probado en un leon y funciona perfectamente, le voy a probar otro cable de video para asegurarme de que este este bien y no sea ese el fallo.
La codificadion que he hecho es solo la del byte 19 ya que el coche no tiene sensores de aparcamiento.
otra prueba que podria hacer es intentar hacer la misma codificacion y conexion en mi leon y si funciona ya seria cuestion de incompativilidad de componentes, pero tener que estar desmontando mi camara y desconfigurar la 5f eliminar la high de la gw para configurar la low y volver a deshacer todo para volver a hacerlo.... :( :(
ertate
Notapor leonfrrojito el 29 Jun 2021, 13:56
Sabes si el módulo 5F es compatible con la entrada de Video? No todos los son
leonfrrojito
Agradecido: 178 veces
Notapor Gendos22 el 29 Jun 2021, 14:15
Di la referencia de la unidad al menos
Gendos22
Notapor ertate el 29 Jun 2021, 16:38
ahora mismo lo que os puedo decir es la informacion que me aparece en el obdeleven.
numero de hardware 3Q0 035 819 A
version del hardware H24
version del software0245
ertate
Notapor Gendos22 el 29 Jun 2021, 17:08
Es unidad de vw
Y segun codigos PR esa unidad no es compatible con camara ni low ni high
Gendos22
Notapor ertate el 29 Jun 2021, 17:14
Es unidad de vw
por lo tanto ni una del chino?
la cosa es que me sale la pantalla en negro con el mensaje de "revise la trallectoria" y en la codificacion extendida de la 5f si me sale la opcion de camara low montada
ertate
Notapor YeSL el 01 Jul 2021, 10:18
Y como se puede saber si la unidad es compatible con video? No basta con que tenga la unidad los pines correspondientes (6 y 12)?
YeSL
Notapor Gendos22 el 01 Jul 2021, 11:17
YeSL escribió:Y como se puede saber si la unidad es compatible con video? No basta con que tenga la unidad los pines correspondientes (6 y 12)?
Todas las unidades tienen esos pines. Por dentro son diferentes. Se puede saber a traves de codigos PR. En etka para cada unidad hay ciertos codigos. Para PDC sin camara el codigo es KA0
Para camara low es KA1
Para camara high es KA2
Gendos22
Notapor ertate el 01 Jul 2021, 12:20
y me imagino que una unidad hackeada se salta todos esos codigos PR no?
ertate
Notapor Gendos22 el 01 Jul 2021, 12:21
No
Gendos22
