León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Notapor Warelio el 26 Dic 2020, 17:08
Raulportela escribió:A ver si algún compi me puede ayudar.. quiero actualizar mi unidad que es la H41 y esta en la versión 0468
A ver si me podéis enviar un resumen o donde está la explicación clave.. porque son 175 páginas.. he buscado en algunas pero no veo nada clave. Gracias de ante mano
Para tu unidad H41 existe la versión oficial 0479 que ya han publicado en este mismo hilo algún compañero, revisa las últimas páginas y encontrarás los enlaces para descargar el firmware. También existe la versión 0515 como más reciente pero esa en teoría es para unidades H5XX aunque también puedes intentar actualizar tu H41 con esa versión pero el proceso es más largo y has de ir con cuidado ya que no es un firmware "oficial" para unidades H4XX ya que está modificado.
Enviado desde mi Pixel 4 XL mediante Tapatalk
Warelio
Moderador de Racing
Agradecido: 1182 veces
Notapor perinkel el 26 Dic 2020, 17:24
Y esa 515 que rula por ahí servirá para actualizar una unidad con H50 y versión 514 de firm? Habrá alguna diferencia palpable como una mejor estabilidad del sistema o no merece la pena actualizar y me quedo como estoy?
perinkel
Agradecido: 29 veces
Notapor Warelio el 26 Dic 2020, 17:28
Para tu unidad H50 ha de servir ya que el Firmware también es 05XXX. Desconozco qué mejoras trae, eso te lo podrán decir los que la llevan instalada. Se comentaba algo de que podías llevar los mismos colores en las puertas y en el Infotainment, por lo demás no creo que existan mejoras a destacar.
Warelio
Moderador de Racing
Notapor Octacon el 26 Dic 2020, 17:32
yo tenia la 514 y al actualizar a la 515 he notado mucha mas fluidez y el full link ahora me funciona perfecto, antes alguna vez tenia que reiniciar porque se quedaba congelado.
Octacon
Agradecido: 95 veces
Notapor Raulportela el 26 Dic 2020, 18:28
Gracias por la ayuda y una duda..
Me han dicho que si tengo la h41 y actualizo a 5xxx corro el riesgo de que me quede sin módulo de la guantera y la pantalla?
A mi me gustaría intentarlo.. a ver esa gente que lo ha echo y como le ha ido... acepto cualquier sugerencia a ver qué hago y qué harías vosotros
Raulportela
Notapor perinkel el 26 Dic 2020, 18:59
Y solo pusiste la tarjeta SD con el firm y le diste a actualizar? No te dio ningun aviso de error ni nada por el estilo?
perinkel
Notapor Octacon el 26 Dic 2020, 19:28
perinkel escribió:Y solo pusiste la tarjeta SD con el firm y le diste a actualizar? No te dio ningun aviso de error ni nada por el estilo?
si puse la 515 y le di a actualizar, no tardo mas de 15min
Octacon
Notapor Warelio el 26 Dic 2020, 20:30
Riesgos cuando actualizas algo siempre hay, no existe el riesgo 0 pero vamos, no debería dar problema. Con el contacto dado pero sin arrancar el vehículo y listo. Como dije en otro post actualicé 2 unidades H41 con el Firmware 0479 y 0 problemas. No he puesto en ninguna H41 la versión 0515 porque se trata de un firmware hackeado que en teoría no es compatible con las unidades H4XX pero si han conseguido que funcione y sobretodo no ha habido problemas pues genial.
Warelio
Moderador de Racing
Notapor jasoriab el 27 Dic 2020, 08:45
Pero luego tienes que meterle el código que se genera a través del XOR para finalizar correctamente la actualización, ¿no? Porque para eso ya necesitas un interfaz OBD y no sé si @perinkel tendrá o no.
jasoriab
Agradecido: 2055 veces
Notapor guindilla01 el 27 Dic 2020, 09:08
jasoriab escribió:
guindilla01 escribió:No me acabo de aclarar con todo este lío inalámbrico......¿me puedo conectar de ese modo a mi MK3 con andriod Auto?
Lo pregunto por que, desque que actualicé A.A. cada vez que entro en el coche, se me activa esa aplicación diciendo que está conectado, sin llegar a enchufar el cable.
La versión de mi infotainment supongo que será la última de los MK3.
Gracias y saludos.
Hola @guindilla01
No, en el Mk3 no hay forma de hacerlo de manera 'nativa', es decir, sin añadir algún dispositivo extra al coche. El grupo VAG no ha implementado en la generación del Mk3 ese tipo de conexión, que sí lo ha hecho en el nuevo Mk4.
Como bien ha escrito @Warelio, hay que añadir un dispositivo que haga de puente, por un lado conectado a uno de los puertos USB del coche, y por otro lado, que cree una wifi a la que se conecte el móvil. Actualmente hay un proyecto de crowdfunding que haría precisamente esto, https://www.indiegogo.com/projects/aawi ... 25074180#/
Somos varios en el foro (yo incluido) los que nos hemos unido al proyecto, y se espera que para los primeros meses de 2021 se envíen los dispositivos. Puedes dejar siempre conectado este dispositivo al puerto USB y así te ahorras de conectar el cable al móvil cada vez que quieras usarlo.
Y respecto a tu otra pregunta, si se te activa en el móvil android auto automáticamente, es que tienes seleccionada la opción dentro de los ajustes de la aplicación, que al conectarse automáticamente al dispositivo bluetooth del coche, se inicie.
Pues nada, que le vamos a hacer :(
Muchas gracias a ambos.
MK3 2.0 TSI 190 CV DSG-7 FR.Edition
guindilla01
Coche: Leon MK3 2.0 TSI 190cv
Agradecido: 111 veces
Notapor Warelio el 27 Dic 2020, 09:13
Correcto, después de actualizar has de quitar un error que aparece pero que en principio no afecta al funcionamiento del vehículo pero si molesta tenerlo ahí y se recomienda quitarlo. Hay que escribir unos valores que te genera previamente la calculadora XOR en el módulo 5F a través de OBD, una vez introducidos correctamente el error desaparece y la actualización queda 100% realizada.
Warelio
Moderador de Racing
Notapor RGF2595 el 28 Dic 2020, 03:45
Buenas chicos hay algo para H30? Tengo la 0359
León MK3 16´ FR Advanced 1.4 TSI ACT 150CV - Azul mediterráneo
Ateca 20´ FR Edition 2.0 TDI 150CV - Gris Rodium
RGF2595
Agradecido: 9 veces
Notapor Warelio el 28 Dic 2020, 09:30
RGF2595 escribió:Buenas chicos hay algo para H30? Tengo la 0359
¿Has echado un vistazo a los Posts? Revisa si para tu unidad existe una versión más moderna, es complicado acordarse de todas las versiones disponibles. En las últimas páginas es probable que encuentres información de si existe una versión actualizada para tu unidad, se habló bastante del tema.
Warelio
Moderador de Racing
Notapor Raulportela el 28 Dic 2020, 11:27
Buenas a todos a ver si alguien me aclara que es lo que tengo que hacer con este archivo exactamente.. yo tengo obdeleven
Agradeceria si alguien me lo pudiese explicar mas detalladamente que hacer en cada momento ya que no lo veo muy claro que hacer en algunos puntos gracias!
Raulportela
Notapor Warelio el 28 Dic 2020, 11:31
Raulportela escribió:Buenas a todos a ver si alguien me aclara que es lo que tengo que hacer con este archivo exactamente.. yo tengo obdeleven
¿El archivo que tienes abajo que se llama comoinstalar.txt no son las instrucciones de cómo instalar y los pasos a seguir? Imagino que en ese archivo detallará cómo has de proceder.
Warelio
Moderador de Racing
