León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor frestor el 22 Ene 2015, 12:00
frestor
Agradecido: 35 veces
Notapor rojas el 22 Ene 2015, 15:07
frestor escribió:Esta vale verdad?
http://m.ebay.es/itm/390788866033?cmd=VIDESC
por ejemplo :cuñao:
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1889 veces
Notapor GTI35 el 22 Ene 2015, 17:06
Yo tengo esa lista para instalar
Seat Leon ST FR 2.0 TDI 184CV
GTI35
Coche: Leon MK3 1.4 TSI 140cv
Agradecido: 90 veces
Notapor rocketboy el 22 Ene 2015, 17:07
Ahora, 13 euros de gastos de envio... No veas con la peña, casi tanto como la cámara! :comediante:
"Competir es vida. Cualquier cosa antes o después es sólo esperar"
Steve McQueen
rocketboy
Notapor GTI35 el 22 Ene 2015, 17:09
A mi me costo 15€ todo en aliexpress con la broca incluida!
GTI35
Notapor frestor el 22 Ene 2015, 17:24
Lo que pasa que en aliespres tarda en llegar y ya llevo mes y medio esperando
A este ritmo se me quitan las ganas
Gracias chavales
frestor
Notapor Martín st el 22 Ene 2015, 18:30
Esto ya se pone en marxa jejeje roker si lo tienes to tío eres una maquina pues ya me dirás que me hace falta, la camara ya tiene dueño....?
Martín st
Coche: Leon MK3 1.4 TSI 122cv
Agradecido: 26 veces
Notapor JoseCa el 22 Ene 2015, 18:36
frestor escribió:Lo que pasa que en aliespres tarda en llegar y ya llevo mes y medio esperando
Gracias chavales
Yo en aliexpress suelo comprar bastantes cosas. Lo que más me tardo en llegar llego en un 33 días, y lo que menos 7 días(Flipé)
Yo creo que depende de la rapidez de envío del vendedor, de que no hayas problemas con la compañía de transporte y sobre todo la alineación de los astros y la luna. [FACE WITH TEARS OF JOY]
JoseCa
Agradecido: 47 veces
Notapor AlvaroFR el 22 Ene 2015, 20:59
Gracias chavales
Tambien que amontonan un porron de envios con mismo destino y luego los mandan. De ahí que se tarde y que sea gratis el envío, sino no les sería rentable.
Tambien puede pasar que en la aduana te retengan un paquete mas tiempo y/o lo abran por contener sustancias quimicas tipo bateria.
AlvaroFR
Agradecido: 33 veces
Notapor rojas el 22 Ene 2015, 21:05
yo aun espero el fusible para hacer el brico hace ya mas de un mes .... estoy por hacer el brico y dejar la conexion de corriente para cuando llegue !! :rey:
rojas
Notapor Maestro el 22 Ene 2015, 22:44
Buenas....
Al final como tenia todos los componentes y estaba impaciente por tener la cámara de marcha atrás en el coche he instalado la del deal extreme que compre, no puse RCA en el quadlock y puse directamente los faston al cable, como por otro lado me dio guerra el alimentar la cámara con la luz d marcha atrás lleve el cable de alimentación hasta los fusibles y allí lo alimente con el ladrón de fusibles sin rele ni el cacharro que compre, os dejo un video de la adaptación de la cámara al plafón derecho de la matricula, quizás os pueda dar una idea.
Esta es la cámara http://www.dx.com/p/eagleyes-ec-th1009-1-4-ccd-170-wide-angle-car-rearview-camera-w-night-vision-black-dc-12v-195193#.VKBtdIAwJQ se ve muy bien de noche, si observáis al final del video podréis obserbar la luz que hay en el garage y como se ve más claro en la pantalla sin ningún ajuste
Última edición por Maestro el 23 Ene 2015, 15:44, editado 3 veces en total
Viajar no es desplazarse, es sentir el camino
Maestro
Agradecido: 25 veces
Notapor Maestro el 22 Ene 2015, 22:59
Maestro escribió:Buenas....
Al final como tenia todos los componentes y estaba impaciente por tener la cámara de marcha atrás en el coche he instalado la del deal extreme que compre, no puse RCA en el quadlock y puse directamente los faston al cable, como por otro lado me dio guerra el alimentar la cámara con la luz d marcha atrás lleve el cable de alimentación hasta los fusibles y allí lo alimente con el ladrón de fusibles, enganche un tornillos la chapa que esta en el lateral izqdo. Delos fusibles y allí puse la masa, decir que no he necesitado ningún rele ni el el aparatito que compre en ebay, os dejo un video de la adaptación de la cámara al plafón derecho de la matricula
http://youtu.be/8hbDEwT7Wus
Maestro
Notapor er_trompe el 22 Ene 2015, 23:18
frestor escribió:@rojas
El chino despues de mes y medio se ha olvidado de mandarme la camara
Y en vez de mandarme otra me devuelve el dinero hay dios....
Haber en vez de poner la camara en el plafon la kiero poner centrada en el paracas, le hago agujero y pista
Ahora el tema, que camara pongo, tendra que tener vision nocturna no?
me echais un cable?
Yo he pillado esta, es la mas pequeña que he encontrado, se puede regular en altura, para ponerla justo que se vea el filo del paragolpes y de noche va bien, necesita muy poca luz para verse, vamos que con la de marcha atras va de sobra. La voy a poner entre las luces de matrículas, en el centro del paragolpes. Bueno bonito barato, al menos eso parece, ya diré cuando la tenga
http://www.aliexpress.com/item/Factory- ... 21665.html
Edito: Acabo de leer que prefieres no pillarla por aliexpress. De todos modos ya te han comentado que depende mucho del vendedor y su tiempo de preparación, pero, es lo que tiene comprar a mitad de precio, o incluso mas barato
Es de bien nacido ser agradecido. Si te ha resultado útil este mensaje, dale al botoncito de gracias ;)
Antes de preguntar, escribe tu duda aqui, posiblemente ahorres tiempo y nos lo ahorres a los demás.
er_trompe
Agradecido: 124 veces
Notapor frestor el 23 Ene 2015, 10:43
Manda huevos chavales
No voy ayer y compro la nueva camara que hoy a las 9:30 llama el cartero y me trae la china del plafon
Con la pasta devuelta en mi cuenta de paypal por el chino claro
He pedido que me anule el pedido al de la camara nueva, que aunque ya lo pague por paypal haber si hace el favor
Sino me lo devuelve tendre 2 camaras y 1 coche, es decir que me sobra 1camara, ya ahora no se si poner la del plafon o la otra.....
No me jodas que mala suerte, esperandola 1 mes y medio, me devuelven la pasta sin pedirselo al chino, compro otra y me llega la china
Bueno sino me anula el pedido si alguien la quereis me sobra 1
Haber que me dice entre hoy y mañana
frestor
Notapor JoseCa el 23 Ene 2015, 11:28
frestor escribió:Manda huevos chavales
Y si cancelas la transferencia directamente en PayPal?
JoseCa
