León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: León Mk3 - BRICO - Como instalar la cámara de parking
Notapor ertate el 02 Jul 2021, 12:55
Gendos22 escribió:
ertate escribió:
Gendos22 escribió:
YeSL escribió:Y como se puede saber si la unidad es compatible con video? No basta con que tenga la unidad los pines correspondientes (6 y 12)?
Todas las unidades tienen esos pines. Por dentro son diferentes. Se puede saber a traves de codigos PR. En etka para cada unidad hay ciertos codigos. Para PDC sin camara el codigo es KA0
Para camara low es KA1
Para camara high es KA2
Отправлено с моего SM-N986B через Tapatalk
y me imagino que una unidad hackeada se salta todos esos codigos PR no?
No
si te paso los datos de otro equipo me podrias mirar si mi equipo tiene los PR de la camara high o low??
ertate
Agradecido: 128 veces
Notapor eMi1 el 18 Jul 2021, 16:31
Buenas tardes, tengo un fr del 2018 y estoy pensando en instalarle la cámara de marcha atrás, estoy mirando está,
https://es.aliexpress.com/item/4000708940177.html
Me podríais decir si valdría para el coche o si tendría algún problema para instalarla
Un saludo y gracias de antemano
Última edición por jasoriab el 20 Jul 2021, 14:30, editado 1 vez en total
Razón: Editado para corregir URL
eMi1
Notapor mgrondona el 20 Jul 2021, 17:30
eMi1 escribió:Buenas tardes, tengo un fr del 2018 y estoy pensando en instalarle la cámara de marcha atrás, estoy mirando está,
Hola, esa es válida para el León MK3. Es la que llamamos cámara high. Ya que se ve mejor que la original y tiene varios modos de funcionamiento.
Aunque la instalación es algo más compleja que la original, ya que esta funciona vía canbus y para tener todos los modos de visualización tendrás que parametrizar y calibrar con odis.
Enviado desde mi Mi A3 mediante Tapatalk
mgrondona
Agradecido: 112 veces
Notapor Romera el 20 Jul 2021, 22:34
Esa cámara en concreto ya te la envía el chino parameteizada, lista para montar, codificar lo poquito que hay que hacer y calibrarla (la envía con parámetros del Skoda Octavia MK3) que es lo mas semejante al león.
El cableado tiene buena calidad, la cámara... Pues eso, es de las que no pasan todos los tests de calidad pero van muy bien.... Lo único malo que tiene es el soporte de la cámara, que es de un plástico bastante flojito de calidad pero con mimo encaja bien.
Luego toca calibrarla, ya sea con odis o con una diagnosis capaz de hacerlo (las diagnosis Texas por ejemplo lo permiten)
Yo las cámaras las calibro con Texas, más rápido y cómodo de hacer.....
Enviado desde mi Mi 10 mediante Tapatalk
Romera
Agradecido: 331 veces
Notapor eMi1 el 20 Jul 2021, 22:51
Gracias por vuestras respuestas, si me decido a ponerla ya os comentaré, y preguntaré para el tema de calibrar que no lo tengo muy claro
eMi1
Notapor mgrondona el 20 Jul 2021, 23:37
Vaya! No sabía que ya la mandaban con parámetros del Octavia, cuando la compré en su día la mandaban parametrizada para el A3 aunque le pidieses otro. Funcionaba pero faltaba una vista, no recuerdo cuál...
mgrondona
Notapor Romera el 20 Jul 2021, 23:38
Bueno, basta con pedirle al chino del enlace que se muestra más arriba (3 o 4 mensajes) que te la mande parameteizada para león 5f.
Romera
Notapor eMi1 el 20 Jul 2021, 23:39
Quería preguntaros otra cosa, si instalo la cámara y no le hago la calibración a parte de estar desalineadas las líneas hay algún otro problema, da algún error o algo
eMi1
Notapor Warelio el 21 Jul 2021, 15:33
Hombre, si no la calibras no te hará las lecturas correctas de las distancias cuando estés estacionando y te podrías llevar algún sustillo, no sé si te marcará fallo en el cuadro o no porque la mía la dejaron calibrada cuando instalé la cámara High y todo salió perfecto y sin fallos. Dejar estos bricos "a medias" pues como que no es muy recomendable...
Warelio
Moderador de Racing
Agradecido: 1183 veces
Notapor eMi1 el 21 Jul 2021, 16:32
Warelio escribió:Hombre, si no la calibras no te hará las lecturas correctas de las distancias cuando estés estacionando y te podrías llevar algún sustillo, no sé si te marcará fallo en el cuadro o no porque la mía la dejaron calibrada cuando instalé la cámara High y todo salió perfecto y sin fallos. Dejar estos bricos "a medias" pues como que no es muy recomendable...
Tengo intención de calibrarla , lo preguntaba por instalarla, activarla y luego calibrar más adelante ,por si habías algún problema antes de calibrarla
eMi1
Notapor ertate el 21 Jul 2021, 18:41
eMi1 escribió:Quería preguntaros otra cosa, si instalo la cámara y no le hago la calibración a parte de estar desalineadas las líneas hay algún otro problema, da algún error o algo
si la dejas sin calibrar al pasarle la diagnosis te dara fallo de ajuste basico pero no te salta ningun chivato de averia ni nada similar ni en el fis ni en la pantalla del infotaiment , solo te das cuenta si pasas el vagcom o el obdeleven o alguno similar.
ertate
Notapor eMi1 el 21 Jul 2021, 20:36
Gracias por la respuesta, mi intención es calibrarla, pero de momento es lo que menos claro tengo como hacerlo, por eso preguntaba para instalarla activar y luego informarme mejor para calibrarla
eMi1
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor untalT el 28 Ago 2021, 12:00
Mei escribió:Alguien me ayuda a instalarla cámara trasera de AliExpress? Evidentemente, le compensaría económicamente, tengo obdeleven pro.
Zona Cádiz Málaga
Hola @Mei
Alguna recomendación de donde instalaste la cámara? yo soy del Campo de Gibraltar, supongo que serás de la zona también
untalT
Notapor Rayito169 el 22 Sep 2021, 11:35
Muy buenas familia,
Tengo una duda con la instalación de una cámara chinosa de aliexpres
https://es.aliexpress.com/item/40008667 ... 9464380cac
El problema viene a la hora de instalar los cables en la radio. En mi caso, corte el cable de video para colocar los pines y me aparecieron un cable amarillo, otro rojo y luego como otro cable sin goma, totalmente pelado. No sé exactamente cual usar para el pin 6 y cual para el 12.
Muchísimas gracias a todos.
Rayito169
Coche: Leon MK3 1.2 TSI 105cv
Notapor pistoleromtb el 27 Sep 2021, 21:42
una pregunta ... que estado mirando y seguramente no lo habre visto al poner una camara de plafon habeis tenido algun problema al pasar la itv? por tocar una luz del coche... y merece la pena el parametrizar teniendo los sensores de marcha atras? gracias
pistoleromtb
Hilo del León mkIV e-hybrid
Foro: General
Autor: vkr84
Respuestas: 663
León Mk3 - Sustituir Pantalla LCD 8"
Foro: AudioCar y MultimediaCar
Autor: noel fr
Respuestas: 2
Leds legales a partir del 1 de noviembre
Foro: General
Autor: arjleon90
Respuestas: 129
León Mk3 - Full Link - Apple CarPlay
Autor: KingDejan
Respuestas: 242
Nombre de pieza de manilla
Foro: Leon II - Mecánica / Electricidad / Electrónica
Autor: Dvd69
Respuestas: 5
